Connect to service through Nrf connect app on NRF52833.
Hello Everyone,
                     I am using NRF52833 in my project and I have implemented one service named borrower. The code details are in the attached in the files. When I open nrfconnect app and try to connect to my device, I am able to connect to it. The app asks for pairing request as I have added static security key and it gets connected to the app. Now the firmware has 2 services named borrower and lender. Currently I am working on the borrower service. I can see the service details in the NRFCONNECT app but when I try to send or receive data via Nrfconnect app. I get
Error(0x85):GATT ERROR -
GATT Timeout error.
Can anyone help me resolve the issue? I have seen many threads on it but doesnt seem to find the solution.
Thanks & Regards,
Snehal.
#include "sdk_common.h"
#include "ble.h"
#include "ble_borrower.h"
#include "ble_srv_common.h"
#include "peer_manager.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#define NRF_LOG_MODULE_NAME ble_rcbr
#if BLE_RCBR_CONFIG_LOG_ENABLED
#define NRF_LOG_LEVEL       BLE_RCBR_CONFIG_LOG_LEVEL
#define NRF_LOG_INFO_COLOR  BLE_RCBR_CONFIG_INFO_COLOR
#define NRF_LOG_DEBUG_COLOR BLE_RCBR_CONFIG_DEBUG_COLOR
#else // BLE_RCBR_CONFIG_LOG_ENABLED
#define NRF_LOG_LEVEL       0
#endif // BLE_RCBR_CONFIG_LOG_ENABLED
#include "nrf_log.h"
NRF_LOG_MODULE_REGISTER();
static pm_peer_id_t m_peer_to_be_deleted = PM_PEER_ID_INVALID;
static uint16_t     m_conn_handle        = BLE_CONN_HANDLE_INVALID;
/**@brief Function for handling the @ref BLE_GAP_EVT_CONNECTED event from the SoftDevice.
 * @param[in] p_rcbr     R3charge Borrower Service structure.
 * @param[in] p_ble_evt Pointer to the event received from BLE stack.
static void on_connect(ble_rcbr_t * p_rcbr, ble_evt_t const * p_ble_evt)
    ret_code_t                 err_code;
    ble_rcbr_evt_t              evt;
    ble_gatts_value_t          gatts_val;
    uint8_t                    cccd_value[2];
    ble_rcbr_client_context_t * p_client = NULL;
    err_code = blcm_link_ctx_get(p_rcbr->p_link_ctx_storage,
                                 p_ble_evt->evt.gap_evt.conn_handle,
                                 (void *) &p_client);
    if (err_code != NRF_SUCCESS) {
        NRF_LOG_ERROR("Link context for 0x%02X connection handle could not be fetched.",
                      p_ble_evt->evt.gap_evt.conn_handle);
    /* Check the hosts CCCD value to inform of readiness to send data using the RX characteristic */
    memset(&gatts_val, 0, sizeof(ble_gatts_value_t));
    gatts_val.p_value = cccd_value;
    gatts_val.len     = sizeof(cccd_value);
    gatts_val.offset  = 0;
    err_code = sd_ble_gatts_value_get(p_ble_evt->evt.gap_evt.conn_handle,
                                      p_rcbr->tx_handles.cccd_handle,
                                      &gatts_val);
    if ((err_code == NRF_SUCCESS)     &&
            (p_rcbr->data_handler != NULL) &&
            ble_srv_is_notification_enabled(gatts_val.p_value)) {
        if (p_client != NULL) {
            p_client->is_notification_enabled = true;
        memset(&evt, 0, sizeof(ble_rcbr_evt_t));
        evt.type        = BLE_RCBR_EVT_NOTIF_ENABLED;
        evt.p_rcbr       = p_rcbr;
        evt.conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
        evt.p_link_ctx  = p_client;
        p_rcbr->data_handler(&evt);
/**@brief Function for handling the @ref BLE_GATTS_EVT_WRITE event from the SoftDevice.
static void on_write(ble_rcbr_t * p_rcbr, ble_evt_t const * p_ble_evt)
    ble_rcbr_evt_t                 evt;
    ble_rcbr_client_context_t    * p_client;
    ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
                                 p_ble_evt->evt.gatts_evt.conn_handle,
                      p_ble_evt->evt.gatts_evt.conn_handle);
    evt.conn_handle = p_ble_evt->evt.gatts_evt.conn_handle;
    if ((p_evt_write->handle == p_rcbr->tx_handles.cccd_handle) &&
            (p_evt_write->len == 2)) {
            if (ble_srv_is_notification_enabled(p_evt_write->data)) {
            } else {
                p_client->is_notification_enabled = false;
                evt.type                          = BLE_RCBR_EVT_NOTIF_DISABLED;
            if (p_rcbr->data_handler != NULL) {
    } else if ((p_evt_write->handle == p_rcbr->rx_handles.value_handle) &&
               (p_rcbr->data_handler != NULL)) {
        evt.type                  = BLE_RCBR_EVT_RX_DATA;
        evt.params.rx_data.p_data = p_evt_write->data;
        evt.params.rx_data.length = p_evt_write->len;
    } else {
        // Do Nothing. This event is not relevant for this service.
