New Event_submit Asset_tracker_V2 Issue
I adding an Event to Asset_Tracker_V2. I have created bms_module_evnet.h and bms_event.c files in events folder and bms_module.c. I have defined inclusion of these files in corresponding CMakeLists.TXT files.  I added the BMS related states, enumerated parameters etc in app_module_event.c and app_module_event.h file also. I have added code of bms part in app_event_handler function of main.c.
I wrote code to :
1. sent BMS Events in response to (IS_EVENT(msg, app, APP_EVT_START)), (IS_EVENT(msg, app, APP_EVT_CONFIG_GET)) ,  (IS_EVENT(msg, app, APP_EVT_DATA_GET)) Events generated by app_module. When, I run the program and observe the various Events. The APP_EVT_START event by event_manager is generated at initial stage. In response to it various other modules like UI, DATA, CLOUD, MODEM etc submit their events, but BMS event is not seen, while I have written the code to respond to APP_EVT_START event in on_state_init() function.
What may be the reason ? 1.  BMS_THREAD not initialized 2. module_get_next_msg(&self, &msg); function not getting any messages 3.   In the  on_state_init() function, Event is not detected or Event is not submitted. So, please explain me how to add an event.
The major files, where  I have added BMS code are in attachment. At last, the log file created by LTE_LINK_MONITOR is attached.
 * Copyright (c) 2021 Nordic Semiconductor ASA
#include <zephyr.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <app_event_manager.h>
#if defined(CONFIG_NRF_MODEM_LIB)
#include <modem/nrf_modem_lib.h>
#endif /* CONFIG_NRF_MODEM_LIB */
#include <sys/reboot.h>
#if defined(CONFIG_NRF_CLOUD_AGPS) || defined(CONFIG_NRF_CLOUD_PGPS)
#include <net/nrf_cloud_agps.h>
/* Module name is used by the Application Event Manager macros in this file */
#define MODULE main
#include <caf/events/module_state_event.h>
#include "modules_common.h"
#include "events/app_module_event.h"
#include "events/cloud_module_event.h"
#include "events/data_module_event.h"
#include "events/sensor_module_event.h"
#include "events/ui_module_event.h"
#include "events/util_module_event.h"
#include "events/modem_module_event.h"
#include "events/led_state_event.h"
#include "events/bms_module_event.h"
#include <logging/log.h>
#include <logging/log_ctrl.h>
LOG_MODULE_REGISTER(MODULE, CONFIG_APPLICATION_MODULE_LOG_LEVEL);
/* Message structure. Events from other modules are converted to messages
 * in the Application Event Manager handler, and then queued up in the message queue
 * for processing in the main thread.
struct app_msg_data {
	union {
		struct cloud_module_event cloud;
		struct ui_module_event ui;
		struct sensor_module_event sensor;
		struct data_module_event data;
		struct util_module_event util;
		struct modem_module_event modem;
		struct app_module_event app;
                struct bms_module_event bms;
	} module;
/* Application module super states. */
static enum state_type {
	STATE_INIT,
	STATE_RUNNING,
	STATE_SHUTDOWN
} state;
/* Application sub states. The application can be in either active or passive
 * mode.
 * Active mode: Sensor data and GNSS position is acquired at a configured
 *		interval and sent to cloud.
 * Passive mode: Sensor data and GNSS position is acquired when movement is
 *		 detected, or after the configured movement timeout occurs.
static enum sub_state_type {
	SUB_STATE_ACTIVE_MODE,
	SUB_STATE_PASSIVE_MODE,
} sub_state;
/* Internal copy of the device configuration. */
static struct cloud_data_cfg app_cfg;
/* Timer callback used to signal when timeout has occurred both in active
 * and passive mode.
static void data_sample_timer_handler(struct k_timer *timer);
/* Timer callback used to signal when the application is expecting movement to trigger the next
 * sample request.
static void waiting_for_movement_handler(struct k_timer *timer);
/* Application module message queue. */
#define APP_QUEUE_ENTRY_COUNT		10
#define APP_QUEUE_BYTE_ALIGNMENT	4
K_MSGQ_DEFINE(msgq_app, sizeof(struct app_msg_data), APP_QUEUE_ENTRY_COUNT,
	      APP_QUEUE_BYTE_ALIGNMENT);
/* Data sample timer used in active mode. */
K_TIMER_DEFINE(data_sample_timer, data_sample_timer_handler, NULL);
/* Movement timer used to detect movement timeouts in passive mode. */
K_TIMER_DEFINE(movement_timeout_timer, data_sample_timer_handler, NULL);
/* Movement resolution timer decides the period after movement that consecutive
 * movements are ignored and do not cause data collection. This is used to
 * lower power consumption by limiting how often GNSS search is performed and
 * data is sent on air.
K_TIMER_DEFINE(movement_resolution_timer, waiting_for_movement_handler, NULL);
/* Module data structure to hold information of the application module, which
 * opens up for using convenience functions available for modules.
