Since the beacon will run on CR2032, I'm trying to minimize power concumption.
NOTE: All measured using nRF52-DK + PPK2 configuration
The online profiler says that if I use an external clock I can go below 10uA:
However, this looks impossible:
In the sdk_config.h, I made sure that I selected an external clock NRF_CLOCK_ENABLED=1 CLOCK_CONFIG_LF_SRC=1.
here is my code (a bit mod of example):
* Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_beacon_main main.c
* @ingroup ble_sdk_app_beacon
* @brief Beacon Transmitter Sample Application main file.
* This file contains the source code for an Beacon transmitter sample application.
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_clock.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(1000, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH 0x17 /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH 0x15 /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE 0x02 /**< 0x02 refers to Beacon. */
//#define APP_MEASURED_RSSI 0xC3 /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
/*Measured Power
Measured Power is a factory-calibrated, read-only constant that indicates what’s the expected RSSI at a distance of 1 meter to the beacon.
Combined with RSSI, it allows estimating the distance between the device and the beacon.*/
#define APP_MEASURED_RSSI 0xA4 /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER 0x0059 /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE 0x01, 0x02 /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE 0x03, 0x04 /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \
0x45, 0x56, 0x67, 0x78, \
0x89, 0x9a, 0xab, 0xbc, \
0xcd, 0xde, 0xef, 0xf0 /**< Proprietary UUID for Beacon. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO 18 /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS 0x10001080 /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
static ble_gap_adv_params_t m_adv_params; /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = NULL,
.len = 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */
APP_DEVICE_TYPE, // Manufacturer specific information. Specifies the device type in this
// implementation.
APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
// manufacturer specific data in this implementation.
APP_BEACON_UUID, // 128 bit UUID value.
APP_MAJOR_VALUE, // Major arbitrary value that can be used to distinguish between Beacons.
APP_MINOR_VALUE, // Minor arbitrary value that can be used to distinguish between Beacons.
APP_MEASURED_RSSI // Manufacturer specific information. The Beacon's measured TX power in
// this implementation.
* @details Encodes the required advertising data and passes it to the stack.
* Also builds a structure to be passed to the stack when starting advertising.
uint32_t err_code;
ble_advdata_t advdata;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
// If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
// UICR instead of using the default values. The major and minor values obtained from the UICR
// are encoded into advertising data in big endian order (MSB First).
// To set the UICR used by this example to a desired value, write to the address 0x10001080
// using the nrfjprog tool. The command to be used is as follows.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
// For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
// the following command should be used.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
// Initialize advertising parameters (used when starting advertising).
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = 0; // Never time out.
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
ret_code_t err_code;
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
ret_code_t set_advertisement_interval(uint16_t adv_interval)
ret_code_t ret_c;
sd_ble_gap_adv_stop(m_adv_handle);
NRF_LOG_INFO("Adv interval: %d", adv_interval);
m_adv_params.interval = MSEC_TO_UNITS(adv_interval, UNIT_0_625_MS);;
ret_c = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
if(ret_c != NRF_SUCCESS) {
NRF_LOG_INFO("sd_ble_gap_adv_set_configure error code %d", ret_c);
return ret_c;
ret_c = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
NRF_LOG_INFO("sd_ble_gap_adv_stop error code %d", ret_c);
return ret_c;
return NRF_SUCCESS;
uint32_t ram_start = 0;
// Enable BLE stack.
//if (NRF_LOG_PROCESS() == false)
nrf_pwr_mgmt_run();
static void lfclk_config(void)
ret_code_t err_code = nrf_drv_clock_init();
* @brief Function for application main entry.
lfclk_config();
uint32_t err_code;
//log_init();
// Initialize.
power_management_init();//do we need it?
ble_stack_init();
advertising_init();
// Start execution.
advertising_start();
//NRF_LOG_INFO("advertising is started");
/* Set low TX power for advertising
@note Supported tx_power values: -40dBm, -20dBm, -16dBm, -12dBm, -8dBm, -4dBm, 0dBm, +3dBm and +4dBm. */
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, -40);
//NRF_LOG_INFO("advertising to -40dBm");
err_code = sd_power_mode_set(NRF_POWER_MODE_LOWPWR);//TODO: how to use it?
err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);//WOW it works! -6µA
for (;;)
idle_state_handle();
No matter what I do, I cannot get out of 10 A. Please tell me how can I turn on the LF ex clock on nRF52-DK?