/**@brief Function for handling the @ref BLE_GATTS_EVT_HVN_TX_COMPLETE event from the SoftDevice.
static void on_hvx_tx_complete(ble_rcbr_t * p_rcbr, ble_evt_t const * p_ble_evt)
    ble_rcbr_evt_t              evt;
        return;
    if ((p_client->is_notification_enabled) && (p_rcbr->data_handler != NULL)) {
        evt.type        = BLE_RCBR_EVT_TX_RDY;
void ble_rcbr_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
    if ((p_context == NULL) || (p_ble_evt == NULL)) {
        return;
    ble_rcbr_t * p_rcbr = (ble_rcbr_t *)p_context;
    switch (p_ble_evt->header.evt_id) {
    case BLE_GAP_EVT_CONNECTED:
        on_connect(p_rcbr, p_ble_evt);
    case BLE_GATTS_EVT_WRITE:
        on_write(p_rcbr, p_ble_evt);
    case BLE_GATTS_EVT_HVN_TX_COMPLETE:
        on_hvx_tx_complete(p_rcbr, p_ble_evt);
        // No implementation needed.
uint32_t ble_rcbr_init(ble_rcbr_t * p_rcbr, ble_rcbr_init_t const * p_rcbr_init)
    ble_uuid_t            ble_uuid;
    ble_uuid128_t         rcbr_base_uuid = RCBR_BASE_UUID;
    ble_add_char_params_t add_char_params;
    VERIFY_PARAM_NOT_NULL(p_rcbr);
    VERIFY_PARAM_NOT_NULL(p_rcbr_init);
    // Initialize the service structure.
    p_rcbr->data_handler = p_rcbr_init->data_handler;
    /**@snippet [Adding proprietary Service to the SoftDevice] */
    // Add a custom base UUID.
    err_code = sd_ble_uuid_vs_add(&rcbr_base_uuid, &p_rcbr->uuid_type);
    VERIFY_SUCCESS(err_code);
    ble_uuid.type = p_rcbr->uuid_type;
    ble_uuid.uuid = BLE_UUID_RCBR_SERVICE;
    // Add the service.
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                        &ble_uuid,
                                        &p_rcbr->service_handle);
    // Add the RX Characteristic.
    memset(&add_char_params, 0, sizeof(add_char_params));
    add_char_params.uuid                     = BLE_UUID_RCBR_SETTING_CHARACTERISTIC;
    add_char_params.uuid_type                = p_rcbr->uuid_type;
    add_char_params.max_len                  = BLE_RCBR_MAX_NOTIF_CHAR_LEN;
    add_char_params.init_len                 = sizeof(uint8_t);
    add_char_params.is_var_len               = true;
    add_char_params.char_props.write         = 1;
    add_char_params.char_props.write_wo_resp = 1;
    add_char_params.read_access  = SEC_OPEN;
    add_char_params.write_access = SEC_OPEN;
    err_code = characteristic_add(p_rcbr->service_handle, &add_char_params, &p_rcbr->rx_handles);
        return err_code;
    // Add the TX Characteristic.
    /**@snippet [Adding proprietary characteristic to the SoftDevice] */
    add_char_params.uuid              = BLE_UUID_RCBR_NOTIF_CHARACTERISTIC;
    add_char_params.max_len           = BLE_RCBR_MAX_SETTING_CHAR_LEN;
    add_char_params.char_props.notify = 1;
    add_char_params.cccd_write_access = SEC_OPEN;
    return characteristic_add(p_rcbr->service_handle, &add_char_params, &p_rcbr->tx_handles);
uint32_t ble_rcbr_data_send(ble_rcbr_t * p_rcbr,
                            uint8_t   * p_data,
                            uint16_t  * p_length,
                            uint16_t    conn_handle)
    ble_gatts_hvx_params_t     hvx_params;
    err_code = blcm_link_ctx_get(p_rcbr->p_link_ctx_storage, conn_handle, (void *) &p_client);
    if ((conn_handle == BLE_CONN_HANDLE_INVALID) || (p_client == NULL)) {
        return NRF_ERROR_NOT_FOUND;
    if (!p_client->is_notification_enabled) {
    if (*p_length > BLE_RCBR_MAX_DATA_LEN) {
        return NRF_ERROR_INVALID_PARAM;
    memset(&hvx_params, 0, sizeof(hvx_params));
    hvx_params.handle = p_rcbr->tx_handles.value_handle;
    hvx_params.p_data = p_data;
    hvx_params.p_len  = p_length;
    hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
    return sd_ble_gatts_hvx(conn_handle, &hvx_params);
ble_borrower.h
* Copyright (c) [2019-2021], Netobjex INC
* All rights reserved.
