Why can't I set uart0 to low power when the modem is running?
I use nrf9160 to develop a product for customers. The modem is also set to PSM and the log is turned off. However, I find that when the modem is connected to the Internet, it needs to use UART0. When I turn off UART0 or set it to low power consumption, the system will crash. Why? Why does the communication between modem and 9160 need UART0? Even if I have closed the log.
This is my proj.conf file:
# Copyright (c) 2019 Nordic Semiconductor ASA
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_ASSERT=y
CONFIG_REBOOT=y
CONFIG_GPIO=y
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
# Log
CONFIG_LOG=n
CONFIG_LOG_IMMEDIATE=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_LOG_MODE_OVERFLOW=y
CONFIG_LOG_BACKEND_RTT_MODE_DROP=y
CONFIG_LOG_BACKEND_SHOW_COLOR=n
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=n
# watch dog
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_TIMEOUT_MSEC=10000
# Modem info
CONFIG_MODEM_INFO=y
# BSD library
CONFIG_BSD_LIBRARY=y
CONFIG_BSD_LIBRARY_TRACE_ENABLED=n
# Flash
CONFIG_FLASH=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# NVS
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_NVS=y
CONFIG_NVS_LOG_LEVEL_DBG=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# GPS
CONFIG_NRF9160_GPS=y
#CONFIG_GPS_USE_SIM=y
CONFIG_GPS_USE_EXTERNAL=y
CONFIG_GPS_DEV_NAME="NRF9160_GPS"
CONFIG_GPS_CONTROL_PSM_ENABLE_ON_START=y
CONFIG_GPS_CONTROL_FIRST_FIX_CHECK_DELAY=10
CONFIG_GPS_CONTROL_FIX_CHECK_INTERVAL=30
CONFIG_GPS_CONTROL_FIX_TRY_TIME=360
CONFIG_GPS_CONTROL_PSM_DISABLE_ON_STOP=n
# AT_CMD
CONFIG_AT_HOST_LIBRARY=y
# Console
CONFIG_CONSOLE_SUBSYS=n
CONFIG_CONSOLE_HANDLER=n
CONFIG_CONSOLE_GETCHAR=n
CONFIG_CONSOLE=n
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
# Enable SUPL client support AGPS
CONFIG_SUPL_CLIENT_LIB=n
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_USE_FALLBACK=y
CONFIG_LTE_NETWORK_TIMEOUT=60
CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=n
CONFIG_LTE_NETWORK_MODE_NBIOT_GPS=y
CONFIG_LTE_LEGACY_PCO_MODE=y
# PSM
CONFIG_LTE_PSM_ENABLE=y
# Set Periodic-TAU timer to 10 minutes and Active-Time to 20 seconds.
CONFIG_LTE_PSM_REQ_RPTAU="10101010"
CONFIG_LTE_PSM_REQ_RAT="00001010"
# eDRX
CONFIG_LTE_EDRX_ENABLE=n
CONFIG_LTE_EDRX_REQ_VALUE="1001"
# RAI
CONFIG_LTE_RAI_ENABLE=n
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=n
CONFIG_MQTT_KEEPALIVE=300
CONFIG_MQTT_PUB_TOPIC="device/auri/pushdata"
CONFIG_MQTT_SUB_TOPIC="device/auri/"
CONFIG_MQTT_CLIENT_ID="my-client-id"
CONFIG_MQTT_USER_NAME="admin123"
CONFIG_MQTT_PASSWORD="admin123"
CONFIG_MQTT_DOMESTIC_BROKER_HOSTNAME="47.107.51.89"
CONFIG_MQTT_DOMESTIC_BROKER_PORT=1883
CONFIG_MQTT_FOREIGN_BROKER_HOSTNAME="18.135.53.53"
CONFIG_MQTT_FOREIGN_BROKER_PORT=1883
# Library for buttons and LEDs
CONFIG_DK_LIBRARY=y
CONFIG_DK_LIBRARY_INVERT_LEDS=n
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_HW_STACK_PROTECTION=y
# SPI
CONFIG_SPI=y
CONFIG_SPI_NRFX=y
CONFIG_SPI_2=n
CONFIG_SPI_2_NRF_SPIM=n
CONFIG_SPI_3=y
CONFIG_SPI_3_NRF_SPIM=y
# I2C
CONFIG_I2C=y
CONFIG_I2C_NRFX=y
CONFIG_I2C_1=y
CONFIG_I2C_1_NRF_TWIM=y
CONFIG_I2C_2=n
CONFIG_I2C_2_NRF_TWIM=n
CONFIG_I2C_INIT_PRIORITY=60
# UART
CONFIG_SERIAL=y
CONFIG_UART_2_NRF_UARTE=y
# ANIMATION
CONFIG_ANIMATION_SUPPORT=y
# PPG
CONFIG_PPG_SUPPORT=y
# IMU
CONFIG_IMU_SUPPORT=y
CONFIG_FALL_DETECT_SUPPORT=n
# WIFI
CONFIG_WIFI=n
# TP
CONFIG_TOUCH_SUPPORT=y
# AUDIO
CONFIG_AUDIO_SUPPORT=n
# Data Sync
CONFIG_SYNC_SUPPORT=y
# Temperature
CONFIG_TEMP_SUPPORT=y
# CRC Check
CONFIG_CRC_SUPPORT=y
# DEVICE POWER MANAGEMENT
CONFIG_DEVICE_POWER_MANAGEMENT=y
# Download client
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_TLS=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
# DATA UPDATE
CONFIG_DATA_DOWNLOAD_SUPPORT=y
CONFIG_DATA_DOWNLOAD_HOST_HK="aug-fm-files-hk.oss-cn-hongkong.aliyuncs.com"
CONFIG_DATA_DOWNLOAD_HOST_CN="aug-fm-files-cn.oss-cn-shenzhen.aliyuncs.com"
# IMG
CONFIG_IMG_DATA_UPDATE=y
CONFIG_IMG_DATA_DOWNLOAD_FILE="E2/e2_img.bin"
# FONT
CONFIG_FONT_DATA_UPDATE=y
CONFIG_FONT_DATA_DOWNLOAD_FILE="E2/e2_font.bin"
# PPG
CONFIG_PPG_DATA_UPDATE=y
CONFIG_PPG_DATA_DOWNLOAD_FILE="E2/e2_ppg.bin"
