NCS1.9.1, VSCode, nRF52840,
from link UART Driver – Nordic Developer Academy (nordicsemi.com)
uart can't to receive data continuously,
receiving evt->data.rx.offset will Increasing,
when rx_buf[128] is exhausted, will got evt
UART_RX_BUF_RELEASED
UART_RX_DISABLED
it will lost data,even call uart_rx_enable(dev, rx_buf, sizeof(rx_buf), 1000); again
is it a bug or missing some step?
#include <zephyr.h>
#include <device.h>
#include <drivers/gpio.h>
#include <sys/util.h>
#include <sys/printk.h>
#include <inttypes.h>
#include "uart.h"
#include "stdlib.h"
#include <drivers/uart.h>
const struct device *uart=NULL;
static uint8_t rx_buf[128] = {0}; //A buffer to store incoming UART data
static uint8_t tx_buf[] = {"uart started\n\r"};
static uint8_t tem_show_buf[128] = {0};
const struct uart_config uart_cfg = {
.baudrate = 115200,
.parity = UART_CFG_PARITY_NONE,
.stop_bits = UART_CFG_STOP_BITS_1,
.data_bits = UART_CFG_DATA_BITS_8,
.flow_ctrl = UART_CFG_FLOW_CTRL_NONE
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
switch (evt->type) {
case UART_TX_DONE:
printk("Tx sent %d bytesn\n", evt->data.tx.len);
case UART_TX_ABORTED:
printk("Tx aborted\n");
case UART_RX_RDY:
int l=evt->data.rx.len;
memcpy(tem_show_buf,evt->data.rx.buf+evt->data.rx.offset,l);tem_show_buf[l]=0;
printk("Received data:[%d]%s len:%d bytes\n", evt->data.rx.offset,tem_show_buf,l);
}break;
case UART_RX_BUF_REQUEST:
// uint8_t *buf;
// err = k_mem_slab_alloc(&uart_slab, (void **)&buf, K_NO_WAIT);
// __ASSERT(err == 0, "Failed to allocate slab");
// err = uart_rx_buf_rsp(uart, buf, BUF_SIZE);
// __ASSERT(err == 0, "Failed to provide new buffer");
printk("UART_RX_BUF_REQUEST\n");
case UART_RX_BUF_RELEASED:
// k_mem_slab_free(&uart_slab, (void **)&evt->data.rx_buf.buf);
printk("UART_RX_BUF_RELEASED\n");
case UART_RX_DISABLED:
printk("UART_RX_DISABLED\n");
case UART_RX_STOPPED:
printk("UART_RX_STOPPED\n");
int uart_init()
uart= device_get_binding(DT_LABEL(DT_NODELABEL(uart0)));
if (uart == NULL) {
printk("Could not find %s!\n\r", DT_LABEL(DT_NODELABEL(uart0)));
return;
int err = uart_configure(uart, &uart_cfg);
if (err == -ENOSYS) {
return -ENOSYS;
err = uart_callback_set(uart, uart_cb, NULL);
if (err) {
return err;
uart_rx_enable(uart ,rx_buf,sizeof rx_buf,1000);
return 0;
Best regards