* File:    borrower.c
* Summary: Borrower
* Developer: [email protected]
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <stdlib.h>
#include "error_defs.h"
#include "FreeRTOS.h"
#include "task.h"
#include "semphr.h"
#include "timers.h"
#include "borrower.h"
#include "tasks.h"
#include "task_borrower.h"
#include "button_manager.h"
#include "nrf_drv_gpiote.h"
#include "boards.h"
#include "nrf_log_ctrl.h"
#include "borrower_protocol.h"
#include "device_configuration.h"
#include "product_config.h"
#include "byte_helper.h"
#include "main.h"
#include "battery.h"
#include "device_storage.h"
#include "task_led_button.h"
#include "psf_comm.h"
#include "psf_i2c.h"
#include "max17211_i2c.h"
static device_config_t device_setting;
//extern char device_id[16];
extern uint8_t device_id[17];
extern int8_t rssi;
extern int8_t rssi_val_change;
 * @brief Send data to Central using RCBR service
 * @return NRF_SUCCESS if successful, error otherwise
uint32_t rcbr_service_send_data(uint8_t * data, uint16_t len)
    uint32_t rc = NRF_SUCCESS;
    ble_rcbr_t * rcbr_srv = get_rcbr_service();
    uint16_t length_send = len;
    rc = ble_rcbr_data_send(rcbr_srv,
                            data,
                            &length_send,
                            get_conn_handle());
    if(length_send != len) {
        NRF_LOG_INFO("Attempted to send %d but only sent %d", len, length_send);
    return rc;
borrower_t borrower = {0, 0, 0, 0, 0, {02, 10, 40, 1, 00, 02, 75, 07, 100, 06, 07, 01}};
//uint8_t device_id[DEVICE_ID_BYTE_LEN];
uint8_t flag_saveSetting1 = 0;
 uint32_t borrower_pos = 0;
void borrower_load_settings(void)
    err_rc_t rc = RESULT_ERROR_FAILURE;
    NRF_LOG_INFO("Load Device Setting.");
    while(rc != RESULT_SUCCESS) {
        rc = device_storage_load(&borrower.setting);
       // vTaskDelay(100);
    NRF_LOG_INFO("Device Id: %s", borrower.setting.device_id);
    memcpy(device_id, &borrower.setting.device_id, 16);
void borrower_save_settings(void)
    device_storage_store(&borrower.setting);//$$
void borrower_notify_value(uint8_t cmd)
    char payload[20];float soc;float current;
    uint8_t i = 0;
    memset(payload, 0x00, 20);
    payload[0] = cmd;
    switch (cmd) {
        case BORROWER_OPCODE_SOC: {
            NRF_LOG_INFO("BORROWER Notify: SOC");
            memcpy(&payload[1], &(session_id), 16);
            //soc = get_soc();
            payload[2] = get_soc();
        rcbr_service_send_data(payload, 20);
char code1;
void borrower_process_ble_setting_msg(char *data, uint8_t len)
    activate_led_event(LED_EVENT_SETTINGS_DONE);
void borrower_report_current_status()
    borrower_notify_value(BORROWER_OPCODE_SOC);
    borrower_notify_value(BORROWER_OPCODE_CURRENT);
    borrower_notify_value(BORROWER_OPCODE_BATTERY);
void borrower_readSetting(void) {
//	eeprom_read(DEVICE_SETTING_ADDR, (char*)&borrower.setting, sizeof(borrower_setting_t));
    // nrf_delay_ms(100);
    mem_read_device_setting(&borrower.setting); // read setting from flash and set device id.
    NRF_LOG_INFO("Read setting.");
    NRF_LOG_INFO("Device Id: %s", device_id);
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_freertos.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "task.h"
#include "timers.h"
#include "semphr.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_drv_clock.h"
#include "ble_lender.h"
#include "task_lender.h"
#include "task_system.h"
#include "task_psf_comm.h"
#include "version.h"
#include "lender.h"
#include "nrf_drv_twi.h"
#include "bq24292i.h"
#define DEVICE_NAME                         LE_DEVICE_NAME                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME                   "nordic"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                    300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                    18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define RTC_INTERVAL                        1000                                    /**< RTC interval (ms). */
#define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated battery level. */
#define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(300, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                       0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(5000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY      5000                                    /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY       30000                                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                      1                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_DISPLAY_ONLY                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                      /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define OSTIMER_WAIT_FOR_QUEUE              2                                       /**< Number of ticks to wait for the timer queue to be ready */
#define DEVICEID_SIZE           16
uint8_t device_id[DEVICEID_SIZE+1] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
static char app_fw_version[32];
uint8_t rclr_data_buf[256] = {0};
uint8_t rcbr_data_buf[256] = {0};
uint16_t rclr_data_cnt = 0;
uint16_t rcbr_data_cnt = 0;
BLE_RCLR_DEF(m_rclr, NRF_SDH_BLE_TOTAL_LINK_COUNT);                  /**< BLE R3charge lender service instance. */
BLE_RCBR_DEF(m_rcbr, NRF_SDH_BLE_TOTAL_LINK_COUNT);                  /**< BLE R3charge borrower service instance. */