# fota download
#CONFIG_FOTA_DOWNLOAD=y
#CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
#CONFIG_FOTA_DOWNLOAD_HOST_HK="aug-fm-files-hk.oss-cn-hongkong.aliyuncs.com"
#CONFIG_FOTA_DOWNLOAD_HOST_CN="aug-fm-files-cn.oss-cn-shenzhen.aliyuncs.com"
#CONFIG_FOTA_DOWNLOAD_FILE="E2/e2_update.bin"
#CONFIG_APPLICATION_VERSION=1
# Image manager
#CONFIG_IMG_MANAGER=y
#CONFIG_FLASH=y
#CONFIG_IMG_ERASE_PROGRESSIVELY=y
# DFU Target
#CONFIG_DFU_TARGET=y
# Modem key management
#CONFIG_MODEM_KEY_MGMT=y
# Application Upgrade support
#CONFIG_BOOTLOADER_MCUBOOT=y
n
    Do you have a trace of the fault log output?
    Based on your prj.conf file, you are using Segger RTT as the log backend, and not uart. Could you share the full build/zephyr/.config file?
    Håkon
    # MQTT simple sample
    CONFIG_APPLICATION_WORKQUEUE_STACK_SIZE=1024
    CONFIG_APPLICATION_WORKQUEUE_PRIORITY=-1
    CONFIG_MQTT_MESSAGE_BUFFER_SIZE=128
    CONFIG_MQTT_PAYLOAD_BUFFER_SIZE=128
    CONFIG_SEC_TAG=16842753
    CONFIG_PEER_VERIFY=1
    # CONFIG_LTE_EDRX_ENABLE is not set
    # CONFIG_LTE_RAI_ENABLE is not set
    # end of MQTT simple sample
    # WATCH DOG
    # end of WATCH DOG
    # GPS
    # CONFIG_GPS_USE_SIM is not set
    CONFIG_GPS_CONTROL_ON_LONG_PRESS=y
    # CONFIG_GPS_CONTROL_PSM_DISABLE_ON_STOP is not set
    CONFIG_GPS_CONTROL_FIX_CHECK_OVERDUE=900
    CONFIG_GPS_CONTROL_FIX_COUNT=3
    CONFIG_GPS_CONTROL_MAX_FAILED_FIX_ATTEMPTS=3
    # CONFIG_GPS_START_ON_MOTION is not set
    # end of GPS
    # ANIMATION
    # end of ANIMATION
    # TOUCH
    # end of TOUCH
    # PPG
    # end of PPG
    # IMU
    # CONFIG_FALL_DETECT_SUPPORT is not set
    # end of IMU
    # AUDIO
    # CONFIG_AUDIO_SUPPORT is not set
    # end of AUDIO
    # SYNC
    # end of SYNC
    # TEMPERATURE
    # end of TEMPERATURE
    # CRC
    # end of CRC
    # DATA_DOWNLOAD
    # CONFIG_USE_HTTPS is not set
    # end of DATA_DOWNLOAD
    # IMG_UPDATE
    # CONFIG_DL_TARGET_UI is not set
    # end of IMG_UPDATE
    # FOTA_MQTT
    CONFIG_FOTA_DOWNLOAD_HOST_CN=""
    CONFIG_FOTA_DOWNLOAD_HOST_HK=""
    CONFIG_FOTA_DOWNLOAD_FILE=""
    # end of FOTA_MQTT
    # Zephyr Kernel
    # Modules
    # Nordic nRF Connect
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    # CONFIG_SECURE_BOOT_CRYPTO is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    # end of Secure Boot firmware validation
    # end of Bootloader
    # Bluetooth Low Energy
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # Networking
    # Application protocols
    # CONFIG_NRF_CLOUD is not set
    CONFIG_DOWNLOAD_CLIENT_MAX_FRAGMENT_SIZE=4096
    CONFIG_DOWNLOAD_CLIENT_MAX_TLS_FRAGMENT_SIZE=2048
    CONFIG_DOWNLOAD_CLIENT_MAX_RESPONSE_SIZE=4096
    CONFIG_DOWNLOAD_CLIENT_SOCK_TIMEOUT_MS=-1
    # CONFIG_DOWNLOAD_CLIENT_IPV6 is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_CLOUD_API is not set
    # Self-Registration (Zi ZHu Ce)
    # CONFIG_ZZHC is not set
    # end of Self-Registration (Zi ZHu Ce)
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # end of NFC
    # CONFIG_PROFILER is not set
    # SPM
    CONFIG_SPM=y
    # CONFIG_SPM_BUILD_STRATEGY_USE_HEX_FILE is not set
    # CONFIG_SPM_BUILD_STRATEGY_SKIP_BUILD is not set
    CONFIG_SPM_BUILD_STRATEGY_FROM_SOURCE=y
    # CONFIG_IS_SPM is not set
    CONFIG_ARM_ENTRY_VENEERS_LIB_NAME="spm/libspmsecureentries.a"
    # end of SPM
    CONFIG_FW_INFO=y
    CONFIG_FW_INFO_OFFSET=0x200
    CONFIG_FW_INFO_FIRMWARE_VERSION=1
    CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de
    CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c
    CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea
    CONFIG_FW_INFO_HARDWARE_ID=91
    CONFIG_FW_INFO_VERSION=2
    CONFIG_FW_INFO_CRYPTO_ID=0
    CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0
    CONFIG_FW_INFO_MAGIC_LEN=12
    CONFIG_FW_INFO_VALID_VAL=0x9102FFFF
    CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y
    # CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set
    # CONFIG_PPI_TRACE is not set
    # CONFIG_CPU_LOAD is not set
    # Nordic MPSL
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_SIGNAL_STACK_SIZE=1024
