I see that there is definitely support for where a user would cancel the USB host's request to suspend inside of app_usbd.c
here's line 1246:
case APP_USBD_EVT_DRV_SUSPEND:
sustate_set(SUSTATE_SUSPENDING);
user_event_state_proc(APP_USBD_EVT_DRV_SUSPEND);
/* Processing all instances from the list and then core interface (connected only to EP0) */
app_usbd_all_call((app_usbd_complex_evt_t const *)p_event);
UNUSED_RETURN_VALUE(app_usbd_core_handler_call(p_event));
}You can clearly see that it throws up the APP_USBD_EVT_DRV_SUSPEND
In the documentation it even states that we should be using these events:
"In most cases, it is used to process SUSPEND/RESUME and APP_USBD_EVT_POWER_ events."
Does anyone know the proper method to cancel the suspending event? I would think that we would want to set the sustate to ACTIVE rather than SUSPENDING, but with the sustate_set being an inline method I would suspect it's meant to be a private method inside that source code alone. There is also app_usbd_sustate_with_requested_hfclk, but that again is not defined in the header the only thing I can find is app_usbd_wakeup_req?
It does look like app_usbd_wakeup_req does cover canceling the request, but allows it to suspend first and then turns right back on. Unfortunately I believe this could cause a race condition of aborting all end point transfers, possibly causing rare errors in the future.
I would just like some feedback on if this is the proper way to cancel the suspend event? Or is there a way to dynamically disable the USB suspend event?
