Hi
I would like to change my coded PHY layer 1MBps to 2Mbps.
For that, i just change the params BLE_GAP_PHY_1MBPS to BLE_GAP_PHY_2MBPS in my code.
But now the function sd_ble_gap_adv_set_configure return error 0x07.
Are they others changes needed ?
The SDK used is 15.3 and SD is 132.
see my init code
/**@brief Init advertising
void advertising_init(void)
ble_advertising_init_t init;
memset(&init,0,sizeof(ble_advertising_init_t));
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.le_role = BLE_ADVDATA_ROLE_ONLY_PERIPH;
// generate data packet
uint8_t data[22]={0};
// store advertising manufacturer data
ble_advdata_manuf_data_t adv_manuf_data = {0};
convert_adv_params_to_buffer(data,&adv_manuf_data.data.size);
adv_manuf_data.data.p_data = data;
adv_manuf_data.company_identifier = NORDIC_COMPANY_ID;
init.advdata.p_manuf_specific_data = &adv_manuf_data;
// store advdata to static global variable for an easier update
advdata = init.advdata;
// return to advertising after disconnected event from central
init.config.ble_adv_on_disconnect_disabled = false;
init.config.ble_adv_extended_enabled = false;
// configure fast advertising
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_interval = MSEC_TO_UNITS(ADV_INTERVAL_MS,UNIT_0_625_MS);
init.config.ble_adv_fast_timeout = 0; // 10 min converted in units of 10 ms
// configure slow advertising
init.config.ble_adv_slow_enabled = true;
init.config.ble_adv_slow_interval = MSEC_TO_UNITS(ADV_LONG_INTERVAL_MS,UNIT_0_625_MS);
init.config.ble_adv_slow_timeout = 0; // Unlimited ?
APP_ERROR_CHECK(ble_advertising_init(&m_advertising, &init));
APP_ERROR_CHECK(ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST));
uint32_t ble_advertising_init(ble_advertising_t * const p_advertising,
ble_advertising_init_t const * const p_init)
uint32_t ret;
if ((p_init == NULL) || (p_advertising == NULL))
return NRF_ERROR_NULL;
if (!config_is_valid(&p_init->config))
return NRF_ERROR_INVALID_PARAM;
p_advertising->adv_mode_current = BLE_ADV_MODE_IDLE;
p_advertising->adv_modes_config = p_init->config;
p_advertising->conn_cfg_tag = BLE_CONN_CFG_TAG_DEFAULT;
p_advertising->evt_handler = p_init->evt_handler;
p_advertising->error_handler = p_init->error_handler;
p_advertising->current_slave_link_conn_handle = BLE_CONN_HANDLE_INVALID;
p_advertising->p_adv_data = &p_advertising->adv_data;
memset(&p_advertising->peer_address, 0, sizeof(p_advertising->peer_address));
// Copy advertising data.
if (!p_advertising->initialized)
p_advertising->adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
p_advertising->adv_data.adv_data.p_data = p_advertising->enc_advdata;
if (p_advertising->adv_modes_config.ble_adv_extended_enabled == true)
#ifdef BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED
p_advertising->adv_data.adv_data.len = BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED;
#else
p_advertising->adv_data.adv_data.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX;
#endif // BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED
ret = ble_advdata_encode(&p_init->advdata, p_advertising->enc_advdata, &p_advertising->adv_data.adv_data.len);
VERIFY_SUCCESS(ret);
if (&p_init->srdata != NULL)
p_advertising->adv_data.scan_rsp_data.p_data = p_advertising->enc_scan_rsp_data;
p_advertising->adv_data.scan_rsp_data.len = BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED;
#else
p_advertising->adv_data.scan_rsp_data.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX;
ret = ble_advdata_encode(&p_init->srdata,
p_advertising->adv_data.scan_rsp_data.p_data,
&p_advertising->adv_data.scan_rsp_data.len);
p_advertising->adv_data.scan_rsp_data.p_data = NULL;
p_advertising->adv_data.scan_rsp_data.len = 0;
// Configure a initial advertising configuration. The advertising data and and advertising
// parameters will be changed later when we call @ref ble_advertising_start, but must be set
// to legal values here to define an advertising handle.
p_advertising->adv_params.primary_phy = BLE_GAP_PHY_2MBPS;//BLE_GAP_PHY_1MBPS;
p_advertising->adv_params.duration = p_advertising->adv_modes_config.ble_adv_fast_timeout;
p_advertising->adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
p_advertising->adv_params.p_peer_addr = NULL;
p_advertising->adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
p_advertising->adv_params.interval = p_advertising->adv_modes_config.ble_adv_fast_interval;
ret = sd_ble_gap_adv_set_configure(&p_advertising->adv_handle, NULL, &p_advertising->adv_params);
p_advertising->initialized = true;
return ret;
Thanks in advance