    # end of Nordic MPSL
    # CONFIG_PM_EXTERNAL_FLASH is not set
    # Libraries
    # Binary libraries
    # end of Binary libraries
    # BSD Library for nrf91
    CONFIG_BSD_LIBRARY_SYS_INIT=y
    # CONFIG_BSD_LIBRARY_TRACE_ENABLED is not set
    # CONFIG_NRF91_SOCKET_SEND_SPLIT_LARGE_BLOCKS is not set
    CONFIG_NRF91_SOCKET_BLOCK_LIMIT=2048
    # end of BSD Library for nrf91
    # CONFIG_ADP536X is not set
    # AT Command driver
    CONFIG_AT_CMD=y
    CONFIG_AT_CMD_SYS_INIT=y
    CONFIG_AT_CMD_INIT_PRIORITY=40
    CONFIG_AT_CMD_THREAD_PRIO=10
    CONFIG_AT_CMD_THREAD_STACK_SIZE=1024
    CONFIG_AT_CMD_RESPONSE_MAX_LEN=2700
    CONFIG_AT_CMD_RESPONSE_BUFFER_COUNT=2
    # end of AT Command driver
    # CONFIG_ST25R3911B_LIB is not set
    # CONFIG_LTE_AUTO_INIT_AND_CONNECT is not set
    # CONFIG_LTE_LOCK_BANDS is not set
    # CONFIG_LTE_LOCK_PLMN is not set
    # CONFIG_LTE_UNLOCK_PLMN is not set
    # CONFIG_LTE_EDRX_REQ is not set
    # CONFIG_LTE_PDP_CMD is not set
    # CONFIG_LTE_PDN_AUTH_CMD is not set
    # CONFIG_LTE_NETWORK_MODE_LTE_M is not set
    # CONFIG_LTE_NETWORK_MODE_LTE_M_GPS is not set
    # CONFIG_LTE_NETWORK_MODE_NBIOT is not set
    # CONFIG_FPROTECT is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000
    CONFIG_AT_NOTIF=y
    CONFIG_AT_NOTIF_SYS_INIT=y
    # AT Host Library for nrf91
    CONFIG_AT_HOST_UART_0=y
    # CONFIG_AT_HOST_UART_1 is not set
    # CONFIG_AT_HOST_UART_2 is not set
    CONFIG_AT_HOST_UART=0
    CONFIG_AT_HOST_UART_INIT_TIMEOUT=500
    # CONFIG_NULL_TERMINATION is not set
    # CONFIG_CR_TERMINATION is not set
    CONFIG_LF_TERMINATION=y
    # CONFIG_CR_LF_TERMINATION is not set
    CONFIG_AT_HOST_TERMINATION=2
    CONFIG_AT_HOST_CMD_MAX_LEN=4096
    CONFIG_AT_HOST_THREAD_PRIO=10
    # end of AT Host Library for nrf91
    CONFIG_DK_LIBRARY=y
    CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL=10
    CONFIG_DK_LIBRARY_INVERT_BUTTONS=y
    # CONFIG_DK_LIBRARY_INVERT_LEDS is not set
    CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS=y
    CONFIG_AT_CMD_PARSER=y
    CONFIG_MODEM_INFO=y
    CONFIG_MODEM_INFO_MAX_AT_PARAMS_RSP=10
    CONFIG_MODEM_INFO_BUFFER_SIZE=128
    CONFIG_MODEM_INFO_ADD_NETWORK=y
    CONFIG_MODEM_INFO_ADD_DATE_TIME=y
    CONFIG_MODEM_INFO_ADD_SIM=y
    CONFIG_MODEM_INFO_ADD_SIM_ICCID=y
    CONFIG_MODEM_INFO_ADD_SIM_IMSI=y
    CONFIG_MODEM_INFO_ADD_DEVICE=y
    CONFIG_MODEM_INFO_ADD_BOARD=y
    # CONFIG_PDN_MANAGEMENT is not set
    CONFIG_RESET_ON_FATAL_ERROR=y
    # CONFIG_SMS is not set
    # CONFIG_MODEM_KEY_MGMT is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # end of Libraries
    # Device Drivers
    CONFIG_ENTROPY_CC310=y
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # GPS Drivers
    # CONFIG_GPS_SIM is not set
    CONFIG_NRF9160_GPS_DEV_NAME="NRF9160_GPS"
    CONFIG_NRF9160_GPS_FIX_CHECK_INTERVAL=1
    CONFIG_NRF9160_GPS_HANDLE_MODEM_CONFIGURATION=y
    CONFIG_NRF9160_GPS_SET_MAGPIO=y
    CONFIG_NRF9160_GPS_MAGPIO_STRING="AT%XMAGPIO=1,0,0,1,1,1574,1577"
    CONFIG_NRF9160_GPS_SET_COEX0=y
    CONFIG_NRF9160_GPS_COEX0_STRING="AT%XCOEX0=1,1,1570,1580"
    # NMEA strings
    # CONFIG_NRF9160_GPS_NMEA_GSV is not set
    # CONFIG_NRF9160_GPS_NMEA_GSA is not set
    # CONFIG_NRF9160_GPS_NMEA_GLL is not set
    CONFIG_NRF9160_GPS_NMEA_GGA=y
    # CONFIG_NRF9160_GPS_NMEA_RMC is not set
    # end of NMEA strings
    CONFIG_NRF9160_GPS_INIT_PRIO=90
    CONFIG_NRF9160_GPS_THREAD_PRIORITY=10
    CONFIG_NRF9160_GPS_THREAD_STACK_SIZE=2048
    # end of GPS Drivers
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # end of Device Drivers
    # External libraries
    # CONFIG_CJSON_LIB is not set
    # end of External libraries
    # CONFIG_UNITY is not set
    # end of Nordic nRF Connect
    # MCUboot
    CONFIG_BOOT_SIGNATURE_KEY_FILE="root-rsa-2048.pem"
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    # end of MCUboot
    # Nordic nrfxlib
    CONFIG_BSD_LIB=y
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_NRF_OBERON=y
    # CONFIG_NRF_CC310_BL is not set
    # CONFIG_NRF_CC310_PLATFORM is not set
    # end of Crypto libraries for nRF5x SOCs.
