nRF51822 fds storage: Issue with fds_record_write
Hello everyone! Wave
We are using nRF51822 SoC together with s130 Softdevice. nRF5 SDK v12.3.0 is used for firmware development together with the Segger Embedded Studio.
Among the other things, we have a need to store one 32-bit variable in non-volatile flash memory. Consequently, we decided to use Flash Data Storage (FDS) for that purpose.
We can properly initialize the FDS module by using:
ret_code_t ret = fds_register(fds_evt_handler);
if (ret != FDS_SUCCESS)
    // Registering of the event handler has failed.
ret_code_t ret = fds_init();
    // Handle error.
as it is described here.
However, the trouble comes when we want to write a record to the flash with the fds_record_write() function (link). The function returns FDS_SUCCESS which implies that the write record operation was queued successfully but we never get the FDS_EVT_WRITE event inside the event handler (fds_evt_handler()).
Do you have any idea what we are missing here? We are using FDS in combination with the Softdevice. Perhaps that can be an issue? Do we need any particular SES settings that will enable FDS storage?
Here attached you can find nvs_storage.c/h modules that contain FDS-related code. As you can see, when we call the init_nvs_storage() function for the very first time, there will be no record in the flash, and create_blank_ouid_records() function will be called. Within that function, we try to call fds_record_write() that returns FDS_SUCCESS but FDS_EVT_WRITE event is never detected inside the event handler (fds_evt_handler()).
Thanks in advance for your time and efforts. Looking forward to hearing from you.
Cheers!  Beers
Bojan.
//--------------------------------- INCLUDES ----------------------------------
#include "nvs_storage.h"
#include "fds.h"
#include "bond3_watchdog.h"
#include "nrf_pwr_mgmt.h"
#include "main.h"
#define NRF_LOG_MODULE_NAME "nvs_storage"
#define NRF_LOG_LEVEL 3
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//---------------------------------- MACROS -----------------------------------
#define FILE_ID     0x1111
#define REC_KEY     0x2222
#define OUID_FILE_ID        (0x0020)
#define OUID_BACKUP_FILE_ID (0x0030)
#define OUID_REC_KEY        (0x0010)
//---------------------- PRIVATE FUNCTION PROTOTYPES --------------------------
static void run_garbage_collector(void);
static void fds_evt_handler(fds_evt_t const *p_evt);
static void wait_for_fds_ready(void);
static void wait_for_gc_to_finish(void);
static void wait_for_fds_update(void);
static void wait_for_fds_write(void);
static void wait_for_fds_delete(void);
static uint32_t init_fds_and_wait_until_ready(void);
static uint32_t check_for_fds_corruption(fds_stat_t *p_fds_stat);
static uint32_t create_blank_ouid_records(void);
static uint32_t clear_ouid_data(void);
static uint32_t write_ouid_data_to_flash(void);
static uint32_t search_for_and_init_ouid_data(FDSSysDataComponents_t *p_fds_sys_data);
static uint32_t open_ouid_data_record(FDSSysDataComponents_t *p_fds_sys_data);
static uint32_t open_ouid_data_backup_record(FDSSysDataComponents_t *p_fds_sys_data);
static uint32_t handle_possible_ouid_data_corruptions(FDSSysDataComponents_t *p_fds_sys_data);
static void dump_all_system_data_to_console(void);
static void dump_ouid_data(void);
//------------------------- STATIC DATA & CONSTANTS ---------------------------
/* Flag to check fds initialization. */
static bool volatile m_fds_initialized = false;
static bool volatile m_gc_is_running   = false;
static bool volatile m_fds_is_writing  = false;
static bool volatile m_fds_is_updating = false;
static bool volatile m_fds_is_deleting = false;
static uint32_t ouid_ = 0;
static uint32_t ouid_backup_ = 0;
static bool ouid_is_stored_ = false;
static bool _is_ouid_data_valid = false;
static bool _is_ouid_data_backup_valid = false;
/* Array to map FDS return values to strings. */
//NOTE(bojankoce): this serves for debug only. Could be deleted to save some space, if needed.