static struct module_data self = {
	.name = "app",
	.msg_q = &msgq_app,
	.supports_shutdown = true,
/* Convenience functions used in internal state handling. */
static char *state2str(enum state_type new_state)
	switch (new_state) {
	case STATE_INIT:
		return "STATE_INIT";
	case STATE_RUNNING:
		return "STATE_RUNNING";
	case STATE_SHUTDOWN:
		return "STATE_SHUTDOWN";
		return "Unknown";
static char *sub_state2str(enum sub_state_type new_state)
	case SUB_STATE_ACTIVE_MODE:
		return "SUB_STATE_ACTIVE_MODE";
	case SUB_STATE_PASSIVE_MODE:
		return "SUB_STATE_PASSIVE_MODE";
		return "Unknown";
static void state_set(enum state_type new_state)
	if (new_state == state) {
		LOG_DBG("State: %s", state2str(state));
		return;
	LOG_DBG("State transition %s --> %s",
		state2str(state),
		state2str(new_state));
	state = new_state;
static void sub_state_set(enum sub_state_type new_state)
	if (new_state == sub_state) {
		LOG_DBG("Sub state: %s", sub_state2str(sub_state));
		return;
	LOG_DBG("Sub state transition %s --> %s",
		sub_state2str(sub_state),
		sub_state2str(new_state));
	sub_state = new_state;
/* Check the return code from nRF modem library initializaton to ensure that
 * the modem is rebooted if a modem firmware update is ready to be applied or
 * an error condition occurred during firmware update or library initialization.
static void handle_nrf_modem_lib_init_ret(void)
	int ret = nrf_modem_lib_get_init_ret();
	/* Handle return values relating to modem firmware update */
	switch (ret) {
	case 0:
		/* Initialization successful, no action required. */
		return;
	case MODEM_DFU_RESULT_OK:
		LOG_INF("MODEM UPDATE OK. Will run new firmware after reboot");
	case MODEM_DFU_RESULT_UUID_ERROR:
	case MODEM_DFU_RESULT_AUTH_ERROR:
		LOG_ERR("MODEM UPDATE ERROR %d. Will run old firmware", ret);
	case MODEM_DFU_RESULT_HARDWARE_ERROR:
	case MODEM_DFU_RESULT_INTERNAL_ERROR:
		LOG_ERR("MODEM UPDATE FATAL ERROR %d. Modem failure", ret);
		/* All non-zero return codes other than DFU result codes are
		 * considered irrecoverable and a reboot is needed.
		LOG_ERR("nRF modem lib initialization failed, error: %d", ret);
	LOG_WRN("Rebooting...");
	LOG_PANIC();
	sys_reboot(SYS_REBOOT_COLD);
/* Application Event Manager handler. Puts event data into messages and adds them to the
 * application message queue.
static bool app_event_handler(const struct app_event_header *aeh)
	struct app_msg_data msg = {0};
	bool enqueue_msg = false;
	if (is_cloud_module_event(aeh)) {
		struct cloud_module_event *evt = cast_cloud_module_event(aeh);
		msg.module.cloud = *evt;
		enqueue_msg = true;
	if (is_app_module_event(aeh)) {
		struct app_module_event *evt = cast_app_module_event(aeh);
		msg.module.app = *evt;
		enqueue_msg = true;
	if (is_data_module_event(aeh)) {
		struct data_module_event *evt = cast_data_module_event(aeh);
		msg.module.data = *evt;
		enqueue_msg = true;
	if (is_sensor_module_event(aeh)) {
		struct sensor_module_event *evt = cast_sensor_module_event(aeh);
		msg.module.sensor = *evt;
		enqueue_msg = true;
	if (is_util_module_event(aeh)) {
		struct util_module_event *evt = cast_util_module_event(aeh);
		msg.module.util = *evt;
		enqueue_msg = true;
	if (is_modem_module_event(aeh)) {
		struct modem_module_event *evt = cast_modem_module_event(aeh);
		msg.module.modem = *evt;
		enqueue_msg = true;
	if (is_ui_module_event(aeh)) {
		struct ui_module_event *evt = cast_ui_module_event(aeh);
		msg.module.ui = *evt;
		enqueue_msg = true;
        if (is_bms_module_event(aeh)) {
		struct bms_module_event *evt = cast_bms_module_event(aeh);
		msg.module.bms = *evt;
		enqueue_msg = true;
	if (enqueue_msg) {
		int err = module_enqueue_msg(&self, &msg);
		if (err) {
			LOG_ERR("Message could not be enqueued");
			SEND_ERROR(app, APP_EVT_ERROR, err);
	return false;
static bool is_agps_processed(void)
	struct nrf_modem_gnss_agps_data_frame processed;
	nrf_cloud_agps_processed(&processed);
	if (!processed.sv_mask_ephe) {
		return false;
#endif /* CONFIG_NRF_CLOUD_AGPS || CONFIG_NRF_CLOUD_PGPS */
	return true;
static bool request_gnss(void)
	uint32_t uptime_current_ms = k_uptime_get();
	int agps_wait_threshold_ms = CONFIG_APP_REQUEST_GNSS_WAIT_FOR_AGPS_THRESHOLD_SEC *
				     MSEC_PER_SEC;
	if (!IS_ENABLED(CONFIG_APP_REQUEST_GNSS_WAIT_FOR_AGPS)) {
		return true;
	} else if (agps_wait_threshold_ms < 0) {
		/* If CONFIG_APP_REQUEST_GNSS_WAIT_FOR_AGPS_THRESHOLD_SEC is set to -1,
		 * we need to notify the data module that the application module is awaiting
		 * A-GPS data in order to request GNSS. If not, GNSS will never be
		 * requested if the initial A-GPS data request fails.