    # Nordic Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # end of Nordic Security
    # end of Nordic nrfxlib
    # Optional modules. Make sure they're installed, via the project manifest.
    # CONFIG_CANOPENNODE is not set
    # CONFIG_CIVETWEB is not set
    # CONFIG_LIBMETAL is not set
    # CONFIG_HAS_SEMTECH_LORAMAC is not set
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # CONFIG_MBEDTLS is not set
    # CONFIG_HAS_MEC_HAL is not set
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # CONFIG_NRFX_CLOCK is not set
    # CONFIG_NRFX_DPPI is not set
    # CONFIG_NRFX_EGU is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    # CONFIG_NRFX_GPIOTE is not set
    # CONFIG_NRFX_I2S is not set
    # CONFIG_NRFX_IPC is not set
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM is not set
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_RTC is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    CONFIG_NRFX_SPIM=y
    # CONFIG_NRFX_SPIM0 is not set
    # CONFIG_NRFX_SPIM1 is not set
    # CONFIG_NRFX_SPIM2 is not set
    CONFIG_NRFX_SPIM3=y
    # CONFIG_NRFX_SPIS is not set
    # CONFIG_NRFX_SPIS0 is not set
    # CONFIG_NRFX_SPIS1 is not set
    # CONFIG_NRFX_SPIS2 is not set
    # CONFIG_NRFX_SPIS3 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TIMER is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    CONFIG_NRFX_TWIM=y
    # CONFIG_NRFX_TWIM0 is not set
    CONFIG_NRFX_TWIM1=y
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    # CONFIG_NRFX_TWIS is not set
    # CONFIG_NRFX_TWIS0 is not set
    # CONFIG_NRFX_TWIS1 is not set
    # CONFIG_NRFX_TWIS2 is not set
    # CONFIG_NRFX_TWIS3 is not set
    # CONFIG_NRFX_UARTE is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_UARTE2 is not set
    # CONFIG_NRFX_UARTE3 is not set
    CONFIG_NRFX_WDT=y
    CONFIG_NRFX_WDT0=y
    # CONFIG_NRFX_PRS is not set
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of nrfx drivers
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_TINYCBOR is not set
    # end of Modules
    CONFIG_SPI=y
    # CONFIG_NET_L2_ETHERNET is not set
    CONFIG_I2C=y
    # CONFIG_MODEM is not set
    CONFIG_NET_IPV6=y
    # CONFIG_NET_CONFIG_NEED_IPV6 is not set
    CONFIG_BOARD="nrf9160_pca10090"
    # CONFIG_I2C_2 is not set
    CONFIG_SPI_3=y
    CONFIG_FLASH_LOAD_SIZE=0x40000
    CONFIG_FLASH_LOAD_OFFSET=0x40000
    CONFIG_SOC="nRF9160_SICA"
    CONFIG_SOC_SERIES="nrf91"
    CONFIG_NUM_IRQS=65
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_WATCHDOG=y
    # CONFIG_UART_NS16550 is not set
    CONFIG_GPIO=y
    CONFIG_SYS_POWER_MANAGEMENT=y
    # CONFIG_SYS_POWER_DEEP_SLEEP_STATES is not set
    CONFIG_HAS_SYS_POWER_STATE_DEEP_SLEEP_1=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    # CONFIG_CORTEX_M_SYSTICK is not set
    CONFIG_CLOCK_CONTROL=y
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_FLOAT=y
    CONFIG_TEXT_SECTION_OFFSET=0
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_SRAM_SIZE=128
    CONFIG_SRAM_BASE_ADDRESS=0x20020000
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_TINYCRYPT is not set
    # CONFIG_NET_L2_IEEE802154 is not set
    CONFIG_SOC_GECKO_EMU=y
    # CONFIG_BOARD_NRF9160_PCA10090 is not set
    CONFIG_BOARD_NRF9160_PCA10090NS=y
    # Board Options
    # CONFIG_BOARD_NRF52840_GPIO_RESET is not set
    # end of Board Options
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MUSCA is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC1701X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    # CONFIG_SOC_SERIES_NRF52X is not set
    # CONFIG_SOC_SERIES_NRF53X is not set
    CONFIG_SOC_SERIES_NRF91X=y
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_CC310=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIOTE=y
    CONFIG_HAS_HW_NRF_I2S=y
    CONFIG_HAS_HW_NRF_IPC=y
    CONFIG_HAS_HW_NRF_PDM=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_PWM1=y
    CONFIG_HAS_HW_NRF_PWM2=y
    CONFIG_HAS_HW_NRF_PWM3=y
    CONFIG_HAS_HW_NRF_RTC0=y
    CONFIG_HAS_HW_NRF_RTC1=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM0=y
    CONFIG_HAS_HW_NRF_SPIM1=y
    CONFIG_HAS_HW_NRF_SPIM2=y
    CONFIG_HAS_HW_NRF_SPIM3=y
    CONFIG_HAS_HW_NRF_SPIS0=y
