I am working with a sensor that generates a simple crc8 XOR on based on this code from the nrf sdk 17 and sends it to a central:
#include <stdio.h> #include <string.h> #include <math.h> static unsigned int L2_calculate_crc(unsigned char *buffer_ptr, unsigned int count) { register unsigned int crc_reg; register unsigned char bit_count; #define CRC_GEN_POLY (0x11021) /* CRC-CCITT (X^^16 + X^^12 + X^^5 + 1): */ #define CRC_WORK_POLY (0x08408) /* Bit order reversed to match Tx order */ /* * Initialize the working register to all one bits. * This is equivalent to initializing to zero and then * inverting the first sixteen message bits. */ crc_reg = 0xFFFF; /* Loop for each byte in the message */ do { crc_reg ^= (unsigned int)*buffer_ptr; ++buffer_ptr; for (bit_count=8; bit_count; --bit_count) { if (crc_reg & 0x01) { /* * Bit ready to be shifted off the right is a one. * A division is possible. This bit is logically * XORed with the implied "testing" bit below * bit zero of the working polynomial. */ crc_reg >>= 1; crc_reg ^= CRC_WORK_POLY; } else { /* * Bit ready to be shifted off the right is a zero. * No division is possible. Just shift right one bit. */ crc_reg >>= 1; } }/*end for each bit*/ } while (--count); /* Return the one's complement of the calculated remainder. */ return (~crc_reg); } char CalculateSum8 (__uint8_t *Buffer, __uint16_t Length) { __uint8_t Sum; __uint16_t Count; for (Sum = 0, Count = 0; Count < Length; Count++) { Sum = (__uint8_t) (Sum + *(Buffer + Count)); } return Sum; } char CalculateCheckSum8 ( __uint8_t *Buffer, __uint16_t Length) { __uint8_t CheckSum; CheckSum = CalculateSum8 (Buffer, Length); return (__uint8_t) (0x100 - CheckSum); } int main() { unsigned char crc[2] ={0xff,0xff}; printf("Test CRC8 generation\n"); /*66 11 01 1650861179 'e'*/ unsigned char array1[] ={ 0x42 , 0x0B , 0x01 , 0x62,0x66,0x24,0x7B , 0x65}; unsigned char crc_value; unsigned char *buffer_ptr = array1; unsigned int count = sizeof(array1); crc_value = CalculateCheckSum8(buffer_ptr,count); // test function printf("crc_value: 0X%X\n",crc_value); return 0; }
I need to check this CRC8 on the central and noticed that zephyr had a crc8 function: https://docs.zephyrproject.org/apidoc/latest/group__crc.html#ga9a925de71cd0255a22c769dc4b130da5
but that it required a polynomial and initial value. Can this be configured to be compatible with the crc8 check done from the nrf sdk 17 so that I can check the crc8 code sent from the sensor?
