Unable to get an NMOS output to be driven by GPIO if another NMOS output is driven by PWM on Thingy91
I am running a PWM pin on 15 using this DT Overlay:
    pwmnmos {
        compatible = "pwm-leds";
        status = "okay";
        pwm_nmos0: pwm_nmos_0{
            pwms = <&pwm2 15>;
Is the compatible line correct?
My GPIO lines look like this :
    gpiocustom {
        compatible = "gpio-keys";
        gpiocus0: gpiocus_0 {
            gpios = <&gpio0 16 GPIO_ACTIVE_LOW>;
            label = "Custom gpio 16";
        gpiocus1: gpiocus_1 {
            gpios = <&gpio0 30 GPIO_ACTIVE_LOW>;
            label = "Custom gpio 30";
        nmos_out2: nmos_2{
            gpios = <&gpio0 14 GPIO_ACTIVE_LOW>;
            label = "NMOS_2_output p0.14";
I can get the NMOS outputs to work like this:
    if (!device_is_ready(spec->port)) {
        printk("Error: %s device is not ready\n", spec->port->name);
        return;
    else printk(" %s device is ready\n", spec->port->name);
    ret = gpio_pin_configure(nmosdev, NMOS2PIN, GPIO_OUTPUT_ACTIVE | NMOS2FLAGS);
    if (ret != 0) {
        printk("Error %d: failed to configure pin %d (NMOS '%s')\n",
            ret, spec->pin, nmos2.gpio_pin_name);
        return;
    printk("Configured pin %d (NMOS '%s')\n",
    gpio_pin_set(nmosdev, NMOS2PIN,1); // leds on
    gpio_pin_set(dev_cust_gpio, CUST_IO_PIN, 1);
But the LED goes out after this code:
    pwm = DEVICE_DT_GET(PWM_CTLR);
    if (!device_is_ready(pwm)) {
        while (1)
        printk("Error: PWM device %s is not ready\n", pwm->name);
        k_sleep(K_SECONDS(1U));
    ret = pwm_pin_set_usec(pwm, PWM_CHANNEL,
                       period,pulsewidth, PWM_FLAGS);
Another NMOS output shows the PWM output but the GPIO'd LED goes out.
Any bright ideas as to why PWM fouls up another NMOS pin?