    CONFIG_HAS_HW_NRF_SPIS1=y
    CONFIG_HAS_HW_NRF_SPIS2=y
    CONFIG_HAS_HW_NRF_SPIS3=y
    CONFIG_HAS_HW_NRF_SPU=y
    CONFIG_HAS_HW_NRF_TIMER0=y
    CONFIG_HAS_HW_NRF_TIMER1=y
    CONFIG_HAS_HW_NRF_TIMER2=y
    CONFIG_HAS_HW_NRF_TWIM0=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_TWIM2=y
    CONFIG_HAS_HW_NRF_TWIM3=y
    CONFIG_HAS_HW_NRF_TWIS0=y
    CONFIG_HAS_HW_NRF_TWIS1=y
    CONFIG_HAS_HW_NRF_TWIS2=y
    CONFIG_HAS_HW_NRF_TWIS3=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_UARTE1=y
    CONFIG_HAS_HW_NRF_UARTE2=y
    CONFIG_HAS_HW_NRF_UARTE3=y
    CONFIG_HAS_HW_NRF_WDT=y
    CONFIG_NRF_ENABLE_ICACHE=y
    CONFIG_SOC_NRF9160=y
    CONFIG_SOC_NRF9160_SICA=y
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    # ARM Options
    CONFIG_CPU_CORTEX=y
    CONFIG_CPU_CORTEX_M=y
    CONFIG_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_NONSECURE_FIRMWARE=y
    # ARM TrustZone Options
    # Non-secure firmware
    CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS=y
    # end of ARM TrustZone Options
    CONFIG_FP_HARDABI=y
    # CONFIG_FP_SOFTABI is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    CONFIG_XIP=y
    # ARM Cortex-M0/M0+/M3/M4/M7/M23/M33 options
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # end of ARM Cortex-M0/M0+/M3/M4/M7/M23/M33 options
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_ARM_TRUSTZONE_M=y
    CONFIG_ARCH="arm"
    # end of ARM Options
    # CONFIG_ARC is not set
    CONFIG_ARM=y
    # CONFIG_X86 is not set
    # CONFIG_NIOS2 is not set
    # CONFIG_RISCV is not set
    # CONFIG_XTENSA is not set
    # CONFIG_ARCH_POSIX is not set
    # General Architecture Options
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    # CONFIG_USERSPACE is not set
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_PRIVILEGED_STACK_TEXT_AREA=256
    CONFIG_KOBJECT_TEXT_AREA=256
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=0
    CONFIG_GEN_IRQ_START_VECTOR=0
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MEMORY_PROTECTION=y
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_FP_SHARING=y
    # General Kernel Options
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=0
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    # CONFIG_INIT_STACKS is not set
    # CONFIG_KERNEL_DEBUG is not set
    CONFIG_BOOT_DELAY=0
    # CONFIG_EXECUTION_BENCHMARKING is not set
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # end of Kernel Debugging and Metrics
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    CONFIG_OFFLOAD_WORKQUEUE_STACK_SIZE=1024
    CONFIG_OFFLOAD_WORKQUEUE_PRIORITY=-1
    # end of Work Queue Options
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    CONFIG_POLL=y
    # end of Timer API Options
    # Other Kernel Object Options
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    CONFIG_NUM_PIPE_ASYNC_MSGS=10
    CONFIG_HEAP_MEM_POOL_MIN_SIZE=64
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # CONFIG_STACK_CANARIES is not set
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # end of SMP Options
    CONFIG_TICKLESS_IDLE=y
    CONFIG_TICKLESS_IDLE_THRESH=3
    CONFIG_TICKLESS_KERNEL=y
    # CONFIG_SYS_PM_STATE_LOCK is not set
    # CONFIG_SYS_PM_DIRECT_FORCE_MODE is not set
    # CONFIG_SYS_PM_DEBUG is not set
    # CONFIG_DEVICE_IDLE_PM is not set
    CONFIG_SYS_PM_POLICY_RESIDENCY=y
    # CONFIG_SYS_PM_POLICY_DUMMY is not set
    # CONFIG_SYS_PM_POLICY_APP is not set
    CONFIG_SYS_PM_MIN_RESIDENCY_DEEP_SLEEP_1=60000
    # end of General Kernel Options
    CONFIG_HAS_DTS=y
    CONFIG_HAS_DTS_GPIO=y
    CONFIG_HAS_DTS_I2C=y
    CONFIG_HAS_DTS_WDT=y
    # Device Drivers
    # CONFIG_IEEE802154 is not set
    # CONFIG_LORA is not set
    # CONFIG_CONSOLE is not set
    # CONFIG_NET_LOOPBACK is not set
    CONFIG_SERIAL=y
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # Serial Drivers
    # CONFIG_UART_NSIM is not set
    CONFIG_UART_NRFX=y
    CONFIG_UART_0_NRF_UARTE=y
    CONFIG_UART_0_INTERRUPT_DRIVEN=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    # CONFIG_UART_0_NRF_FLOW_CONTROL is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    CONFIG_UART_0_GPIO_MANAGEMENT=y
