Mesh shell errors enabling publication on a custom model
Hello
I added the mesh shell module to my app running on nRF52480 custom board and I am trying to provision and enable publication on the custom model I have
This produces multiple errors. See session log below. Any suggestions? Some of the errors are probably related to the memory allocation to various mesh/bt stack buffers -I can provide the proj.conf  if needed.
Another question - is the health client really needed? From what I can tell it just provides info about the faults - is it required?
Note
I know my custom model works - I can provision it with nRF Mesh app and configure publish parameters
I need to be able to do the same via the mesh shell
Thanks
mesh init
Mesh shell initialized
mesh provision 0 0x123
mesh dst
Destination address: 0x0000 (local) <--I expected it to be 0x123 that I used in provision
In general this dst parameter is confusing . What does it represent? The node address? If so - it should be set during provisioning, no?
mesh get-comp -error -116 (ETIMEDOUT)
Debug output:
[00:01:20.006,103] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x000002
[00:01:20.006,103] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 0 seq 0x000002
[00:01:20.006,164] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 16 headroom 9 tailroom 4
[00:01:20.006,225] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 16: 80800443a2c4dccbf6fe4f0a46d7c07f
[00:01:20.006,225] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x000003
[00:01:20.006,256] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 0 seq 0x000003
[00:01:20.006,256] <wrn> bt_mesh_net: Unable to allocate loopback
[00:01:20.006,286] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x000001 sub 0x20000980
[00:01:20.006,317] <err> bt_mesh_transport: Too big incoming SDU length
[00:01:20.006,347] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 7 headroom 9 tailroom 13
[00:01:20.006,408] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 7: 00000400000000
[00:01:20.006,408] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x000004
[00:01:20.006,439] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 1 seq 0x000004
[00:01:20.006,469] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x000002 sub 0x20000980
[00:01:20.006,500] <err> bt_mesh_transport: Too big incoming SDU length
[00:01:20.006,530] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 7 headroom 9 tailroom 13
[00:01:20.006,561] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 7: 00000400000000
[00:01:20.006,591] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x000005
[00:01:20.006,591] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 1 seq 0x000005
[00:01:20.006,652] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x000004 sub 0x20000980
[00:01:20.006,652] <wrn> bt_mesh_transport: SDU canceled
[00:01:20.006,683] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x000005 sub 0x20000980
[00:01:20.006,713] <wrn> bt_mesh_transport: No matching TX context for ack
NOTE. I get this error only when I set mesh dst to a value other than 0x0001.
mesh net-key-add 0 2870A43ADE4745D5F471CE29E6FFC0F2
NetKeyAdd failed with status 0x06 <--- where is this defined??
Debug output:
[00:04:11.208,740] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 16: 80002801468f989757e9afc82db6b474
--- 1 messages dropped ---
[00:04:11.208,770] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x00000a
[00:04:11.208,770] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 0 seq 0x00000a
[00:04:11.208,831] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x00000a sub 0x20000980
[00:04:11.208,923] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 16 headroom 9 tailroom 4
[00:04:11.208,953] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 16: 80002821c71db5939fa6c66af0798203
[00:04:11.208,984] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x00000b
[00:04:11.208,984] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 0 seq 0x00000b
[00:04:11.209,045] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x00000b sub 0x20000980
[00:04:11.209,106] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 7 headroom 9 tailroom 13
[00:04:11.209,136] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 7: 00002800000003
[00:04:11.209,167] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x00000c
[00:04:11.209,167] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 1 seq 0x00000c
[00:04:11.209,320] <dbg> bt_mesh_cfg_srv: net_key_add: idx 0x0000
[00:04:11.209,320] <dbg> bt_mesh_net_keys: bt_mesh_subnet_add: 0x000
[00:04:11.209,411] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 10 headroom 9 tailroom 10
[00:04:11.209,472] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 10: 006545f5ee661b34c1c2
[00:04:11.209,472] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x00000d
[00:04:11.209,472] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 0 seq 0x00000d
[00:04:11.209,533] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x00000c sub 0x20000980
[00:04:11.209,564] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x00000d sub 0x20000980
[00:04:11.209,716] <dbg> bt_mesh_cfg_cli: net_key_status: net_idx 0x0000 app_idx 0xfffe src 0x0123 len 3:
I can do mesh net-key-upd without errors
mesh app-key-add 0 0 522975C06BCADCBBF4A402DF2F895226
AppKey added, NetKeyIndex 0x0000 AppKeyIndex 0x0000
mesh app-key-get 0
Unable to send AppKeyGet (err -116)
[00:08:22.455,139] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 9 headroom 9 tailroom 11
[00:08:22.455,169] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 9: 00e81169afbfecbebb
[00:08:22.455,200] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x00001a
[00:08:22.455,200] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 0 seq 0x00001a
[00:08:22.455,261] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x00001a sub 0x20000980
[00:08:22.455,322] <dbg> bt_mesh_cfg_srv: app_key_get: idx 0x0000
[00:08:22.455,413] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 12 headroom 9 tailroom 8
[00:08:22.455,474] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 12: 002841cedf6f494a30412ffe
[00:08:22.455,474] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x00001b
[00:08:22.455,505] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 0 seq 0x00001b
[00:08:22.455,535] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x00001b sub 0x20000980
[00:08:22.455,688] <dbg> bt_mesh_cfg_cli: app_key_list: net_idx 0x0000 app_idx 0xfffe src 0x0123 len 5: 0000000000
[00:08:22.455,718] <err> bt_mesh_cfg_cli: The message size for the application opcode is incorrect.