		if (is_agps_processed()) {
			return true;
		SEND_EVENT(app, APP_EVT_AGPS_NEEDED);
		return false;
	} else if ((agps_wait_threshold_ms < uptime_current_ms) || is_agps_processed()) {
		return true;
	return false;
	ARG_UNUSED(timer);
	SEND_EVENT(app, APP_EVT_DATA_GET_ALL);
	ARG_UNUSED(timer);
	SEND_EVENT(app, APP_EVT_ACTIVITY_DETECTION_ENABLE);
/* Static module functions. */
static void passive_mode_timers_start_all(void)
	LOG_DBG("Device mode: Passive");
	LOG_DBG("Start movement timeout: %d seconds interval", app_cfg.movement_timeout);
	LOG_DBG("%d seconds until movement can trigger a new data sample/publication",
		app_cfg.movement_resolution);
	k_timer_start(&movement_resolution_timer,
		      K_SECONDS(app_cfg.movement_resolution),
		      K_SECONDS(0));
	k_timer_start(&movement_timeout_timer,
		      K_SECONDS(app_cfg.movement_timeout),
		      K_SECONDS(app_cfg.movement_timeout));
	k_timer_stop(&data_sample_timer);
static void active_mode_timers_start_all(void)
	LOG_DBG("Device mode: Active");
	LOG_DBG("Start data sample timer: %d seconds interval", app_cfg.active_wait_timeout);
	k_timer_start(&data_sample_timer,
		      K_SECONDS(app_cfg.active_wait_timeout),
		      K_SECONDS(app_cfg.active_wait_timeout));
	k_timer_stop(&movement_resolution_timer);
	k_timer_stop(&movement_timeout_timer);
	SEND_EVENT(app, APP_EVT_ACTIVITY_DETECTION_DISABLE);
static void data_get(void)
	static bool first = true;
	struct app_module_event *app_module_event = new_app_module_event();
	size_t count = 0;
	/* Set a low sample timeout. If GNSS is requested, the sample timeout will be increased to
	 * accommodate the GNSS timeout.
	app_module_event->timeout = 1;
	/* Specify which data that is to be included in the transmission. */
	app_module_event->data_list[count++] = APP_DATA_MODEM_DYNAMIC;
	app_module_event->data_list[count++] = APP_DATA_BATTERY;
	app_module_event->data_list[count++] = APP_DATA_ENVIRONMENTAL;
	if (IS_ENABLED(CONFIG_APP_REQUEST_NEIGHBOR_CELLS_DATA) && !app_cfg.no_data.neighbor_cell) {
		app_module_event->data_list[count++] = APP_DATA_NEIGHBOR_CELLS;
	/* The reason for having at least 75 seconds sample timeout when
	 * requesting GNSS data is that the GNSS module on the nRF9160 modem will always
	 * search for at least 60 seconds for the first position fix after a reboot. This limit
	 * is enforced in order to give the modem time to perform scheduled downloads of
	 * A-GPS data from the GNSS satellites.
	 * However, if A-GPS data has been downloaded via the cloud connection and processed
	 * before the initial GNSS search, the actual GNSS timeout set by the application is used.
	 * Processing A-GPS before requesting GNSS data is enabled by default,
	 * and the time that the application will wait for A-GPS data before including GNSS
	 * in sample requests can be adjusted via the
	 * CONFIG_APP_REQUEST_GNSS_WAIT_FOR_AGPS_THRESHOLD_SEC Kconfig option. If this option is
	 * set to -1, the application module will not request GNSS unless A-GPS data has been
	 * processed.
	 * If A-GPS data has been processed the sample timeout can be ignored as the
	 * GNSS will most likely time out before the sample timeout expires.
	 * When GNSS is requested, set the sample timeout to (GNSS timeout + 15 seconds)
	 * to let the GNSS module finish ongoing searches before data is sent to cloud.
	if (first) {
		if (IS_ENABLED(CONFIG_APP_REQUEST_GNSS_ON_INITIAL_SAMPLING) && request_gnss() &&
		    !app_cfg.no_data.gnss) {
			app_module_event->data_list[count++] = APP_DATA_GNSS;
			app_module_event->timeout = MAX(app_cfg.gnss_timeout + 15, 75);
		app_module_event->data_list[count++] = APP_DATA_MODEM_STATIC;
		first = false;
	} else {
		if (request_gnss() && !app_cfg.no_data.gnss) {
        app_module_event->data_list[count++] = APP_DATA_BMS;
	/* Set list count to number of data types passed in app_module_event. */
	app_module_event->count = count;
	app_module_event->type = APP_EVT_DATA_GET;
	APP_EVENT_SUBMIT(app_module_event);
/* Message handler for STATE_INIT. */
static void on_state_init(struct app_msg_data *msg)
	if (IS_EVENT(msg, data, DATA_EVT_CONFIG_INIT)) {
		/* Keep a copy of the new configuration. */
		app_cfg = msg->module.data.data.cfg;
		if (app_cfg.active_mode) {
			active_mode_timers_start_all();
		} else {
			passive_mode_timers_start_all();
		state_set(STATE_RUNNING);
		sub_state_set(app_cfg.active_mode ? SUB_STATE_ACTIVE_MODE :
						    SUB_STATE_PASSIVE_MODE);
/* Message handler for STATE_RUNNING. */
static void on_state_running(struct app_msg_data *msg)
	if (IS_EVENT(msg, cloud, CLOUD_EVT_CONNECTED)) {
		data_get();
	if (IS_EVENT(msg, app, APP_EVT_DATA_GET_ALL)) {
		data_get();
/* Message handler for SUB_STATE_PASSIVE_MODE. */
void on_sub_state_passive(struct app_msg_data *msg)
	if (IS_EVENT(msg, data, DATA_EVT_CONFIG_READY)) {
			sub_state_set(SUB_STATE_ACTIVE_MODE);
			return;
	if ((IS_EVENT(msg, ui, UI_EVT_BUTTON_DATA_READY)) ||
	    (IS_EVENT(msg, sensor, SENSOR_EVT_MOVEMENT_DATA_READY))) {
		if (IS_EVENT(msg, ui, UI_EVT_BUTTON_DATA_READY) &&
		    msg->module.ui.data.ui.button_number != 2) {
			return;
		/* Trigger a sample request if button 2 has been pushed on the DK or activity has
		 * been detected. The data request can only be triggered if the movement
		 * resolution timer has timed out.