char const *fds_err_str[] = {
    "FDS_SUCCESS",
    "FDS_ERR_OPERATION_TIMEOUT",
    "FDS_ERR_NOT_INITIALIZED",
    "FDS_ERR_UNALIGNED_ADDR",
    "FDS_ERR_INVALID_ARG",
    "FDS_ERR_NULL_ARG",
    "FDS_ERR_NO_OPEN_RECORDS",
    "FDS_ERR_NO_SPACE_IN_FLASH",
    "FDS_ERR_NO_SPACE_IN_QUEUES",
    "FDS_ERR_RECORD_TOO_LARGE",
    "FDS_ERR_NOT_FOUND",
    "FDS_ERR_NO_PAGES",
    "FDS_ERR_USER_LIMIT_REACHED",
    "FDS_ERR_CRC_CHECK_FAILED",
    "FDS_ERR_BUSY",
    "FDS_ERR_INTERNAL",
/* Array to map FDS events to strings. */
static char const *fds_evt_str[] = {
    "FDS_EVT_INIT",       "FDS_EVT_WRITE",    "FDS_EVT_UPDATE",
    "FDS_EVT_DEL_RECORD", "FDS_EVT_DEL_FILE", "FDS_EVT_GC",
static fds_record_desc_t  ouid_fds_desc_ = {0};  // Descriptor for our ouid
static fds_record_desc_t  ouid_backup_fds_desc_ = {0};  // Descriptor for our backup ouid
static const fds_record_chunk_t ouid_data_chunk = {
    .p_data = &ouid_,
    .length_words = 1
static const fds_record_chunk_t ouid_backup_data_chunk = {
    .p_data = &ouid_backup_,
    .length_words = 1
static fds_record_t const ouid_record = {   // Record to hold our ouid
    .file_id = OUID_FILE_ID,
    .key = OUID_REC_KEY,
    .data.p_chunks = &ouid_data_chunk,
    .data.num_chunks = 1
static fds_record_t const ouid_backup_record = {   // Record to hold our backup ouid
    .file_id = OUID_BACKUP_FILE_ID,
    .data.p_chunks = &ouid_backup_data_chunk,
/* Keep track of the progress of a delete_all operation. */
static struct {
    bool delete_next; //!< Delete next record.
    bool pending; //!< Waiting for an fds FDS_EVT_DEL_RECORD event, to delete
                  //! the next record.
} m_delete_all;
//---------------------------- PRIVATE FUNCTIONS ------------------------------
static void fds_evt_handler(fds_evt_t const *p_evt) {
    //NRF_LOG_DEBUG("Event: %s received (%s)", fds_evt_str[p_evt->id],
    //              fds_err_str[p_evt->result]);
    switch (p_evt->id) {
    case FDS_EVT_INIT:
        NRF_LOG_INFO("FDS_EVT_INIT! 0x%X\r\n", p_evt->result);
        if (p_evt->result == FDS_SUCCESS) {
            m_fds_initialized = true;
            NRF_LOG_INFO("FDS initialized!\r\n");
    case FDS_EVT_GC:
        NRF_LOG_INFO("FDS_EVT_GC!\r\n");
    case FDS_EVT_WRITE: {
            NRF_LOG_DEBUG("Record ID:\t0x%04x", p_evt->write.record_id);
            NRF_LOG_DEBUG("File ID:\t0x%04x", p_evt->write.file_id);
            NRF_LOG_DEBUG("Record key:\t0x%04x", p_evt->write.record_key);
        NRF_LOG_INFO("FDS_EVT_WRITE! 0x%X\r\n", p_evt->result);
    } break;
    case FDS_EVT_DEL_FILE:
    case FDS_EVT_DEL_RECORD: {
            NRF_LOG_DEBUG("Record ID:\t0x%04x", p_evt->del.record_id);
            NRF_LOG_DEBUG("File ID:\t0x%04x", p_evt->del.file_id);
            NRF_LOG_DEBUG("Record key:\t0x%04x", p_evt->del.record_key);
        NRF_LOG_INFO("FDS_EVT_DEL_FILE/RECORD! 0x%X\r\n", p_evt->result);
        m_delete_all.pending = false;
    } break;
    case FDS_EVT_UPDATE: {
        NRF_LOG_INFO("FDS_EVT_UPDATE!: 0x%X\r\n", p_evt->result);
    } break;
/**@brief   Wait for fds to initialize. */
static void wait_for_fds_ready(void) {
    while (!m_fds_initialized) {
        //nrf_pwr_mgmt_run();
static void wait_for_gc_to_finish(void) {
    while (m_gc_is_running)
static void wait_for_fds_update(void) {
    while (m_fds_is_updating)
static void wait_for_fds_write(void) {
    while (m_fds_is_writing)
static void wait_for_fds_delete(void) {
    while (m_fds_is_deleting)
static void run_garbage_collector(void) {
    uint32_t err_code;
    NRF_LOG_DEBUG("Running garbage collector.\r\n");
    m_gc_is_running = true;
    feed_wdt();
    err_code = fds_gc();
    feed_wdt();
    if (err_code) {
        //NRF_LOG_WARNING("GC failure: %s", fds_err_str[err_code]);
        NRF_LOG_WARNING("GC failure: %d", err_code);