mesh mod-app-bind 0x123 0 0x1002 0x0059
AppKey successfully bound
$ mesh mod-pub 0x123 0x1002 0x0059 0xFFFF 0 0 5 72 2 200
Model Publication Set failed (err -116)
[00:14:41.373,016] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x00001e
--- 3 messages dropped ---
[00:14:41.373,046] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 0 seq 0x00001e
[00:14:41.373,077] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x00001e sub 0x20000980
[00:14:41.373,168] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 16 headroom 9 tailroom 4
[00:14:41.373,229] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 16: 800078220f280ba70aa05e6e2cd2e77d
[00:14:41.373,229] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x00001f
[00:14:41.373,260] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 0 seq 0x00001f
[00:14:41.373,291] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x00001f sub 0x20000980
[00:14:41.373,382] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 13 headroom 9 tailroom 7
[00:14:41.373,443] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 13: 800078426b8ea9bfb6f2f80b01
[00:14:41.373,443] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x000020
[00:14:41.373,474] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 0 seq 0x000020
[00:14:41.373,504] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x000020 sub 0x20000980
[00:14:41.373,565] <dbg> bt_mesh_net: bt_mesh_net_send: src 0x0123 dst 0x0123 len 7 headroom 9 tailroom 13
[00:14:41.373,596] <dbg> bt_mesh_net: bt_mesh_net_send: Payload len 7: 00007800000007
[00:14:41.373,626] <dbg> bt_mesh_net: bt_mesh_net_send: Seq 0x000021
[00:14:41.373,626] <dbg> bt_mesh_net: net_header_encode: src 0x0123 dst 0x0123 ctl 1 seq 0x000021
[00:14:41.373,779] <dbg> bt_mesh_cfg_srv: mod_pub_va_set: elem_addr 0x0123 cred_flag 0
[00:14:41.373,779] <dbg> bt_mesh_cfg_srv: mod_pub_va_set: pub_app_idx 0x000, pub_ttl 5 pub_period 0x48
[00:14:41.373,809] <dbg> bt_mesh_cfg_srv: mod_pub_va_set: retransmit 0x1a (count 2 interval 200ms)
[00:14:41.373,809] <dbg> bt_mesh_cfg_srv: get_model: Company 0x0059 ID 0x1002 addr 0x0123
[00:14:41.374,908] <err> bt_mesh_transport: No multi-segment message contexts available
[00:14:41.374,938] <err> bt_mesh_cfg_srv: Unable to send Model Publication Status
[00:14:41.374,969] <dbg> bt_mesh_net: bt_mesh_net_local: src: 0x0123 dst: 0x0123 seq 0x000021 sub 0x20000980
  • Update
    I can now successfully provision and enable publication on a SIG  battery model ( battery server ) and see it publishing in the RTT log
    1 .issue remain
    1. Enabling publication on a custom model fails with status 0x07 E2BG - any ideas there?
    I enabled all the logging I could think of - no errors reported.
    Any ideas?
    Thanks
  • Update2
    A problem provisioning a SIG model (battery server)
    Here is the sequence I use
    uart:~$ mesh provision 0 0x0001
    uart:~$ mesh dst 0x0001
    Destination address set to 0x0001
    uart:~$ mesh get-comp
    Got Composition Data for 0x0001:
    CID 0x0a0a
    PID 0x0000
    VID 0x0000
    CRPL 0x000a
    Features 0x0007
    Element @ 0x0001:
    SIG Models:
    0x0000
    0x0002
    0x100c
    0x0001
    Vendor Models:
    Company 0x0059: 0x1002
    uart:~$ mesh net-key-upd 0 2870A43ADE4745D5F471CE29E6FFC0F2
    NetKey updated with NetKey Index 0x000
    uart:~$ mesh app-key-add 0 0 522975C06BCADCBBF4A402DF2F895226
    uart:~$ mesh mod-app-bind 0x0001 0 0x100c
    uart:~$ mesh mod-pub 0x0001 0x100c 0xFFFF 0 0 5 74 2 200
    Model Publication successfully set
    Model Publication for Element 0x0001, Model 0x100c:
    Publish Address: 0x9751
    AppKeyIndex: 0x0000
    Credential Flag: 0
    PublishTTL: 5
    PublishPeriod: 0x4a
    PublishRetransmitCount: 2
    PublishRetransmitInterval: 200ms
    uart:~$
    Why the publish address is 0x9751?
    The composition data is as follows
    static struct bt_mesh_elem elements[] = {
        BT_MESH_ELEM(
            1, BT_MESH_MODEL_LIST(
                BT_MESH_MODEL_CFG_SRV,
                BT_MESH_MODEL_HEALTH_SRV(&_health_srv, &_health_pub),
                BT_MESH_MODEL_BATTERY_SRV(&_batt_ctx.srv),
                BT_MESH_MODEL_CFG_CLI(&_config_client))
                vnd_models),
    And I still cannot enable publication on the custom model - status 0x07
  • Update3
    There are bugs in the mesh shell function
    1. When mod_pub_set() function is called from  cmd_mod_pub the is_va parameter is set to false
    In mod_pub_se()t the uuid field of bt_mesh_cfg_mod_pub structure is left uninitialized if is_va is false.
    Later in bt_mesh_cfg_mod_pub_set() function the pub->uuid field is examined and if it's not NULL mod_pub_va_set function is called
    Solution: memset the cmd_mod_pub  to clear all fields
    2. cmd_mod_pub  period field is not encoded  with the BT_MESH_PUB_PERIOD_SEC macro
    I modified the shell.c  in subsys/bluetooth/mesh/ an now I don't see the issue with the address described in update2. It is set to the value specified in the command parameters.
    The problem with the custom model (status 0x07) still remains.
    The team will take a look at this, I will come back to you when I have an update.
    Can you provide which version of the SDK you are using?