		if (k_timer_remaining_get(&movement_resolution_timer) == 0) {
			data_sample_timer_handler(NULL);
/* Message handler for SUB_STATE_ACTIVE_MODE. */
static void on_sub_state_active(struct app_msg_data *msg)
		if (!app_cfg.active_mode) {
			sub_state_set(SUB_STATE_PASSIVE_MODE);
			return;
/* Message handler for all states. */
static void on_all_events(struct app_msg_data *msg)
	if (IS_EVENT(msg, util, UTIL_EVT_SHUTDOWN_REQUEST)) {
		SEND_SHUTDOWN_ACK(app, APP_EVT_SHUTDOWN_READY, self.id);
		state_set(STATE_SHUTDOWN);
void main(void)
	int err;
	struct app_msg_data msg;
	if (!IS_ENABLED(CONFIG_LWM2M_CARRIER) && !IS_ENABLED(CONFIG_NRF_CLOUD_FOTA)) {
		handle_nrf_modem_lib_init_ret();
	if (app_event_manager_init()) {
		/* Without the Application Event Manager, the application will not work
		 * as intended. A reboot is required in an attempt to recover.
		LOG_ERR("Application Event Manager could not be initialized, rebooting...");
		k_sleep(K_SECONDS(5));
	} else {
		module_set_state(MODULE_STATE_READY);
		SEND_EVENT(app, APP_EVT_START);
	self.thread_id = k_current_get();
	err = module_start(&self);
	if (err) {
		LOG_ERR("Failed starting module, error: %d", err);
	while (true) {
		switch (state) {
		case STATE_INIT:
			on_state_init(&msg);
		case STATE_RUNNING:
			switch (sub_state) {
				on_sub_state_active(&msg);
				on_sub_state_passive(&msg);
				LOG_WRN("Unknown application sub state");
			on_state_running(&msg);
			/* The shutdown state has no transition. */
			LOG_WRN("Unknown application state");
		on_all_events(&msg);
APP_EVENT_LISTENER(MODULE, app_event_handler);
APP_EVENT_SUBSCRIBE_EARLY(MODULE, cloud_module_event);
APP_EVENT_SUBSCRIBE(MODULE, app_module_event);
APP_EVENT_SUBSCRIBE(MODULE, data_module_event);
APP_EVENT_SUBSCRIBE(MODULE, util_module_event);
APP_EVENT_SUBSCRIBE_FINAL(MODULE, ui_module_event);
APP_EVENT_SUBSCRIBE_FINAL(MODULE, sensor_module_event);
APP_EVENT_SUBSCRIBE_FINAL(MODULE, modem_module_event);
APP_EVENT_SUBSCRIBE_EARLY(MODULE, bms_module_event);
#include <stdio.h>
#include "app_module_event.h"
#include "common_module_event.h"
static char *type2str(enum app_module_data_type type)
	switch (type) {
	case APP_DATA_ENVIRONMENTAL:
		return "ENV";
	case APP_DATA_MOVEMENT:
		return "MOVE";
	case APP_DATA_MODEM_STATIC:
		return "MOD_STAT";
	case APP_DATA_MODEM_DYNAMIC:
		return "MOD_DYN";
	case APP_DATA_BATTERY:
		return "BAT";
	case APP_DATA_GNSS:
		return "GNSS";
	case APP_DATA_NEIGHBOR_CELLS:
		return "NEIGHBOR_CELLS";
        case APP_DATA_BMS:
                return "BMS_DATA";
		return "Unknown type";
static char *get_evt_type_str(enum app_module_event_type type)
	switch (type) {
	case APP_EVT_DATA_GET:
		return "APP_EVT_DATA_GET";
	case APP_EVT_CONFIG_GET:
		return "APP_EVT_CONFIG_GET";
	case APP_EVT_ACTIVITY_DETECTION_ENABLE:
		return "APP_EVT_ACTIVITY_DETECTION_ENABLE";
	case APP_EVT_ACTIVITY_DETECTION_DISABLE:
		return "APP_EVT_ACTIVITY_DETECTION_DISABLE";
	case APP_EVT_AGPS_NEEDED:
		return "APP_EVT_AGPS_NEEDED";
	case APP_EVT_DATA_GET_ALL:
		return "APP_EVT_DATA_GET_ALL";
	case APP_EVT_START:
		return "APP_EVT_START";
	case APP_EVT_LTE_CONNECT:
		return "APP_EVT_LTE_CONNECT";
	case APP_EVT_LTE_DISCONNECT:
		return "APP_EVT_LTE_DISCONNECT";
	case APP_EVT_SHUTDOWN_READY:
		return "APP_EVT_SHUTDOWN_READY";
	case APP_EVT_ERROR:
		return "APP_EVT_ERROR";
		return "Unknown event";
static void log_event(const struct app_event_header *aeh)
	const struct app_module_event *event = cast_app_module_event(aeh);
	char data_types[50] = "\0";
	if (event->type == APP_EVT_ERROR) {
		APP_EVENT_MANAGER_LOG(aeh, "%s - Error code %d",
				get_evt_type_str(event->type), event->data.err);
	} else if (event->type == APP_EVT_DATA_GET) {
		for (int i = 0; i < event->count; i++) {
			strcat(data_types, type2str(event->data_list[i]));
			if (i == event->count - 1) {
			strcat(data_types, ", ");
		APP_EVENT_MANAGER_LOG(aeh, "%s - Requested data types (%s)",
				get_evt_type_str(event->type), log_strdup(data_types));
	} else {
		APP_EVENT_MANAGER_LOG(aeh, "%s", get_evt_type_str(event->type));
#if defined(CONFIG_PROFILER)
static void profile_event(struct log_event_buf *buf,
#if defined(CONFIG_PROFILER_EVENT_TYPE_STRING)
	profiler_log_encode_string(buf, get_evt_type_str(event->type));