    CONFIG_UART_2_INTERRUPT_DRIVEN=y
    # CONFIG_UART_2_NRF_PARITY_BIT is not set
    # CONFIG_UART_2_NRF_FLOW_CONTROL is not set
    CONFIG_UART_2_NRF_TX_BUFFER_SIZE=32
    CONFIG_UART_2_GPIO_MANAGEMENT=y
    CONFIG_NRF_UARTE_PERIPHERAL=y
    # CONFIG_UART_ALTERA_JTAG is not set
    # CONFIG_UART_PL011 is not set
    # CONFIG_UART_RTT is not set
    # Interrupt Controllers
    # CONFIG_SWERV_PIC is not set
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    # end of Interrupt Controllers
    # Timer Drivers
    CONFIG_SYSTEM_CLOCK_DISABLE=y
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    # end of Timer Drivers
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_ENTROPY_NRF_FORCE_ALT=y
    CONFIG_ENTROPY_HAS_DRIVER=y
    CONFIG_ENTROPY_NAME="ENTROPY_0"
    # CONFIG_GPIO_SHELL is not set
    # CONFIG_GPIO_DW is not set
    # CONFIG_GPIO_PCAL9535A is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRF_INIT_PRIORITY=40
    CONFIG_GPIO_NRF_P0=y
    # CONFIG_GPIO_SX1509B is not set
    # CONFIG_GPIO_INTEL_APL is not set
    # CONFIG_SHARED_IRQ is not set
    # CONFIG_SPI_ASYNC is not set
    # CONFIG_SPI_SLAVE is not set
    CONFIG_SPI_INIT_PRIORITY=70
    # CONFIG_SPI_0 is not set
    # CONFIG_SPI_1 is not set
    # CONFIG_SPI_2 is not set
    CONFIG_SPI_3_OP_MODES=1
    # CONFIG_SPI_4 is not set
    # CONFIG_SPI_5 is not set
    # CONFIG_SPI_6 is not set
    # CONFIG_SPI_7 is not set
    # CONFIG_SPI_8 is not set
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_3_NRF_ORC=0xff
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=0
    # CONFIG_SPI_OC_SIMPLE is not set
    # CONFIG_I2C_SLAVE is not set
    # CONFIG_I2C_GPIO is not set
    CONFIG_I2C_NRFX=y
    # CONFIG_I2C_SBCON is not set
    # CONFIG_I2C_0 is not set
    CONFIG_I2C_1=y
    # CONFIG_I2C_3 is not set
    # CONFIG_I2C_4 is not set
    # CONFIG_I2C_5 is not set
    # CONFIG_I2C_6 is not set
    # CONFIG_I2C_7 is not set
    # CONFIG_I2S is not set
    # CONFIG_PWM is not set
    # CONFIG_PINMUX is not set
    # CONFIG_ADC is not set
    CONFIG_WDT_DISABLE_AT_BOOT=y
    CONFIG_WDT_NRFX=y
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_IPM is not set
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH=y
    CONFIG_SOC_FLASH_NRF=y
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    # CONFIG_SPI_NOR is not set
    # CONFIG_SPI_FLASH_W25QXXDV is not set
    # CONFIG_FLASH_SIMULATOR is not set
    # CONFIG_COUNTER is not set
    # CONFIG_DMA is not set
    # CONFIG_USB is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_WIFI is not set
    # CONFIG_LED is not set
    # CONFIG_CAN is not set
    # CONFIG_AUDIO is not set
    # CONFIG_NEURAL_NET_ACCEL is not set
    # CONFIG_HWINFO is not set
    # CONFIG_ESPI is not set
    # CONFIG_PS2 is not set
    # CONFIG_KSCAN is not set
    # CONFIG_VIDEO is not set
    # CONFIG_EEPROM is not set
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_NEWLIB_LIBC_NANO=y
    # CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
    # end of C Library
    # Additional libraries
    # CONFIG_LVGL is not set
    # OS Support Library
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    # CONFIG_BASE64 is not set
    # end of OS Support Library
    CONFIG_POSIX_MAX_FDS=4
    # CONFIG_POSIX_API is not set
    # CONFIG_PTHREAD_IPC is not set
    # CONFIG_POSIX_CLOCK is not set
    CONFIG_MAX_TIMER_COUNT=5
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_UPDATEHUB is not set
    # end of Additional libraries
    # CONFIG_BT is not set
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_CPLUSPLUS is not set
    # System Monitoring Options
    # CONFIG_BOOT_TIME_MEASUREMENT is not set
    # CONFIG_STATS is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_TRACING is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    # CONFIG_EARLY_CONSOLE is not set
    CONFIG_ASSERT=y
    CONFIG_ASSERT_LEVEL=2
    CONFIG_SPIN_VALIDATE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_OBJECT_TRACING is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_OPENOCD_SUPPORT is not set
    # CONFIG_TRACING_CPU_STATS is not set
    # CONFIG_TRACING_CTF is not set