        return;
    wait_for_gc_to_finish();
static uint32_t init_fds_and_wait_until_ready(void) {
    NRF_LOG_INFO("init_fds_and_wait_until_ready::Starting Process\r\n");
    uint32_t err_code;
    /* Register first to receive an event when initialization is complete. */
    err_code = fds_register(fds_evt_handler);
    NRF_LOG_INFO("fds_register: 0x%X\r\n", err_code);
    if (err_code) {
        //APP_ERROR_CHECK(err_code);
        return err_code;
    err_code = fds_init();
    NRF_LOG_INFO("fds_init: 0x%X\r\n", err_code);
    if (err_code == FDS_ERR_NO_PAGES) {
        NRF_LOG_ERROR("FDS found NO Valid pages. Attempting to erase ALL FDS pages.\r\n");
        //TODO(bojankoce): check if it is needed to erase all FDS pages!
        feed_wdt();
        perform_system_reset();
    } else if (err_code) {
        return err_code;
    feed_wdt();
    wait_for_fds_ready();
    return err_code;
static uint32_t check_for_fds_corruption(fds_stat_t *p_fds_stat) {
    NRF_LOG_INFO("check_for_fds_corruption::Starting Process\r\n");
    uint32_t err_code;
    bool     gc_required = false;
    if (!p_fds_stat) {
        NRF_LOG_ERROR("Null Pointer\r\n");
        return NRF_ERROR_NULL;
    err_code = fds_stat(p_fds_stat);
    if (err_code) {
        return err_code;
    NRF_LOG_INFO("Found %d valid records.\r\n", p_fds_stat->valid_records);
    NRF_LOG_INFO("Found %d dirty records.\r\n", p_fds_stat->dirty_records);
    if (p_fds_stat->dirty_records >=
        MAX_DIRTY_RECORDS_BEFORE_GARBAGE_COLLECTION) {
        NRF_LOG_WARNING("Sufficient dirty records to run GC.\r\n");
        gc_required = true;
    if (gc_required) {
        feed_wdt();
        run_garbage_collector();
    return err_code;
static uint32_t search_for_and_init_ouid_data(FDSSysDataComponents_t *p_fds_sys_data) {
    uint32_t err_code;
    if (!p_fds_sys_data) {
    //APP_ERROR_CHECK(open_ouid_data_record(p_fds_sys_data));
    //APP_ERROR_CHECK(open_ouid_data_backup_record(p_fds_sys_data));
    err_code = open_ouid_data_record(p_fds_sys_data);
    NRF_LOG_INFO("open_ouid_data_record: 0x%X\r\n", err_code);
    err_code = open_ouid_data_backup_record(p_fds_sys_data);
    NRF_LOG_ERROR("open_ouid_data_backup_record: 0x%X\r\n", err_code);
    //err_code = (handle_possible_ouid_data_corruptions(p_fds_sys_data));
    err_code = handle_possible_ouid_data_corruptions(p_fds_sys_data);
    NRF_LOG_INFO("handle_possible_ouid_data_corruptions: 0x%X\r\n", err_code);
    return err_code;
static uint32_t open_ouid_data_record(FDSSysDataComponents_t *p_fds_sys_data) {
    uint32_t err_code;
    err_code = fds_record_find(ouid_record.file_id,
                               ouid_record.key, &ouid_fds_desc_,
                               &(p_fds_sys_data->sys_data_ouid_token));
    NRF_LOG_INFO("fds_record_find: 0x%X\r\n", err_code);
    if (!err_code) {
        NRF_LOG_INFO("System Data OUID found\r\n");
        err_code = fds_record_open(&ouid_fds_desc_,
                                   &(p_fds_sys_data->sys_data_ouid_record));
        if (!err_code) {
            NRF_LOG_WARNING("System Data OUID valid\r\n");
            _is_ouid_data_valid = true;
        } else {
            NRF_LOG_WARNING("System Data OUID invalid\r\n");
    } else {
        NRF_LOG_INFO("System Data OUID not found\r\n");
    return err_code;
static uint32_t open_ouid_data_backup_record(FDSSysDataComponents_t *p_fds_sys_data) {
    uint32_t err_code;
        ouid_backup_record.file_id, ouid_backup_record.key,
        &ouid_backup_fds_desc_,
        &(p_fds_sys_data->sys_data_ouid_backup_token));
    if (!err_code) {
        NRF_LOG_INFO("System Data OUID Backup found\r\n");
        err_code =
            fds_record_open(&ouid_backup_fds_desc_,
                            &(p_fds_sys_data->sys_data_ouid_backup_record));
        if (!err_code) {