#else
	profiler_log_encode_uint8(buf, event->type);
COMMON_APP_EVENT_INFO_DEFINE(app_module_event,
			 profile_event);
#endif /* CONFIG_PROFILER */
COMMON_APP_EVENT_TYPE_DEFINE(app_module_event,
			 log_event,
			 &app_module_event_info,
			 APP_EVENT_FLAGS_CREATE(
				IF_ENABLED(CONFIG_APP_EVENTS_LOG,
					(APP_EVENT_TYPE_FLAGS_INIT_LOG_ENABLE))));
0447.app_module_event.h
#include <stdio.h>
#include "bms_module_event.h"
static char *get_evt_type_str(enum bms_module_event_type type)
	switch (type) {
        case BMS_PIN_SUCCESS:return "BMS_PIN_HARDWARE_CONFIGURATION_OK";
        case BMS_PIN_FAIL: return "BS_PIN_HARDWARE_CONFIGURATION_FAIL";
        case BMS_DETACHED: return "BMS_REMOVED";
	case BMS_ATTACHED:
		return "BMS_ATTACHED";
	case BMS_DATA_ERROR:
		return "BMS_EVT_ERROR";
        case BMS_DATA_READY:
                return "BMS_DATA_READY";
		return "Unknown BMS event";
static void log_event(const struct app_event_header *eh)
	const struct bms_module_event *event = cast_bms_module_event(eh);
	char event_name[50] = "\0";
	strcpy(event_name, get_evt_type_str(event->type));
	if (event->type == BMS_DATA_ERROR) {
	} else if (event->type == BMS_DATA_READY) {
        else if (event->type == BMS_ATTACHED) {
	const struct bms_module_event *event = cast_bms_module_event(aeh);
#else
COMMON_APP_EVENT_INFO_DEFINE(bms_module_event,
			 profile_event);
COMMON_APP_EVENT_TYPE_DEFINE(bms_module_event,
			 log_event,
			 &bms_module_event_info,
				IF_ENABLED(CONFIG_BMS_EVENTS_LOG,
0451.bms_module_event.h
LOG_MODULE_REGISTER(bms_module, CONFIG_BMS_MODULE_LOG_LEVEL);
struct bms_msg_data {
	union {
	} module;
/* BMS module super states. */
	BMS_INIT,
        BMS_DETECT,
	BMS_RUNNING,
} state;
/* Bms module message queue. */
#define BMS_QUEUE_ENTRY_COUNT	10
#define BMS_QUEUE_BYTE_ALIGNMENT 4
K_MSGQ_DEFINE(msgq_bms, sizeof(struct bms_msg_data),
	      BMS_QUEUE_ENTRY_COUNT, BMS_QUEUE_BYTE_ALIGNMENT);
	.name = "bms_DALY",
	.msg_q = &msgq_bms,
	case BMS_INIT:
        case BMS_DETECT:
              return "BMS DETECTED";
	case BMS_RUNNING:
		return "Unknown";
		return;
		state2str(state),
	state = new_state;
/* Handlers */
static bool app_event_handler(const struct app_event_header *eh)
  struct bms_msg_data msg = {0};
	if (is_app_module_event(eh)) {
		struct app_module_event *event = cast_app_module_event(eh);
		msg.module.app = *event;
		enqueue_msg = true;
	if (enqueue_msg) {
		if (err) {
			SEND_ERROR(bms, BMS_DATA_ERROR, err);
	return false;
static void on_state_init(struct bms_msg_data *msg)
{   int ret;
    struct bms_module_event *bms_init_event = new_bms_module_event();
    if (IS_EVENT(msg, app, APP_EVT_START)){
    // my code here
    if((detect_pin_flag == true)&&(reset_pin_flag == true)){bms_init_event->type=BMS_PIN_SUCCESS;state_set(BMS_DETECT);}
        else{bms_init_event->type=BMS_PIN_FAIL;}
    EVENT_SUBMIT(bms_init_event);
static void detect_bms(struct bms_msg_data *msg)
  struct bms_module_event *bms_detect_event = new_bms_module_event();
    if(IS_EVENT(msg, app, APP_EVT_CONFIG_GET))
  // my code
  if(....)bms_detect_event->type = BMS_ATTACHED;
  else{bms_detect_event->type = BMS_DETACHED;}
  EVENT_SUBMIT(bms_detect_event);
static void on_state_running(struct bms_msg_data *msg)
  struct bms_module_event *bms_run_event = new_bms_module_event();
   if (IS_EVENT(msg, app, APP_EVT_DATA_GET)){
     // my code
     bms_run_event->type = BMS_DATA_READY;
   EVENT_SUBMIT(bms_run_event);
static void module_thread_fn(void)
        int err;
	struct bms_msg_data msg;
	if (err) {
        LOG_DBG("BMS Thread Started: %d", err);
        while (true) {
                LOG_WRN("New Message in BMS Thread");
          switch (state) {
		case BMS_INIT:
                case BMS_DETECT:
                        detect_bms(&msg);
		case BMS_RUNNING:
			LOG_WRN("Unknown BMS module state.");
K_THREAD_DEFINE(bms_module_thread, CONFIG_BMS_THREAD_STACK_SIZE,
		module_thread_fn, NULL, NULL, NULL,
		K_LOWEST_APPLICATION_THREAD_PRIO, 0, 0);
2022-04-26T14:23:59.494Z DEBUG Application data folder: C:\Users\Andrew.McComas\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
2022-04-26T14:23:59.564Z DEBUG App pc-nrfconnect-linkmonitor v2.0.1 official
