motion sensor data is not showing using thingy 91 for Asset Tracker ?
hello sir ,
 i am using thigy91 board and uploaded the asset tracker application code from  ncs sample code . ii am getting humidity data on my azure cloud .but there was no data available regarding motion sensor.
1. Is there any way for test motion sensor data ,any AT command for it for LTE monitor.
2. Is I need to solder SB6 and SB5 pin to get data.
  • Hello Mohit,
    Mohit Nama said:
    link you shred i read and find that there was no solution for my problem.
    i there was no solution for checking step by step ,
    The Asset Tracker v2 application is intended to demonstrate the usage of asset tracking with our nRF9160. Its purpose is not to cover all possible customer use cases.
    As already mentioned in my first reply:
    The accelerometer available on the Thingy:91 needs detailed tuning for each use case to determine reliably which readings are considered as motion.
    This is beyond the scope of the general asset tracker framework this application provides.
    Therefore, the readings are not transmitted to the cloud and are only used to detect a binary active and inactive state.
    Every customisation beyond this scope has to be done by our customers themselves. We are happy to support you with technical input during the development process, but I’m not able to tell how you should customise your application step by step.
    Markus
  • i got this data , did acc mean acceleration and spd means , speed ???
    please confirm.