            NRF_LOG_WARNING("System Data OUID Backup valid\r\n");
            _is_ouid_data_backup_valid = true;
        } else {
            NRF_LOG_WARNING("System Data OUID Backup invalid\r\n");
    } else {
        NRF_LOG_INFO("System Data OUID Backup not found\r\n");
    return err_code;
static uint32_t handle_possible_ouid_data_corruptions(FDSSysDataComponents_t *p_fds_sys_data) {
    uint32_t err_code;
        NRF_LOG_ERROR("Null pointer\r\n");
    if (_is_ouid_data_valid && _is_ouid_data_backup_valid) {
        // All OUID data is valid
        NRF_LOG_INFO("All system data ouid records are intact.\r\n");
        memcpy(&ouid_,
               p_fds_sys_data->sys_data_ouid_record.p_data,
               sizeof(ouid_));
        memcpy(&ouid_backup_,
               p_fds_sys_data->sys_data_ouid_backup_record.p_data,
               sizeof(ouid_));
        /* Close the records when done reading. */
        err_code = fds_record_close(&ouid_fds_desc_);
        err_code = fds_record_close(&ouid_backup_fds_desc_);
    } else if (!_is_ouid_data_valid && _is_ouid_data_backup_valid) {
        NRF_LOG_WARNING("Using system data OUID backup.\r\n");
        memcpy(&ouid_,
               sizeof(ouid_));
               sizeof(ouid_));
    } else if (_is_ouid_data_valid && !_is_ouid_data_backup_valid) {
        NRF_LOG_WARNING("System data OUID backup invalid. Using system data OUID data.\r\n");
        memcpy(&ouid_,
               sizeof(ouid_));
               sizeof(ouid_));
    } else {
        NRF_LOG_WARNING("Neither system data OUID nor system data OUID backup were valid! \r\n");
        err_code = NRF_ERROR_NOT_FOUND;
    return err_code;
static uint32_t create_blank_ouid_records(void){
    uint32_t err_code = NRF_SUCCESS;
    // OUID data
    NRF_LOG_INFO("Creating new ouid data file\r\n");
    m_fds_is_writing = true;
    err_code = fds_record_write(&ouid_fds_desc_, &ouid_record);
    NRF_LOG_INFO("fds_record_write: 0x%X\r\n", err_code);
    if (err_code) {
        return err_code;
    } else {
        NRF_LOG_INFO("fds_record_write OK!\r\n");
    wait_for_fds_write();
    NRF_LOG_INFO("Creating new ouid backup file\r\n");
    err_code         = fds_record_write(&ouid_backup_fds_desc_,
                                &ouid_backup_record);
    if (err_code) {
        return err_code;
    return err_code;
static uint32_t clear_ouid_data(void){
    uint32_t virgin_ouid = 0;
    return set_ouid(&virgin_ouid);
static void dump_all_system_data_to_console(void){
    dump_ouid_data();
static void dump_ouid_data(void){
    NRF_LOG_INFO("OUID: 0x%X\r\n", ouid_);
    NRF_LOG_INFO("Backup OUID: 0x%X\r\n", ouid_backup_);
//------------------------------ PUBLIC FUNCTIONS -----------------------------
uint32_t init_nvs_storage(void) {
    FDSSysDataComponents_t fds_sys_data;
    memset(&fds_sys_data, 0, sizeof(fds_sys_data));
    err_code = init_fds_and_wait_until_ready();
    //NRF_LOG_INFO("init_fds_and_wait_until_ready: 0x%X\r\n", err_code);
    if (err_code) {
        return err_code;
    err_code = check_for_fds_corruption(&(fds_sys_data.fds_stat));
    //NRF_LOG_INFO("check_for_fds_corruption: 0x%X\r\n", err_code);
    if (err_code) {
        return err_code;
    err_code = search_for_and_init_ouid_data(&fds_sys_data);
    NRF_LOG_INFO("search_for_and_init_ouid_data: 0x%X\r\n", err_code);
    if (err_code) {
        NRF_LOG_WARNING("Unable to load ouid from internal flash. Will "
                        "create virgin records: 0x%X\r\n",
                        err_code);
        err_code = create_blank_ouid_records();
        if (err_code) {
            NRF_LOG_ERROR("Unable to create new OUID records: 0x%X\r\n",
                          err_code);
        } else {
            NRF_LOG_INFO("OUID records newly created\r\n");
    } else {