BLE_BAS_DEF(m_bas);                                                 /**< Battery service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
////////////Added for bonding///////////
// Static passkey
#define STATIC_PASSKEY    "123456"
static ble_opt_t    m_static_pin_option;
uint8_t passkey[] = STATIC_PASSKEY;
static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
   // {BLE_UUID_RCLR_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN},
    {BLE_UUID_RCBR_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN}
static TimerHandle_t m_rtc_timer;                               /**< Definition of battery timer. */
#if NRF_LOG_ENABLED
static TaskHandle_t m_logger_thread;                                /**< Definition of Logger thread. */
static void advertising_start(void * p_erase_bonds);
static void nrf_nvmc_write_word(uint32_t address, uint32_t value);
ble_rclr_t * get_rclr_service(void)
    return &m_rclr;
ble_rcbr_t * get_rcbr_service(void)
    return &m_rcbr;
uint16_t get_conn_handle(void)
    return m_conn_handle;
uint8_t * get_rclr_rcv_buffer(void)
    return rclr_data_buf;
uint16_t get_rclr_rcv_cnt(void)
    return rclr_data_cnt;
uint8_t * get_rcbr_rcv_buffer(void)
    return rcbr_data_buf;
uint16_t get_rcbr_rcv_cnt(void)
    return rcbr_data_cnt;
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    bool delete_bonds = false;
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id) {
        //..advertising_start(&delete_bonds);
        advertising_start(false);
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
void battery_level_update(void)
    uint8_t  battery_level;
    battery_level = battery_get_percentage(); /* Update TODO */
    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
uint32_t rtc_val = 0;
uint32_t get_system_rtc(void)
    return rtc_val;
/**@brief Function for handling the RTC event
 * @details This function will be called each time the RTC timer expires.
 * @param[in] xTimer Handler to the timer that called this function.
 *                   You may get identifier given to the function xTimerCreate using pvTimerGetTimerID.
static void rtc_timeout_handler(TimerHandle_t xTimer)
    UNUSED_PARAMETER(xTimer);
    rtc_val++;
static StaticTimer_t xRTCTimer;
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    m_rtc_timer = xTimerCreateStatic("RTC",
                                     RTC_INTERVAL,
                                     pdTRUE,
                                     NULL,
                                     rtc_timeout_handler,
                                     &xRTCTimer);
    /* Error checking */
    if (NULL == m_rtc_timer) {
        APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    //commented for adding device id.
    //err_code = sd_ble_gap_device_name_set(&sec_mode,
    //                                      (const uint8_t *)DEVICE_NAME,
    //                                      strlen(DEVICE_NAME));
#ifdef USE_DEVICEID_ON_SRDATA
#else
    uint8_t basename_size = strlen(DEVICE_NAME);
    uint8_t devicename[DEVICEID_SIZE+1+basename_size+1];
    memcpy(&devicename[0], (const uint8_t *)DEVICE_NAME, basename_size);
    devicename[basename_size] = '-';
    memcpy(&devicename[basename_size+1], device_id, DEVICEID_SIZE);
    memset(&devicename[basename_size+1+DEVICEID_SIZE], 0x00, 1);
                                          (const uint8_t *)devicename,
                                          strlen(devicename));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
    ////////Added for bonding ///////////
    m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
    err_code =  sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
/**@brief Function for initializing the GATT module. */
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    APP_ERROR_HANDLER(nrf_error);
static void rclr_data_handler(ble_rclr_evt_t * p_evt)
    if (p_evt->type == BLE_RCLR_EVT_RX_DATA) {
        uint32_t err_code;
        if(p_evt->params.rx_data.length < sizeof(rclr_data_buf)) {
            memset(rclr_data_buf, 0, sizeof(rclr_data_buf));
            memcpy(rclr_data_buf, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            rclr_data_cnt = p_evt->params.rx_data.length;
            /* Inform lender Task we have a command */
            lender_task_queue_event(LENDER_TASK_EVT_SETTING_CMD);
    } else if(p_evt->type == BLE_RCLR_EVT_NOTIF_ENABLED) {
        /* Inform lender Task notifications have begun */
        lender_task_queue_event(LENDER_TASK_EVT_NOTIF_EN);
static void rcbr_data_handler(ble_rcbr_evt_t * p_evt)
    if (p_evt->type == BLE_RCBR_EVT_RX_DATA) {
        uint32_t err_code;
        if(p_evt->params.rx_data.length < sizeof(rcbr_data_buf)) {
            memset(rcbr_data_buf, 0, sizeof(rcbr_data_buf));
            memcpy(rcbr_data_buf, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            rcbr_data_cnt = p_evt->params.rx_data.length;
            /* Inform borrower Task we have a command */
            borrower_task_queue_event(BORROWER_TASK_EVT_SETTING_CMD);
        /* Inform borrower Task notifications have begun */
        borrower_task_queue_event(BORROWER_TASK_EVT_NOTIF_EN);
 * @details Initialize the Heart Rate, Battery and Device Information services.
    ble_rclr_init_t    rclr_init;
    ble_rcbr_init_t    rcbr_init;
    ble_bas_init_t     bas_init;
    ble_dis_init_t     dis_init;
    uint8_t            body_sensor_location;
    // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    // Here the sec level for the Battery Service can be changed/increased.
