RTC compare event
I am testing the RTC example in nRF5 SDK v17.1.0.
This example shows LED1 switching at a rate of 8 Hz and LED2 lighting up after 3 seconds.
This is confirmed.
The programme shows that the action after 3 seconds is performed by a compare event interrupt, but only one entry is made to this interrupt.
I would like to repeat this interrupt every three seconds to make LED2 blink, but please tell me exactly how to change the programme.
  • Hi there,
    You need to clear the counter and reset the compare interrupt like this:
     * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup rtc_example_main main.c
     * @ingroup rtc_example
     * @brief Real Time Counter Example Application main file.
     * This file contains the source code for a sample application using the Real Time Counter (RTC).
    #include "nrf.h"
    #include "nrf_gpio.h"
    #include "nrf_drv_rtc.h"
    #include "nrf_drv_clock.h"
    #include "boards.h"
    #include "app_error.h"
    #include <stdint.h>
    #include <stdbool.h>
    #define COMPARE_COUNTERTIME  (3UL)                                        /**< Get Compare event COMPARE_TIME seconds after the counter starts from 0. */
    #ifdef BSP_LED_0
        #define TICK_EVENT_OUTPUT     BSP_LED_0                                 /**< Pin number for indicating tick event. */
    #ifndef TICK_EVENT_OUTPUT
        #error "Please indicate output pin"
    #ifdef BSP_LED_1
        #define COMPARE_EVENT_OUTPUT   BSP_LED_1                                /**< Pin number for indicating compare event. */
    #ifndef COMPARE_EVENT_OUTPUT
    const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(0); /**< Declaring an instance of nrf_drv_rtc for RTC0. */
    /** @brief: Function for handling the RTC0 interrupts.
     * Triggered on TICK and COMPARE0 match.
    static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
        if (int_type == NRF_DRV_RTC_INT_COMPARE0)
            nrf_gpio_pin_toggle(COMPARE_EVENT_OUTPUT);
            nrf_drv_rtc_counter_clear(&rtc);
            int err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 8,true);
        else if (int_type == NRF_DRV_RTC_INT_TICK)
            nrf_gpio_pin_toggle(TICK_EVENT_OUTPUT);
    /** @brief Function configuring gpio for pin toggling.
    static void leds_config(void)
    /** @brief Function starting the internal LFCLK XTAL oscillator.
    static void lfclk_config(void)
        ret_code_t err_code = nrf_drv_clock_init();
    /** @brief Function initialization and configuration of RTC driver instance.
    static void rtc_config(void)
        uint32_t err_code;
        //Initialize RTC instance
        nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
        config.prescaler = 4095;
        err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
        //Enable tick event & interrupt
        nrf_drv_rtc_tick_enable(&rtc,true);
        //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
        //Power on RTC instance
        nrf_drv_rtc_enable(&rtc);
     * @brief Function for application main entry.
        leds_config();
        lfclk_config();
        rtc_config();
        while (true)
            __SEV();
            __WFE();
            __WFE();
    Alternatively:
        static int counter = 2;
            int err_code = nrf_drv_rtc_cc_set(&rtc,0,((COMPARE_COUNTERTIME * 8)*counter) % 0x1000000,true);
            counter++;
    regards
    Jared
  • Reply, thank you.
    Regarding the first example.
    Regarding clearing the counter in the interrupt and resetting the compare interrupt, I was trying the same code (two lines of the following).
    I just did not have the 'APP_ERROR_CHECK(err_code)' statement.
    The result was the same as when I did it, only one time into the 'if (int_type == NRF_DRV_RTC_INT_COMPARE0)' interrupt.
    Thanks to the 'err code' I could see that it was stopping at 'NRF_BREAKPOINT_COND' in 'app_error_weak.c', but the cause was not clear to me.
    Regarding the second example.
    This method worked.
    I would like to try to apply this method to change the repetition cycle and send packets in that cycle. By the way, when transmitting, I plan to use ESB for the protocol with low consumption.
    Strange, I tested this method and it worked for me. Could share the error message and check the return value from nrf_drv_rtc_cc_set()?
    This method worked.
    Good, then you have a working alternative Slight smile
    regards
    Jared