2022-04-26T14:23:59.564Z DEBUG App path: C:\Users\Andrew.McComas\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
2022-04-26T14:23:59.564Z DEBUG nRFConnect 3.11.0, required by the app is (^3.8.0)
2022-04-26T14:23:59.564Z DEBUG nRFConnect path: C:\Users\Andrew.McComas\AppData\Local\Programs\nrfconnect\resources\app.asar
2022-04-26T14:23:59.564Z DEBUG HomeDir: C:\Users\Andrew.McComas
2022-04-26T14:23:59.564Z DEBUG TmpDir: C:\Users\ANDREW~1.MCC\AppData\Local\Temp
2022-04-26T14:23:59.566Z INFO Using nrf-device-lib-js version: 0.4.5
2022-04-26T14:23:59.567Z INFO Using nrf-device-lib version: 0.11.0
2022-04-26T14:23:59.567Z INFO Using nrfjprog DLL version: 10.15.1
2022-04-26T14:23:59.567Z INFO Using JLink version: JLink_V7.58b
2022-04-26T14:24:03.578Z INFO Modem port is opened
2022-04-26T14:24:13.951Z DEBUG modem << ing Zephyr OS build v2.7.99-ncs1-2195-g186cf4539e5a  ***
2022-04-26T14:24:13.969Z DEBUG modem << I: Starting bootloader
2022-04-26T14:24:13.973Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
2022-04-26T14:24:13.975Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
2022-04-26T14:24:13.976Z DEBUG modem << I: Boot source: none
2022-04-26T14:24:13.980Z DEBUG modem << I: Swap type: none
2022-04-26T14:24:14.059Z DEBUG modem << I: Bootloader chainload address offset: 0x10000
2022-04-26T14:24:14.065Z DEBUG modem << I: Jumping to the first image slot
2022-04-26T14:24:14.542Z DEBUG modem << *** Booting Zephyr OS build v2.7.99-ncs1-2195-g186cf4539e5a  ***
2022-04-26T14:24:14.554Z DEBUG modem << [00:00:00.207,611] [0m<dbg> watchdog: watchdog_timeout_install: Watchdog timeout installed. Timeout: 60[0m
2022-04-26T14:24:14.559Z DEBUG modem << [00:00:00.217,163] [0m<dbg> watchdog: watchdog_start: Watchdog started[0m
2022-04-26T14:24:14.566Z DEBUG modem << [00:00:00.223,907] [0m<dbg> watchdog: watchdog_feed_enable: Watchdog feed enabled. Timeout: 30000[0m
2022-04-26T14:24:14.597Z DEBUG modem << [00:00:00.233,337] [0m<inf> app_event_manager: APP_EVT_START[0m
2022-04-26T14:24:14.599Z DEBUG modem << [00:00:00.239,227] [0m<dbg> gnss_module: state_set: State: STATE_INIT[0m
2022-04-26T14:24:14.603Z DEBUG modem << [00:00:00.245,910] [0m<dbg> ui_module: state_set: State transition STATE_INIT --> STATE_RUNNING[0m
2022-04-26T14:24:14.604Z DEBUG modem << [00:00:00.254,760] [0m<dbg> ui_module: sub_state_set: Sub state: SUB_STATE_ACTIVE[0m
2022-04-26T14:24:14.610Z DEBUG modem << [00:00:00.262,451] [0m<dbg> ui_module: sub_sub_state_set: Sub state: SUB_SUB_STATE_GNSS_INACTIVE[0m
2022-04-26T14:24:14.625Z DEBUG modem << [00:00:00.271,484] [0m<dbg> util_module: state_set: State: STATE_INIT[0m
2022-04-26T14:24:14.627Z DEBUG modem << [00:00:00.278,717] [1;31m<err> os: ***** USAGE FAULT *****[0m
2022-04-26T14:24:14.629Z DEBUG modem << [00:00:00.284,332] [1;31m<err> os:   Stack overflow (context area not valid)[0m
2022-04-26T14:24:14.640Z DEBUG modem << [00:00:00.291,595] [1;31m<err> os: r0/a1:  0x0c060050  r1/a2:  0xfb7f9ff7  r2/a3:  0x0e00d620[0m
2022-04-26T14:24:14.643Z DEBUG modem << [00:00:00.300,323] [1;31m<err> os: r3/a4:  0x5df7ffff r12/ip:  0x000214ee r14/lr:  0x61000200[0m
2022-04-26T14:24:14.647Z DEBUG modem << [00:00:00.309,020] [1;31m<err> os:  xpsr:  0x00000000[0m
2022-04-26T14:24:14.659Z DEBUG modem << [00:00:00.314,300] [1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000[0m
2022-04-26T14:24:14.671Z DEBUG modem << [00:00:00.324,768] [1;31m<err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000[0m
2022-04-26T14:24:14.679Z DEBUG modem << [00:00:00.335,235] [1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000[0m
2022-04-26T14:24:14.690Z DEBUG modem << [00:00:00.345,733] [1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000[0m
2022-04-26T14:24:14.695Z DEBUG modem << [00:00:00.356,170] [1;31m<err> os: fpscr:  0x01c10400[0m
2022-04-26T14:24:14.705Z DEBUG modem << [00:00:00.361,389] [1;31m<err> os: Faulting instruction address (r15/pc): 0x00000000[0m
2022-04-26T14:24:14.712Z DEBUG modem << [00:00:00.369,354] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0[0m
2022-04-26T14:24:14.724Z DEBUG modem << [00:00:00.377,288] [1;31m<err> os: Current thread: 0x2000d2b0 (unknown)[0m
2022-04-26T14:24:14.727Z DEBUG modem << [00:00:00.384,155] [0m<dbg> util_module: state_set: State transition STATE_INIT --> STATE_REBOOT_PENDING[0m