        NRF_LOG_INFO("OUID records loaded from internal flash\r\n");
    //TODO(bojankoce): We can use non-volatile flash to store some System Status/Settings data
    dump_all_system_data_to_console();
    NRF_LOG_INFO("Internal flash initialized\r\n");
    return err_code;
uint32_t get_ouid(uint32_t *ouid) {
    int ret = NRF_SUCCESS;
#if STORE_IN_NVS
    *ouid = ouid_;
#else
    *ouid = ouid_;
    ret = 4;
    return ret;
uint32_t set_ouid(uint32_t *new_ouid) {
#if STORE_IN_NVS
    fds_stat_t stat = {0};
    if (!new_ouid) {
    ouid_ = *new_ouid;
    ouid_backup_ = *new_ouid;
    feed_wdt();
    m_fds_is_updating = true;
    err_code = fds_record_update(&ouid_fds_desc_, &ouid_record);
    NRF_LOG_INFO("fds_record_update: 0x%X\r\n", err_code);
    if (err_code) {
        return err_code;
    wait_for_fds_update();
    err_code          = fds_record_update(&ouid_backup_fds_desc_,
    if (err_code) {
        return err_code;
    err_code = fds_stat(&stat);
    if (err_code) {
        return err_code;
    NRF_LOG_INFO("Found %d valid records, %d dirty records.\r\n", stat.valid_records, stat.dirty_records);
    if (stat.dirty_records >= MAX_DIRTY_RECORDS_BEFORE_GARBAGE_COLLECTION) {
#else
    ouid_ = ouid;
    if(!ouid_is_stored()){
        ouid_is_stored_ = true;
    return err_code;
bool ouid_is_stored(void) {
#if STORE_IN_NVS
    return _is_ouid_data_valid;
#else
    return ouid_is_stored_;
4760.nvs_storage.h
  • Hey, guys... here are some additional pieces of information:
    • when I initialize the FDS module AFTER initializing the Bluetooth module (gap, advertising, gatt, services, connection parameters), then I am able to properly write an initial value to the flash by using fds_record_write() function. FDS_EVT_WRITE event is properly detected.
    • However, when I establish BLE connection with the Central device and want to update the flash with fds_record_write() or fds_record_update() functions then write/update record operation was queued successfully but we never get the FDS_EVT_WRITE/UPDATE event inside the event handler.
    It seems to me that the FDS module has some limitations when used in the presence of the Softdevice. I know that the Peer Manager is also using FDS. Is there anything we should do to make the FDS module works together with the Softdevice?
    Some threads that are reporting similar issue (e.g. link1, link2) suggest including ${SDK_ROOT}/components/softdevice/common/nrf_sdh_soc.c file in the build. However, nRF5 SDK v12.3.0 does not contain that file. Is there anything similar we should include?
    Bojan.
    Flash operations have very low priority compared to other softdevice taks:
    https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.s130.sds/dita/softdevices/s130/multilink_scheduling/priorities_and_events_intro.html
    So, it may take considerably time before the flash operation completes or it can even timeout if the softdevice is not able to execute the flash operation due to other higher priority activities. What you can try is to for instance configure FS_OP_MAX_RETRIES to 1000, that should at least give more retries before it "give up".
    To give the softdevice time to execute flash operations, it may help to increase the connection interval, and at least use slave latency on the link, since this will allow connection intervals to be skipped (e.g. to handle flash operations if needed).
    Kenneth
  • Thanks for the suggestions, Kenneth!
    Changing FS_OP_MAX_RETRIES or connection interval parameters did not resolve the issue.
    What resolved the issue is putting the event into the scheduler queue with app_sched_event_put() API.
    Writing into the FDS from withing scheduler handler function did the job for us!
    Thanks in advance for your hints! I think we can close the ticket now.
    Cheers,
    Bojan.