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_SEGGER_SYSTEMVIEW is not set
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    # end of Debugging Options
    # CONFIG_DISK_ACCESS is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    CONFIG_NVS=y
    # end of File Systems
    # CONFIG_LOG is not set
    # Management
    # CONFIG_MCUMGR_SMP_BT is not set
    # CONFIG_MCUMGR_SMP_SHELL is not set
    # CONFIG_MCUMGR_SMP_UART is not set
    # CONFIG_MCUMGR is not set
    # end of Management
    # Networking
    CONFIG_NET_BUF=y
    CONFIG_NET_BUF_USER_DATA_SIZE=4
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_POOL_USAGE is not set
    CONFIG_NETWORKING=y
    # CONFIG_NET_HOSTNAME_ENABLE is not set
    # Link layer options
    # CONFIG_NET_L2_DUMMY is not set
    # CONFIG_NET_L2_BT_SHELL is not set
    # CONFIG_NET_L2_PPP is not set
    # CONFIG_NET_L2_CANBUS_RAW is not set
    # CONFIG_NET_L2_WIFI_MGMT is not set
    # CONFIG_NET_L2_WIFI_SHELL is not set
    # end of Link layer options
    # IP stack
    # CONFIG_NET_NATIVE is not set
    # CONFIG_NET_OFFLOAD is not set
    CONFIG_NET_INIT_PRIO=90
    CONFIG_NET_IF_MAX_IPV6_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=2
    CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=3
    CONFIG_NET_IF_IPV6_PREFIX_COUNT=2
    CONFIG_NET_INITIAL_HOP_LIMIT=64
    CONFIG_NET_IPV6_MAX_NEIGHBORS=8
    # CONFIG_NET_IPV6_FRAGMENT is not set
    CONFIG_NET_IPV6_MLD=y
    CONFIG_NET_IPV6_NBR_CACHE=y
    CONFIG_NET_IPV6_ND=y
    CONFIG_NET_IPV6_DAD=y
    CONFIG_NET_IPV6_RA_RDNSS=y
    # CONFIG_NET_6LO is not set
    CONFIG_NET_IPV6_LOG_LEVEL=0
    CONFIG_NET_ICMPV6_LOG_LEVEL=0
    CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL=0
    # CONFIG_NET_IPV4 is not set
    # CONFIG_NET_SHELL is not set
    CONFIG_NET_TC_TX_COUNT=1
    CONFIG_NET_TC_RX_COUNT=1
    CONFIG_NET_TC_MAPPING_STRICT=y
    CONFIG_NET_TX_DEFAULT_PRIORITY=1
    CONFIG_NET_RX_DEFAULT_PRIORITY=0
    CONFIG_NET_IP_ADDR_CHECK=y
    CONFIG_NET_MAX_ROUTERS=1
    CONFIG_NET_ROUTE=y
    CONFIG_NET_MAX_ROUTES=8
    CONFIG_NET_MAX_NEXTHOPS=8
    # CONFIG_NET_TCP is not set
    # CONFIG_NET_TEST_PROTOCOL is not set
    CONFIG_NET_UDP=y
    CONFIG_NET_UDP_CHECKSUM=y
    CONFIG_NET_UDP_LOG_LEVEL=0
    CONFIG_NET_MAX_CONN=4
    CONFIG_NET_MAX_CONTEXTS=6
    # CONFIG_NET_CONTEXT_NET_PKT_POOL is not set
    CONFIG_NET_CONTEXT_SYNC_RECV=y
    CONFIG_NET_CONTEXT_CHECK=y
    # CONFIG_NET_CONTEXT_PRIORITY is not set
    # CONFIG_NET_CONTEXT_TIMESTAMP is not set
    # CONFIG_NET_CONTEXT_TXTIME is not set
    # CONFIG_NET_TEST is not set
    # CONFIG_NET_TRICKLE is not set
    CONFIG_NET_PKT_RX_COUNT=4
    CONFIG_NET_PKT_TX_COUNT=4
    CONFIG_NET_BUF_RX_COUNT=16
    CONFIG_NET_BUF_TX_COUNT=16
    CONFIG_NET_BUF_FIXED_DATA_SIZE=y
    # CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set
    CONFIG_NET_BUF_DATA_SIZE=128
    CONFIG_NET_DEFAULT_IF_FIRST=y
    # CONFIG_NET_PKT_TIMESTAMP is not set
    # CONFIG_NET_PKT_TXTIME is not set
    # CONFIG_NET_PKT_RXTIME_STATS is not set
    # CONFIG_NET_PKT_TXTIME_STATS is not set
    # CONFIG_NET_PROMISCUOUS_MODE is not set
    # Stack usage
    CONFIG_NET_TX_STACK_SIZE=1200
    CONFIG_NET_RX_STACK_SIZE=1500
    # end of Stack usage
    # CONFIG_NET_MGMT is not set
    # CONFIG_NET_STATISTICS is not set
    # CONFIG_NET_LOG is not set
    CONFIG_NET_PKT_LOG_LEVEL=0
    # CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set
    CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0
    # CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set
    CONFIG_NET_CORE_LOG_LEVEL=0
    CONFIG_NET_IF_LOG_LEVEL=0
    CONFIG_NET_TC_LOG_LEVEL=0
    CONFIG_NET_UTILS_LOG_LEVEL=0
    CONFIG_NET_CONTEXT_LOG_LEVEL=0
    CONFIG_NET_CONN_LOG_LEVEL=0
    CONFIG_NET_ROUTE_LOG_LEVEL=0
    # end of IP stack
    # Network Protocols
    # CONFIG_COAP is not set
    # CONFIG_DNS_RESOLVER is not set
    CONFIG_MQTT_LIB=y
    CONFIG_MQTT_LOG_LEVEL=0
    # CONFIG_MQTT_LIB_TLS is not set
    # CONFIG_MQTT_LIB_WEBSOCKET is not set
    # CONFIG_HTTP_PARSER is not set
    # CONFIG_HTTP_PARSER_URL is not set
    # CONFIG_HTTP_CLIENT is not set
    CONFIG_NET_HTTP_LOG_LEVEL=0