2022-04-26T14:24:14.737Z DEBUG modem << [00:00:00.393,829] [0m<inf> app_event_manager: UTIL_EVT_SHUTDOWN_REQUEST[0m
2022-04-26T14:24:14.743Z DEBUG modem << [00:00:00.400,848] [0m<dbg> ui_module: state_set: State transition STATE_RUNNING --> STATE_SHUTDOWN[0m
2022-04-26T14:24:14.755Z DEBUG modem << [00:00:00.410,278] [0m<dbg> gnss_module: state_set: State transition STATE_INIT --> STATE_SHUTDOWN[0m
2022-04-26T14:24:14.759Z DEBUG modem << [00:00:00.419,647] [0m<inf> app_event_manager: UI_EVT_SHUTDOWN_READY[0m
2022-04-26T14:24:14.772Z DEBUG modem << [00:00:00.426,269] [1;33m<wrn> modules_common: Module "ui" shutdown registered[0m
2022-04-26T14:24:14.775Z DEBUG modem << [00:00:00.433,807] [0m<inf> app_event_manager: GNSS_EVT_SHUTDOWN_READY[0m
2022-04-26T14:24:14.781Z DEBUG modem << [00:00:00.440,673] [1;33m<wrn> modules_common: Module "gnss" shutdown registered[0m
2022-04-26T14:24:14.789Z DEBUG modem << [00:00:00.448,822] [0m<inf> app_event_manager: APP_EVT_SHUTDOWN_READY[0m
2022-04-26T14:24:14.797Z DEBUG modem << [00:00:00.455,566] [1;33m<wrn> modules_common: Module "app" shutdown registered[0m
2022-04-26T14:24:14.805Z DEBUG modem << [00:00:00.463,531] [0m<dbg> main: state_set: State transition STATE_INIT --> STATE_SHUTDOWN[0m
2022-04-26T14:24:14.812Z DEBUG modem << [00:00:00.472,137] [0m<dbg> cloud_module: state_set: State: STATE_LTE_INIT[0m
2022-04-26T14:24:14.821Z DEBUG modem << [00:00:00.479,217] [0m<dbg> cloud_module: sub_state_set: Sub state: SUB_STATE_CLOUD_DISCONNECTED[0m
2022-04-26T14:24:14.828Z DEBUG modem << [00:00:00.488,403] [0m<inf> app_event_manager: CLOUD_EVT_SHUTDOWN_READY[0m
2022-04-26T14:24:14.839Z DEBUG modem << [00:00:00.495,422] [1;33m<wrn> modules_common: Module "cloud" shutdown registered[0m
2022-04-26T14:24:14.844Z DEBUG modem << [00:00:00.503,387] [0m<dbg> data_module: state_set: State: STATE_CLOUD_DISCONNECTED[0m
2022-04-26T14:24:14.855Z DEBUG modem << [00:00:00.511,444] [0m<dbg> date_time: date_time_core_register_handler: Registering handler 0x47913[0m
2022-04-26T14:24:14.861Z DEBUG modem << [00:00:00.520,721] [0m<dbg> data_module: config_print_all: Device mode: Active[0m
2022-04-26T14:24:14.871Z DEBUG modem << [00:00:00.528,167] [0m<dbg> data_module: config_print_all: Active wait timeout: 120[0m
2022-04-26T14:24:14.878Z DEBUG modem << [00:00:00.536,102] [0m<dbg> data_module: config_print_all: Movement resolution: 120[0m
2022-04-26T14:24:14.888Z DEBUG modem << [00:00:00.544,036] [0m<dbg> data_module: config_print_all: Movement timeout: 3600[0m
2022-04-26T14:24:14.892Z DEBUG modem << [00:00:00.551,696] [0m<dbg> data_module: config_print_all: GPS timeout: 60[0m
2022-04-26T14:24:14.909Z DEBUG modem << [00:00:00.558,837] [0m<dbg> data_module: config_print_all: Accelerometer threshold: 10.00[0m
2022-04-26T14:24:14.912Z DEBUG modem << [00:00:00.567,291] [0m<dbg> data_module: config_print_all: Requesting of neighbor cell data is enabled[0m
2022-04-26T14:24:14.922Z DEBUG modem << [00:00:00.576,873] [0m<dbg> data_module: config_print_all: Requesting of GNSS data is enabled[0m
2022-04-26T14:24:14.925Z DEBUG modem << [00:00:00.585,693] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
2022-04-26T14:24:14.933Z DEBUG modem << [00:00:00.592,163] [0m<dbg> ui_module: sub_state_set: Sub state: SUB_STATE_ACTIVE[0m
2022-04-26T14:24:14.944Z DEBUG modem << [00:00:00.600,311] [0m<dbg> modem_module: state_set: State transition STATE_INIT --> STATE_DISCONNECTED[0m
2022-04-26T14:24:14.954Z DEBUG modem << [00:00:00.609,893] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
2022-04-26T14:24:14.960Z DEBUG modem << [00:00:00.616,851] [0m<dbg> gnss_module: lna_configure: MAGPIO command: AT%XMAGPIO=1,0,0,1,1,1574,1577[0m
2022-04-26T14:24:14.974Z DEBUG modem << [00:00:00.626,312] [0m<dbg> gnss_module: lna_configure: COEX0 command: AT%XCOEX0=1,1,1565,1586[0m
2022-04-26T14:24:14.989Z DEBUG modem << [00:00:00.635,284] [0m<dbg> sensor_module: state_set: State: STATE_INIT[0m[00:00:00.642,242] [0m<dbg> gnss_module: state_set: State transition STATE_SHUTDOWN --> STATE_RUNNING[0m
2022-04-26T14:24:14.992Z DEBUG modem << [00:00:00.652,008] [0m<inf> app_event_manager: SENSOR_EVT_SHUTDOWN_READY[0m
2022-04-26T14:24:15.007Z DEBUG modem << [00:00:00.658,996] [1;33m<wrn> modules_common: Module "sensor" shutdown registered[0m