    bas_init.bl_rd_sec        = SEC_OPEN;
    bas_init.bl_cccd_wr_sec   = SEC_OPEN;
    bas_init.bl_report_rd_sec = SEC_OPEN;
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    err_code = ble_bas_init(&m_bas, &bas_init);
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    ble_srv_ascii_to_utf8(&dis_init.model_num_str, (char *)DEVICE_MODEL_NUM);
    ble_srv_ascii_to_utf8(&dis_init.serial_num_str, (char *)device_id);
    ble_srv_ascii_to_utf8(&dis_init.hw_rev_str, (char *)DEVICE_HW_VER);
    ble_srv_ascii_to_utf8(&dis_init.fw_rev_str, (char *)app_fw_version);
    dis_init.dis_char_rd_sec = SEC_OPEN;
    err_code = ble_dis_init(&dis_init);
    // Initialize RCLR- LENDER Service
    memset(&rclr_init, 0, sizeof(rclr_init));
    rclr_init.data_handler = rclr_data_handler;
    err_code = ble_rclr_init(&m_rclr, &rclr_init);
   // Initialize RCBR - BORROWER Service
    memset(&rcbr_init, 0, sizeof(rcbr_init));
    rcbr_init.data_handler = rcbr_data_handler;
    err_code = ble_rcbr_init(&m_rcbr, &rcbr_init);
/**@brief   Function for starting application timers.
 * @details Timers are run after the scheduler has started.
static void application_timers_start(void)
    // Start application timers.
    if (pdPASS != xTimerStart(m_rtc_timer, OSTIMER_WAIT_FOR_QUEUE)) {
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
 * @param[in]   p_evt   Event received from the Connection Parameters Module.
    if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for initializing the Connection Parameters module. */
    //err_code = bsp_indication_set(BSP_INDICATE_IDLE);
    //APP_ERROR_CHECK(err_code);
    //// Prepare wakeup buttons.
    //err_code = bsp_btn_ble_sleep_mode_prepare();
    //// Go to system-off mode (this function will not return; wakeup will cause a reset).
    //err_code = sd_power_system_off();
    uint32_t err_code;
    switch (ble_adv_evt) {
    case BLE_ADV_EVT_FAST:
        NRF_LOG_INFO("Fast advertising.");
    case BLE_ADV_EVT_IDLE:
       // sleep_mode_enter();
    char        passkey[BLE_GAP_PASSKEY_LEN + 1];
    uint16_t    role = ble_conn_state_role(m_conn_handle);
    pm_handler_secure_on_connection(p_ble_evt);
    uint32_t err_code;
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt; //$$ new
        NRF_LOG_INFO("Connected");
        adv_led_button =1;
        led_grn_pwr_active = 1;
        led_on_duration = get_system_rtc();
        let_btn_task_evt_t evt;
        evt.id = LED_TASK_EVT_PROCESS_LED_RC1;
        led_btn_task_queue_event(evt);
        err_code = sd_ble_gap_rssi_start(p_ble_evt->evt.gap_evt.conn_handle,1,2); //$$ new
        APP_ERROR_CHECK(err_code); //$$ new
        NRF_LOG_INFO("Disconnected");
#if 1
            //NRF_LOG_INFO("%s: BLE_GAP_EVT_SEC_PARAMS_REQUEST", nrf_log_push(roles_str[role]));
        //case BLE_GAP_EVT_PASSKEY_DISPLAY:
        //    memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, BLE_GAP_PASSKEY_LEN);
        //    passkey[BLE_GAP_PASSKEY_LEN] = 0x00;
        //    NRF_LOG_INFO("%s: BLE_GAP_EVT_PASSKEY_DISPLAY: passkey=%s match_req=%d",
        //                 nrf_log_push(roles_str[role]),
        //                 nrf_log_push(passkey),
        //                 p_ble_evt->evt.gap_evt.params.passkey_display.match_request);
        //    if (p_ble_evt->evt.gap_evt.params.passkey_display.match_request)
        //        on_match_request(m_conn_handle, role);
        //    break;
            //char passkey[16 + 1];
            memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, 16);
            passkey[16] = 0;
            // Don't send delayed Security Request if security procedure is already in progress.