    # CONFIG_WEBSOCKET_CLIENT is not set
    # CONFIG_LWM2M is not set
    # CONFIG_SOCKS is not set
    # CONFIG_SNTP is not set
    # end of Network Protocols
    # Network Libraries
    CONFIG_NET_CONFIG_AUTO_INIT=y
    CONFIG_NET_CONFIG_INIT_PRIO=95
    CONFIG_NET_CONFIG_INIT_TIMEOUT=30
    # CONFIG_NET_CONFIG_NEED_IPV6_ROUTER is not set
    # CONFIG_NET_CONFIG_NEED_IPV4 is not set
    CONFIG_NET_CONFIG_LOG_LEVEL=0
    # CONFIG_NET_CONFIG_SETTINGS is not set
    CONFIG_NET_SOCKETS_POLL_MAX=3
    CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000
    # CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set
    # CONFIG_NET_SOCKETS_CAN is not set
    CONFIG_NET_SOCKETS_LOG_LEVEL=0
    # CONFIG_TLS_CREDENTIALS is not set
    # end of Network Libraries
    # Network additional services
    # CONFIG_NET_CONNECTION_MANAGER is not set
    # end of Network additional services
    # end of Networking
    # CONFIG_SHELL is not set
    # CONFIG_IMG_MANAGER is not set
    # Random subsystem
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    # CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
    CONFIG_CSPRING_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # end of Random subsystem
    # Storage
    # CONFIG_FLASH_MAP is not set
    # end of Storage
    # CONFIG_SETTINGS is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_TEST is not set
    # CONFIG_TEST_SHELL is not set
    CONFIG_TEST_EXTRA_STACKSIZE=0
    # CONFIG_TEST_USERSPACE is not set
    CONFIG_TEST_ARM_CORTEX_M=y
    # end of Testing
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # CONFIG_JWT is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # External Sources
    # HALs
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # end of HALs
    # Cryptography
    # end of Cryptography
    # CONFIG_FNMATCH is not set
    # end of External Sources
    CONFIG_TOOLCHAIN_GNUARMEMB=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_USE_DT_CODE_PARTITION is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    # CONFIG_CUSTOM_RODATA_LD is not set
    # CONFIG_CUSTOM_RWDATA_LD is not set
    # CONFIG_CUSTOM_SECTIONS_LD is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # end of Linker Options
    # Compiler Options
    # CONFIG_NATIVE_APPLICATION is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    CONFIG_COMPILER_OPT=""
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    CONFIG_OUTPUT_DISASSEMBLY=y
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    CONFIG_BUILD_OUTPUT_BIN=y
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # end of Build Options
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    CONFIG_REBOOT=y
    # CONFIG_MISRA_SANE is not set
    # end of Boot Options
    # Compatibility
    CONFIG_COMPAT_INCLUDES=y
    # end of Compatibility
    # end of Zephyr Kernel
    OK, this is my build/zephyr/.config file. What I never understood was why the communication between the 9160 and the modem was related to UART0, even though I had turned off the log output.
    Thanks for the full .config. You're using UART0 for the at_host library
    Could you share logs / behavior on what happens when the issue occurs, so I can try to replicate it?
    Håkon
  • Unfortunately, I can't find the exact location of the crash so far, and it doesn't show up in the log, because it looks like I set uart0 to  DEVICE_PM_LOW_POWER_STATE;  By the way, do I have to go through UART0 to operate the modem?  Why can't I just call it like a function?
    You are using the at client interface, which uses UART_0 by default:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/nrf9160/at_client/README.html
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/modem/at_host.html#lib-at-host
    If you want to send and receive AT commands/responses in firmware, you can use the API directly:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfxlib/nrf_modem/doc/at_interface.html#sending-at-commands
    Or if you want to subscribe to a unsolicited notification, you can use the at monitor library:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/modem/at_monitor.html#at-monitor-readme
    Håkon