2022-04-26T14:24:15.010Z DEBUG modem << [00:00:00.666,961] [0m<dbg> cloud_module: state_set: State transition STATE_LTE_INIT --> STATE_SHUTDOWN[0m
2022-04-26T14:24:15.022Z DEBUG modem << [00:00:00.676,788] [0m<inf> app_event_manager: DATA_EVT_SHUTDOWN_READY[0m
2022-04-26T14:24:15.024Z DEBUG modem << [00:00:00.683,532] [1;33m<wrn> modules_common: Module "data" shutdown registered[0m
2022-04-26T14:24:15.039Z DEBUG modem << [00:00:00.691,619] [0m<dbg> sensor_module: state_set: State transition STATE_INIT --> STATE_SHUTDOWN[0m
2022-04-26T14:24:15.045Z DEBUG modem << [00:00:00.701,049] [0m<dbg> data_module: state_set: State transition STATE_CLOUD_DISCONNECTED --> STATE_SHUTDOWN[0m
2022-04-26T14:24:15.060Z DEBUG modem << [00:00:00.719,421] [0m<dbg> modem_module: configure_low_power: PSM requested[0m
2022-04-26T14:24:15.112Z DEBUG modem << [00:00:00.772,521] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
2022-04-26T14:24:15.122Z DEBUG modem << [00:00:00.779,418] [0m<dbg> ui_module: state_set: State transition STATE_SHUTDOWN --> STATE_LTE_CONNECTING[0m
2022-04-26T14:24:15.126Z DEBUG modem << +CEREG: 0
2022-04-26T14:24:15.142Z DEBUG modem << [00:00:00.792,602] [0m<dbg> modem_module: lte_evt_handler: LTE cell changed: Cell ID: -1, Tracking area: -1[0m
2022-04-26T14:24:15.144Z DEBUG modem << [00:00:00.802,642] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
2022-04-26T14:24:15.352Z DEBUG modem << [00:00:01.009,124] [0m<dbg> modem_module: state_set: State transition STATE_DISCONNECTED --> STATE_SHUTDOWN[0m
2022-04-26T14:24:15.359Z DEBUG modem << [00:00:01.019,134] [0m<inf> app_event_manager: MODEM_EVT_SHUTDOWN_READY[0m
2022-04-26T14:24:15.370Z DEBUG modem << [00:00:01.026,184] [1;33m<wrn> modules_common: Module "modem" shutdown registered[0m
  • Have you changed the implementation in EVENT_LISTENER and EVENT_SUBSCRIBE? I don't find macros named APP_EVENT_LISTENER and APP_EVENT_SUBSCRIBE in my workarea (ncs 1.9.0)
  • I downloaded the aaset_tracker from Git. In this code, the MACROs have been changed. The GIT default code is working well. I just added my custom module and events.
    One potential problem I see in your code is that you don't create a unique name for your BMS module event listener. So it might be that your event handler is overwritten by another module (e.g. the main module).
    I also notice that your BMS log_event function doesn't actually do anything. Are you sure this isn't just a case of missing logging?
    Didrik
  • Hi, I have changed the name of event_handler fucntion. I want to know little more about log_event function. It is used to stingfy the event. The log_event function returns int and sprintf function is used to display the event information. Is the information returned by
    return snprintf(buf, buf_len, "%s", get_evt_type_str(event->type));
    displayed in LTE_LINK _MONITOR also ?
    How is log_event handled in EVENT_TYPE_DEFINE ?
    Also, there are two functions in the thread_fn, LOG_ERR() and SEND_ERROR()... What is operational and execution difference in these ? Where are these used ? Where the LOG functions stores the information and where SEND_ERROR sends the information ?
    Where is the information sent by LOG_DBG ?
    After testing as per your suggestions in previous reply, I shall report you the status of results. Meanwhile, may please you clarify my doubts ?
    Yes, if CONFIG_LOG is set. Though this way of doing it (snprintf into buf) has been deprecated, and will be removed in a future NCS version.
    The new way to use the log function is shown in our documentation: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/nrf/libraries/others/event_manager.html#create-a-source-file
    If we look at this piece of code from your bms module, assuming err is -5:
    	if (err) {
    LOG_ERR will log (print to the console) "Failed starting module, error -5" with log level ERROR.
    SEND_ERROR will create a event from the bms module, of type BMS_DATA_ERROR, and data.err will be -5. The event is sent to anyone who is listening for that type of events.
    If log level debug (DBG) is enabled, and uart is used as the log backend, the information will be sent over the uart.
