UART interrupt
Hi nice people, I am working on developing using visual studio and Make environment. I am trying to function UART  tx/rx interrupt works but no luck. The TX and RX works perfect in blocking mode but it is not on interrupt mode. I am going to provide snippets of blocking and non blocking codes.
************************** Blocking mode *****************************************
void UART_run_blocking_test(void)
    nrfx_uart_config_t uart_conf = {
    .baudrate           = UART_BAUDRATE_BAUDRATE_Baud9600,
    .hwfc               = NRF_UARTE_HWFC_DISABLED,
    .parity             = NRF_UARTE_PARITY_EXCLUDED,
    .pseltxd            = UART_TX_PIN,
    .pselrxd            = UART_RX_PIN,
    .pselcts            = NRF_UART_PSEL_DISCONNECTED,
    .pselrts            = NRF_UART_PSEL_DISCONNECTED,
    .p_context          = NULL,
    nrfx_uart_init(&uartInstance, &uart_conf, NULL);
    uint8_t txd;
    while (1)
        nrfx_uart_rx(&uartInstance, &txd, 1);
        nrfx_uart_tx(&uartInstance, &txd, 1);
************************** Non Blocking mode *****************************************
static void uart_callback (nrfx_uart_event_t const * p_event, void *p_context)
(void*) p_context;
switch (p_event->type)
case NRFX_UART_EVT_TX_DONE:
case NRFX_UART_EVT_RX_DONE:
case NRFX_UART_EVT_ERROR:
void UART_run_non_blocking_test(void)
.p_context = NULL,
.interrupt_priority = NRFX_UART_DEFAULT_CONFIG_IRQ_PRIORITY,
nrfx_uart_init(&uartInstance, &uart_conf, uart_callback);
volatile uint32_t d;
while(1)
can u help?
    For future correspondance, please use the "Inser"->"Code" when you intend to paste large code snippets, as it makes it easier to read.
    In general, if you haven't tested, I can recommend the UART implementation from the SDK\examples\ble_peripheral\ble_app_uart example.
    If you want to use the nrfx_uart_init() directly, what does nrfx_uart_init() return?
    If you want to use the non-blocking uart, I also suggest that you test the nrfx_uarte_init, instead of nrfx_uart_init(). Again, look at the implementation from the ble_app_uart example. You can follow the definitions:
    uart_init() (from main.c) ->
    APP_UART_FIFO_INIT() ->
    app_uart_init() ->
    nrf_drv_uart_init() ->
    nrfx_uarte_init()
    Edvin
  • thank you for replay edvin
    it returs nrf_succes
    i did and the same result
    i followed that example
    let me add more:
    -  the code works perfect in blocking mode.
    - when transmitting, the first time it sends successfully but after that becomes busy all the time and not issuing a complete flag to trigger the interrupt
    What was the result?
    Not exactly, because the ble_app_uart uses nrfx_uarte_init(), and not nrfx_uart_init().
    Did you test the unmodified ble_app_uart example?
    BR,
    Edvin
  • I wrote above that i got the same results after changing the APIs from UART to UARTE
  • I think you misunderstood my question.
    what does nrfx_uart_init() return means that if you create a variable, uint32_t err_code; and set it equal to the return value of nrfx_uart_init()/nrfx_uarte_init(), what is the value of err_code after that?
    uint32_t err_code;
    err_code = nrfx_uarte_init();
    NRF_LOG_INFO("err_code = %d", err_code);
    So, what was the result (err_code) after nrfx_uarte_init()?
    And did you test the unmodified ble_app_uart example? Are you telling me that that doesn't work either? If so, what hardware are you using?