            //err_code = app_timer_stop(m_sec_req_timer_id);
            NRF_LOG_INFO("Passkey: %s", nrf_log_push(passkey));
        } break;
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
           // NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_KEY_REQUEST", nrf_log_push(roles_str[role]));
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
            //NRF_LOG_INFO("%s: BLE_GAP_EVT_LESC_DHKEY_REQUEST", nrf_log_push(roles_str[role]));
         case BLE_GAP_EVT_AUTH_STATUS:
             //NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          //p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          //p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          //p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          //*((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          //*((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
    case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
        ble_gap_phys_t const phys = {
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys = BLE_GAP_PHY_AUTO,
    case BLE_GATTC_EVT_TIMEOUT:
    case BLE_GATTS_EVT_TIMEOUT:
    case BLE_GAP_EVT_RSSI_CHANGED:
         rssi = p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
        // NRF_LOG_INFO("RSSI: %d", p_ble_evt->evt.gap_evt.params.rssi_changed.rssi);
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    switch (event) {
    case BSP_EVENT_SLEEP:
        sleep_mode_enter();
    case BSP_EVENT_DISCONNECT:
        if (err_code != NRF_ERROR_INVALID_STATE) {
    case BSP_EVENT_WHITELIST_OFF:
        if (m_conn_handle == BLE_CONN_HANDLE_INVALID) {
/**@brief Function for handling events from the GATT library. */
//void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
//    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
//        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
//        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
//    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
//                  p_gatt->att_mtu_desired_central,
//                  p_gatt->att_mtu_desired_periph);
/**@brief Function for the Peer Manager initialization. */
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    //err_code = pm_register(pm_evt_handler);
/**@brief Clear bond information from persistent storage. */
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/**@brief Function for initializing the Advertising functionality. */
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = false;//..
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.uuids_more_available.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_more_available.p_uuids  = m_adv_uuids;
    init.srdata.name_type = BLE_ADVDATA_FULL_NAME;
static void log_init(void)
   // ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get); //..snehal
/**@brief Function for starting advertising. */
    bool erase_bonds = *(bool*)p_erase_bonds;
    if (erase_bonds) {
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
    } else {
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/* configSUPPORT_STATIC_ALLOCATION is set to 1, so the application must provide an
implementation of vApplicationGetIdleTaskMemory() to provide the memory that is
used by the Idle task. */
void vApplicationGetIdleTaskMemory( StaticTask_t **ppxIdleTaskTCBBuffer,
                                    StackType_t **ppxIdleTaskStackBuffer,
                                    uint32_t *pulIdleTaskStackSize )
    /* If the buffers to be provided to the Idle task are declared inside this
    function then they must be declared static - otherwise they will be allocated on
    the stack and so not exists after this function exits. */
    static StaticTask_t xIdleTaskTCB;
    static StackType_t uxIdleTaskStack[ configMINIMAL_STACK_SIZE ];
    /* Pass out a pointer to the StaticTask_t structure in which the Idle task's
    state will be stored. */
    *ppxIdleTaskTCBBuffer = &xIdleTaskTCB;
    /* Pass out the array that will be used as the Idle task's stack. */
    *ppxIdleTaskStackBuffer = uxIdleTaskStack;
    /* Pass out the size of the array pointed to by *ppxIdleTaskStackBuffer.
    Note that, as the array is necessarily of type StackType_t,
    configMINIMAL_STACK_SIZE is specified in words, not bytes. */
    *pulIdleTaskStackSize = configMINIMAL_STACK_SIZE;
/* configSUPPORT_STATIC_ALLOCATION and configUSE_TIMERS are both set to 1, so the
application must provide an implementation of vApplicationGetTimerTaskMemory()
to provide the memory that is used by the Timer service task. */
void vApplicationGetTimerTaskMemory( StaticTask_t **ppxTimerTaskTCBBuffer,
                                     StackType_t **ppxTimerTaskStackBuffer,
                                     uint32_t *pulTimerTaskStackSize )
    /* If the buffers to be provided to the Timer task are declared inside this
    static StaticTask_t xTimerTaskTCB;
    static StackType_t uxTimerTaskStack[ configTIMER_TASK_STACK_DEPTH ];
    /* Pass out a pointer to the StaticTask_t structure in which the Timer
    task's state will be stored. */
    *ppxTimerTaskTCBBuffer = &xTimerTaskTCB;
    /* Pass out the array that will be used as the Timer task's stack. */
    *ppxTimerTaskStackBuffer = uxTimerTaskStack;
    /* Pass out the size of the array pointed to by *ppxTimerTaskStackBuffer.
    configTIMER_TASK_STACK_DEPTH is specified in words, not bytes. */
    *pulTimerTaskStackSize = configTIMER_TASK_STACK_DEPTH;
void vApplicationMallocFailedHook( void )
    NRF_LOG_INFO("Malloc Failed");
void vApplicationStackOverflowHook(xTaskHandle *pxTask, signed char *pcTaskName )
    for( ;; );
#if NRF_LOG_ENABLED
/**@brief Thread for handling the logger.
 * @details This thread is responsible for processing log entries if logs are deferred.
 *          Thread flushes all log entries and suspends. It is resumed by idle task hook.
 * @param[in]   arg   Pointer used for passing some arbitrary information (context) from the
 *                    osThreadCreate() call to the thread.
static void logger_thread(void * arg)
    UNUSED_PARAMETER(arg);
    while (1) {
        NRF_LOG_FLUSH();
        vTaskSuspend(NULL); // Suspend myself
#endif //NRF_LOG_ENABLED
/**@brief A function which is hooked to idle task.
