Is it possible to have a zero length characteristic read?
We're using the read authentication trigger to detect when a characteristic is being read, so we can update the value before a read.  Is it possible to have a read with zero length?
This is the data handler for the service, and I did confirm that it is getting called and that p_data and length are getting set to zero.
static bool CTFS_Data_Handler(ble_ctfs_evt_t *p_evt)
  bool b_ret_stat = false;
  switch (p_evt->type)
    case READ_CHARACTERISTIC:
    p_evt->params.rw_data.p_data = 0;
    p_evt->params.rw_data.length = 0;
The `CTFS_Data_Handler` gets passed to the softdevice as the data handler for this service.
void Service_Init()
  ble_uuid128_t mps_base_uuid = BLE_UUID_128_BIT_CTFS_BASE_SERVICE;
  /* Initialize the service structure. */
  m_ctfs.conn_handle = BLE_CONN_HANDLE_INVALID;
  m_ctfs.data_handler	= CTFS_Data_Handler;
  /* Add a custom base UUID. */
  uint32_t err_code = sd_ble_uuid_vs_add(&mps_base_uuid, &m_ctfs.uuid_type);
  VERIFY_SUCCESS(err_code);
But reading the characteristic always returns a byte.  Usually it's 0x00, but some times random data will also be returned.
Is there a way to have a zero-length characteristic read?  Or I guess another of putting it is return nothing on a read?
