nRF53 Custom b0n Build
I am trying to compile a custom bootloader for nRF5340 net core (b0n) that is part of a multi-image build.
I have created two separate applications, one based on b0n (nrf/samples/nrf5340/netboot) and one based on nrf/samples/bluetooth/peripheral_lbs. These both build without issue when used as single image applications and I can debug them (using hello_world on the app core) and they appear to work.
I have tried adding the b0n as a child image of the application by adding the following code to CMakeLists.txt
if (CONFIG_SECURE_BOOT)
  add_child_image(
    NAME b0n
    SOURCE_DIR ${CMAKE_CURRENT_LIST_DIR}/../boot_stage1
endif()
If I then build the net app, the application builds, but b0n is neither built nor linked.
I have tried adding CONFIG_SECURE_BOOT=y to the prj.conf file. If I have the above CMakeLists.txt change, I get the following compilation error:
=== child image b0n -  begin ===
loading initial cache file C:/Users/anton/src/bootloader-test/netapp/build/b0n/child_image_preload.cmake
CMake Error: The source "C:/Users/anton/src/bootloader-test/boot_stage1/CMakeLists.txt" does not match the source "C:/Users/anton/ncs/v1.9.1/nrf/samples/nrf5340/netboot/CMakeLists.txt" used to generate cache.  Re-run cmake with a different source directory.
CMake Error at C:\Users\anton\ncs\v1.9.1\nrf\cmake\multi_image.cmake:409 (message):
  CMake generation for b0n failed, aborting.  Command: 1
  C:\Users\anton\ncs\v1.9.1\nrf\cmake\multi_image.cmake:150 (add_child_image_from_source)
  c:\Users\anton\src\bootloader-test\netapp\build\CMakeLists.txt:21 (add_child_image)
This confuses me in the following ways
  • I don't know why the netboot sample should be used to generate the cache.
  • The CMakeLists.txt are identical in both the sample and in my local build.
  • I don't know why they need to match anyway.
What is going wrong here?
p.s. Most of the documnetation about multi-image bootloader builds suggest using CONFIG_B0_BUILD_STRATEGY_FROM_SOURCE=y. There doesn't appear to be an equivalent CONFIG_B0N_BUILD_STRATEGY_FROM_SOURCE.
  • Hi
    I have tried to do custom NSIB and b0n in the samples I suggested you, and I have talked with my colleagues about it.
    And I have finally found what I suspect you have tried to tell me all this time: It does not work.
    As far as I can find, CONFIG_SECURE_BOOT is needed for both NSIB and b0n, and if this is set the child images are imported directly from our samples folder.
    And CONFIG_SECURE_BOOT is too interconnected with the nRF Connect SDK for us to disable it without consequences.
    In conclusion, the only way to have custom NSIB/b0n is to fork the nRF Connect SDK, and make changes to our SDK.
    See my earlier comment for an example, and also Adding your own code.
    Thank you for being thorough in getting your point across.
    While this is not the solution you want right now, I hope it will suffice.
    I will ask our developers about this feature, and maybe we can get it in a future version of the nRF Connect SDK.
    Sigurd Hellesvik
  • Thanks for your honesty.
    This project is for a product that needs to be able to recover even under extreme circumstances so custom bootloaders are absolutely necessary. I have worked around the worst of the issues modifying the SDK by adding the following lines to the top of the application root CMakeLists.txt :
    set(CONFIG_B0_CUSTOM_FOLDER "${CMAKE_SOURCE_DIR}/cpuboot")
    set(CONFIG_B0N_CUSTOM_FOLDER "${CMAKE_SOURCE_DIR}/netboot")
    I have then added the custom bootloaders at those subdirectories. I then copied the SDK into a new directory next to the application (so as not to polute the common SDK) and made the following changes to the samples CMakeLists.txt :
      if (CONFIG_SOC_NRF5340_CPUNET)