 * @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
void vApplicationIdleHook( void )
#if NRF_LOG_ENABLED
    vTaskResume(m_logger_thread);
/**@brief Function for initializing the clock.
static void clock_init(void)
    ret_code_t err_code = nrf_drv_clock_init();
#define LOGGER_TASK_STACK_SIZE 512
#define LOGGER_TASK_PRIORITY   1
/* Structure that will hold the TCB of the task being created. */
StaticTask_t xLoggerTaskBuffer;
/* Buffer that the task being created will use as its stack.  Note this is
an array of StackType_t variables.  The size of StackType_t is dependent on
the RTOS port. */
StackType_t xLoggerStack[ LOGGER_TASK_STACK_SIZE ];
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
/**@brief Function for application main entry.
    bool erase_bonds;
    uint32_t APPPROTECT_reg;
    bool status;
    // Initialize modules.
    log_init();
    clock_init();
    // Do not start any interrupt that uses system functions before system initialisation.
    // The best solution is to start the OS before any other initalisation.
#if NRF_LOG_ENABLED
    // Start execution.
    m_logger_thread = xTaskCreateStatic(logger_thread, "LOGGER", sizeof(xLoggerStack) / sizeof(xLoggerStack[0]), NULL, LOGGER_TASK_PRIORITY, xLoggerStack, &xLoggerTaskBuffer);
    if (m_logger_thread == NULL) {
NRF_LOG_INFO("TESTING NEW FIRMWARE");
   // buttons_leds_init(&erase_bonds);
    // Activate deep sleep mode.
 //   SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    memset(app_fw_version, 0, sizeof(app_fw_version));
    app_version_str(app_fw_version, sizeof(app_fw_version));
    mem_init();
    // Configure and initialize the BLE stack.
    ble_stack_init();
    device_storage_init();
    borrower_load_settings();
    timers_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    application_timers_start();
    // Create a FreeRTOS task for the BLE stack.
    // The task will run advertising_start() before entering its loop.
    nrf_sdh_freertos_init(advertising_start, &erase_bonds);
    init_led_button_task();
    init_borrower_task();
    init_psf_comm_task();
     // Start FreeRTOS scheduler.
    vTaskStartScheduler();
    for (;;) {
        APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
uint32_t app_timer_cnt_get(void)
    return xTaskGetTickCount();
uint32_t app_timer_cnt_diff_compute(uint32_t   ticks_to,
                                    uint32_t   ticks_from)
    return ((ticks_to - ticks_from) & RTC_COUNTER_COUNTER_Msk);
* File:    task_borrower.c
* Summary: borrower Task
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "task.h"
#include "semphr.h"
#include "timers.h"
#include "tasks.h"
#include "boards.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "main.h"
#include "psf_uart.h"
/* Task Configuration */
StaticTask_t task_borrower_tcb;
the RTOS port. */
StackType_t borrower_stack[ BORROWER_TASK_STACK_SIZE ];
static QueueHandle_t borrower_queue_handle = NULL;
static void borrower_task( void *pvParameters );
err_rc_t borrower_task_queue_event(BORROWER_TASK_EVENTS_t evt);
void rssi_change_timer_callback1( TimerHandle_t xTimer );
void max17211_timer_callback( TimerHandle_t xTimer );
static void water_flow_stop(void);
static void water_flow_start(void);
/* LED Stack Queue */
#define QUEUE_LENGTH    10
#define ITEM_SIZE       sizeof( BORROWER_TASK_EVENTS_t )
/* The variable used to hold the queue's data structure. */
static StaticQueue_t xStaticQueue;
/* The array to use as the queue's storage area.  This must be at least
uxQueueLength * uxItemSize bytes. */
uint8_t borrower_queue_storage_area[ QUEUE_LENGTH * ITEM_SIZE ];
volatile TaskHandle_t borrower_task_handle = NULL;
char session_id1[16];
static uint16_t timeSinceStart = 0;                                     // in seconds
static float lastWaterConsumption = 0;
static uint32_t lasttotalPulseCount = 0;
static uint32_t lastPulseCount = 0;
int8_t rssi_val_change1;
static const nrf_drv_timer_t m_timer1 = NRF_DRV_TIMER_INSTANCE(1);
static const nrf_drv_timer_t m_timer2 = NRF_DRV_TIMER_INSTANCE(2);
static nrf_ppi_channel_t m_ppi_channel1;
static nrf_ppi_channel_t m_ppi_channel2;
static void process_timer_event(void);
static void borrower_init(void);
static TimerHandle_t rssi_change_timer_handle;
static StaticTimer_t rssi_change_timer;
static TimerHandle_t max17211_handle;
static StaticTimer_t max17211_timer;
 * @brief Initializes the borrower Task
 * @return RESULT_SUCCESS if initialization completed, otherwise error
err_rc_t init_borrower_task(void)
    err_rc_t rc = RESULT_SUCCESS;
    do {
        /* Start the two tasks as described in the comments at the top of this
        file. */
        borrower_task_handle = xTaskCreateStatic(
                                 borrower_task,       /* Function that implements the task. */
                                 "borrower",          /* Text name for the task. */
                                 BORROWER_TASK_STACK_SIZE,      /* Number of indexes in the borrower_stack array. */
                                 ( void * ) 1,    /* Parameter passed into the task. */
                                 BORROWER_TASK_PRIORITY,/* Priority at which the task is created. */
