Re-enable softdevice
Hi. I'm trying to enable and disable softdevice repeatedely. In my code, softdevice is firstly enabled then advertising properly. After some seconds, softdevice is disabled and ESB is enabled. It is worked properly too. and then esb is deisabled, softdevice is re-enabled and try to start advertising. But I found an error code when re-enabling softdevice.
in ble_stack_handler.c
err_code = sd_softdevice_enable(clock_source, softdevice_assertion_handler);
returns 0x00001001 at second enabling. (at first enabling, it returns NRF_SUCCESS)
I don't know how to solve the problem. please help.
  • I had exactly the same problem: when trying to re-enable my softdevice after running ESB the sd_softdevice_enable() function would return with the "NRF_ERROR_SDM_INCORRECT_INTERRUPT_CONFIGURATION" error code.
    The solution that worked for me was to disable the RADIO_IRQn interrupt in the nrf_esb_disable() function inside of the nrf_esb.c file.
    My modified nrf_esb_disable() function looks like this.
    uint32_t nrf_esb_disable(void)
        m_nrf_esb_mainstate = NRF_ESB_STATE_DISABLE;
        /* Disable RADIO first. */
        NRF_RADIO->INTENCLR        = 0xFFFFFFFF;
        NRF_RADIO->EVENTS_DISABLED = 0;
        NRF_RADIO->TASKS_DISABLE   = 1;
        while (NRF_RADIO->EVENTS_DISABLED == 0) ;
        // Clear PPI
        NRF_PPI->CHENCLR = (1 << NRF_ESB_PPI_TIMER_START) |
                           (1 << NRF_ESB_PPI_TIMER_STOP)  |
                           (1 << NRF_ESB_PPI_RX_TIMEOUT)  |
                           (1 << NRF_ESB_PPI_TX_START);
        m_nrf_esb_mainstate = NRF_ESB_STATE_IDLE;
        reset_fifos();
        memset(m_rx_pipe_info, 0, sizeof(m_rx_pipe_info));
        memset(m_pids, 0, sizeof(m_pids));
        // Disable the radio
        NVIC_DisableIRQ(ESB_EVT_IRQ);
        NRF_RADIO->SHORTS = RADIO_SHORTS_READY_START_Enabled << RADIO_SHORTS_READY_START_Pos |
                            RADIO_SHORTS_END_DISABLE_Enabled << RADIO_SHORTS_END_DISABLE_Pos;
        // EDIT JBR: return origional priorities - turns out to be unnecessary.
        NVIC_SetPriority(RADIO_IRQn, s_radio_irq_initial_priority);
        NVIC_SetPriority(ESB_EVT_IRQ, s_esb_irq_initial_priority);
        // EDIT JBR: disable the radio interrupt! this is the one that fixes it
        NVIC_DisableIRQ(RADIO_IRQn);
        return NRF_SUCCESS;
    I also reset the priorities for the interrupts back to the values that they were at before the nrf_esb_init() function changed them, but that proved to be unnecessary.
  • Please post when you have it. According to our example experimental_ble_app_gzll (in multiprotocol folder) where we switch between Gazel (similar to ESB) and BLE we do need to disable all the interrupt including the RADIO_IRQn, before we switch back to BLE. I think it makes sense to update the nrf_esb_disable() to disable RadioIRQn. I will check with the developer.
