I'm using the nRF Connect SDK 1.9.1 and I have defined a custom board with nRF52840. This works for normal code (samples, etc).
The .dst has the following structure for the memory, based off the nrf52840dk_nrf52840 board (here some of the configuration has been omitted such as spi, etc):
&flash0 {
chosen {
zephyr,console = &uart0;
zephyr,shell-uart = &uart0;
zephyr,uart-mcumgr = &uart0;
zephyr,bt-mon-uart = &uart0;
zephyr,bt-c2h-uart = &uart0;
zephyr,sram = &sram0;
zephyr,flash = &flash0;
zephyr,code-partition = &slot0_partition;
partitions {
#address-cells = <1>;
#size-cells = <1>;
boot_partition: partition@0 {
label = "mcuboot";
reg = <0x000000000 0x0000C000>;
slot0_partition: partition@c000 {
label = "image-0";
reg = <0x0000C000 0x00067000>;
slot1_partition: partition@73000 {
label = "image-1";
reg = <0x00073000 0x00067000>;
scratch_partition: partition@da000 {
label = "image-scratch";
reg = <0x000da000 0x0001e000>;
* The flash starting at 0x000f8000 and ending at
* 0x000fffff is reserved for use by the application.
* Storage partition will be used by FCB/LittleFS/NVS
* if enabled.
storage_partition: partition@f8000 {
label = "storage";
reg = <0x000f8000 0x00008000>;
};Combining 'mcuboot/zephyr/zephyr.hex' ... zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH' region `FLASH' overflowed by 27608 bytes
- What steps do I need to take to configure the MCUBoot for a custom board?
- Is defining the memory map in the .dst of the board not enough?
- Must I write an overlay for the Bootloader? If yes, how should it look like?