                                 borrower_stack,          /* Array to use as the task's stack. */
                                 &task_borrower_tcb );  /* Variable to hold the task's data structure. */
        if(borrower_task_handle == NULL) {
        /* Create a queue */
        borrower_queue_handle = xQueueCreateStatic( QUEUE_LENGTH,
                              ITEM_SIZE,
                              borrower_queue_storage_area,
                              &xStaticQueue );
        if(borrower_queue_handle == NULL) {
        rssi_change_timer_handle = xTimerCreateStatic("RssiTimer",
                               20000,
                               pdFALSE,
                               ( void * ) 0,
                               rssi_change_timer_callback1,
                               &rssi_change_timer);
        if( rssi_change_timer_handle == NULL ) {
            /* The timer was not created */
        max17211_handle = xTimerCreateStatic("Max17211Timer",
                               10000,
                               pdTRUE,
                               ( void * ) 0,
                               max17211_timer_callback,
                               &max17211_timer);
        if( max17211_handle == NULL ) {
    } while(0);
    return rc;
 * @brief Queues an event to be processed by the borrower Task
 * @param evt is the event to queue
    BORROWER_TASK_EVENTS_t queue_evt = evt;
    BaseType_t result =  xQueueSendFromISR(borrower_queue_handle,
                                           &queue_evt,
                                           NULL);
    if(result != pdTRUE) {
    return rc;
 * @brief Main borrower Task thread
 * @param pvParameters unused
    BORROWER_TASK_EVENTS_t evt;
    btnmgr_return_t btrc;
    /* Remove compiler warning about unused parameter. */
    ( void ) pvParameters;
  //  borrower_init();
    if(xTimerStart(max17211_handle, 0 ) != pdPASS ) {
        // The timer could not be set into the Active state.
    while(1)
        xQueueReceive( borrower_queue_handle, &evt, portMAX_DELAY );
        switch(evt)
            case BORROWER_TASK_EVT_TIMER:
               // process_timer_event();
            case BORROWER_TASK_EVT_SETTING_CMD:
                borrower_process_ble_setting_msg(get_rcbr_rcv_buffer(), get_rcbr_rcv_cnt());
            case BORROWER_TASK_EVT_NOTIF_EN:
                /* Notification is enabled, so report the current status */
                borrower_report_current_status();
/**@brief water flow measurement setup
    rssi_val_change1 = 1;
    get_max17201_data();
  • Hi Snehal,
    Could you provide any log from the device ?
    Do you find any disconnect reason when BLE_GAP_EVT_DISCONNECTED occur ?
    I would suggest to capture a sniffer trace so we can get to know what happened over the connection.
  • Hi Hung,
                I actually checked in nrf connect app regarding the logs. When I was trying to see the logs in NRF connect app, I saw the error in the app. It showed "Error(0x85):GATT ERROR" and connection timeout.
    Thanks & Regards,
    Snehal Bundele.
  • Hi Snehal,
    What I was asking is the log from the device, not the log from the nRF Connect app. Do you have any UART , RTT log ?
  • Oh RTT log I will capture it and send to you. I had logs but did not save it. I will have to capture again. WIll share it to you soon.
    Thanks & Regards,
    Snehal.
  • Thanks, please try capture the sniffer trace as well.
  • I have captured the log. After connection when i try to send/receive data on NRF connect app I get the error mentioned in the below log file. I was not able to capture sniffer trace.
    00> <info> app: TESTING NEW FIRMWARE
    00>
    00> <info> app: SoftDevice is present.
    00>
    00> <info> app: Initializing nrf_fstorage_sd implementation...
    00>
    00> <info> app: Load Device Setting.
    00>
    00> <info> app: SIGN is 0
    00>
    00> <info> app: No settings found. Loading defaults
    00>
    00> <info> app: Device Id: 0000000000000001
    00>
    00> <info> app: R3CHARGE Starting
    00>
    00> <info> app: FW Version: 1.0.0
    00>
    00> <info> app: Fast advertising.
    00>
    00> <info> app: SUCCESS
    00>
    00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
    00>
    00> <info> app: Connected
    00>
    00> <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
    00>
    00>
    00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
    00>
    00> <info> app: Borrower Notify: BORROWER_OPCODE_BATTERY 0
    00>
    00> <error> app: ERROR 3735928559 [Unknown error code] at D:\SNEHAL\NETOBJEX\PROJECTS\RECHARGE\SOFTWARE\board-bringup-code\HARDWARE-BLE-FINAL\TIMER\firmware-recharge-nrf52833\sdk\external\freertos\source\queue.c:930
    00>
    00> PC at: 0x00032345
    00>
    00> <error> app: End of error report
    Thanks & Regards,
    Snehal.
  • Hi Snehal,
    I'm no FreeRTOS expert but the log pointed to an assert in \external\freertos\source\queue.c:930
    Have you checked that  ?
    It has something to do with the xqueue in freertos. I noticed that you used that in the task_borrower.c .
    Have you checked you have configured the queue correctly ?
