If Bluetooth is turned off, the mobile phone cannot find it when it is turned on later
Hello Nordic engineer,
SDK is 15.3.0, and example is ble_app_uart
I use the "nrf_sdh_disable_request()" function to turn off Bluetooth
Then start with the function "nrf_sdh_enable_request()"
The mobile phone cannot find Bluetooth
After turning bluetooth back on, do I have to turn on something to make bluetooth work?
Thanks
    Your mobile phone (or any other device) can only see the nRF when it is advertising. I do not know much about your code, but I assume you do not start advertising (for instance by calling ble_advertising_start()) after re-enabling the SoftDevice using nrf_sdh_enable_request().
    (As a side note, most applications never need to disable the SoftDevice so unless there is a good reason for your orginal call to nrf_sdh_disable_request(), you should consider removing that as well. If the point is just to "turn off Bluetooth", then you can simply stop advertising and/or scanning and disconnect any connections until you want to "turn on Bluetooth" again.)
  • Hi, Nordic engineer,
    Thank you for your reply,
    Regarding "advertising", I try to add "ble_advertising_start()"
    About your second paragraph
    (As a side note,
    For example "ble_app_uart"
    It should only have "advertising" and not "scanning", right?
    If I stop advertising, will it not occupy the timeslot?
    I use BLE+ESB, but the synchronization is not good
    So I want to try to turn off bluetooth, because only 1 device in my usage scenario needs to be paired with the phone,
    the rest can be turned off
    Thank you
    Yes. The point is that to "disable Bluetooth" you stop doing bluetooth activities. And that is typically scanning, advertising or being in a connection. For a pure peripheral, scanning is never relevant. And for a pure central, advertising is never relevant. The key is to stop doing what you no longer want to to Slight smile
    If you stop advertising, the SoftDevice will not schedule time for advertising, no. So you will get allocated more time from the radio timeslot API. But of course skipping it altogether is simpler, as you can if you only use ESB while the SoftDevice is disabled. I do not know the details about your product, but it could be that you have a use case where disabling the SoftDevice makes sense.
    I did not get that? If you only want to prevent others from connection, you can stop advertising. Or if you only want the bonded device to be allowed to connect you can use whitelisting. (not sure if that is the point with the above sentence, though).