        # Share some information which is used when generating the zip file
        # with the update binaries.
        set_shared(IMAGE net_core PROPERTY SOC ${CONFIG_SOC})
        set_shared(IMAGE net_core PROPERTY VERSION ${CONFIG_FW_INFO_FIRMWARE_VERSION})
        if (DEFINED CONFIG_B0N_CUSTOM_FOLDER)
          add_child_image(
            NAME b0n
            SOURCE_DIR ${CONFIG_B0N_CUSTOM_FOLDER}
        else()
          add_child_image(
            NAME b0n
            SOURCE_DIR ${CMAKE_CURRENT_LIST_DIR}/nrf5340/netboot
        endif()
      else()
        if (DEFINED CONFIG_B0_CUSTOM_FOLDER)
          add_child_image(
            NAME b0
            SOURCE_DIR ${CONFIG_B0_CUSTOM_FOLDER}
        else()
          add_child_image(
            NAME b0
            SOURCE_DIR ${CMAKE_CURRENT_LIST_DIR}/bootloader
        endif()
      endif()
    This does get the job done but is still a bit of a hack; so, I am not marking this as an answer until custom bootloaders can be built using the unmodified SDK.
  • Sigurd,
    I found this discussion  due to a similar need. I also appreciate the honesty and candor in your response.
    Can you comment if there has been any progress on this or any plans by Nordic to support custom(ized) bootloader builds in nrf connect (without needed to modify the sdk)?
    Anton's use case is very common in the real world :
    "This project is for a product that needs to be able to recover even under extreme circumstances so custom bootloaders are absolutely necessary."
    The use of well structured, well designed, well tested, and open (in case of mcuboot) bootloaders is a good thing, but there will always be real world low level (and often proprietary/legacy methods) recovery needed  directly from the lowest levels of code. It is most often the more complex and higher levels of boot which fail (later stage bootloaders, application etc). And there may also be some other low level/sensitive/proprietary customization required in the first and/or second stages of boot.
    On this same topic and related, Nordic should consider the case of being able to build the bootloaders as standalone projects directly in the toolchain (the documentation states that this is somewhat doable via command line).
    There are  numerous real world (especially in production and repair environments) where a standalone bootloader project/build (not as a child project) is required for the various workflows.
    Building as child application embedded in main effort can also create design isolation challenges: some extreme security projects have separate bootloader/security development environments and don't want to share source/build with the application teams.
    Having the bootloader projects  as  separate standalone examples would allow that customization and should be accommodated by your toolchain, in addition to composite projects that have bootloader and app.
    There are some cases where products never even see an application until some post fielding OTA/download/low level upgrade that is done by bootloader.
    Thank you for considering these inputs.
  • Thank you for the complements!
    There have not been any changes to the multi-image builds yet.
    However, there are work being done on sysbuild. From these release notes:
    "Sysbuild was introduced in Zephyr's v3.2.0 release, and has been adopted in the nRF Connect SDK v2.4.0. Sysbuild will gradually become the new workflow for handling multi-image build configurations and it will replace the child image mechanism, specific to the nRF Connect SDK
    I have still  not tried sysbuild myself, but from what I have heard I suspect it could make it easier to add customized bootloaders to projects.
    In the end, a bootloader does not really care about how which binary it boots to (as long as said binary is signed).
    Therefore, you can in theory add your own bootloader and boot any nRF Connect SDK application after.
    As long as the bootloader is good enough at resetting states of peripherals and such, the application should not be affected by this either.
    In fact, our nRF52840 Dongles run the (old) nRF5 Bootloader, which does not know anything about the nRF Connect SDK.
    And this works.
    You can use the Kconfig option CONFIG_FLASH_LOAD_OFFSET to make the application start at the correct offset for your bootloader.
    And then if you want to do DFU, you either must have an update mechanism in the bootloader (ex. serial recovery) or one in your application which supports the custom bootloader.
    Here you can see a case where I discuss using the nRF Bootloader  One bootloader to rule them all .
    Did this make sense to you?
    Sigurd Hellesvik
