Dear all,
I have pca10059 nrf52480 dongle which I accidentally erased and I could not upload any elf file to run moreover it was not blinking red anymore, no presence in system.
I managed to restore the bootloader with this procedure:
Thenafter, the dongle started to flash red again and I could flash the dongle with my custom blinky example and the diode was blinking again.
The problem I am facing now is, I want to have a look at the running process via OpenOCD, but anytime I start openocd with this command:
openocd -f rpi_as_debugger.cfg -c "transport select swd" -c "adapter speed 100" -f target/nrf52.cfg
I get following problem:
(THE DONGLE IS RUNNING JUST FINE, I CAN SEE THE DIODE BLINKING, BUT AFTER FIRMWARE RESTORATION, IT SEEMS THE CHIP IS LOCKED, BUT WHY? AFTER I RECEIVED THE DONGLE FROM MOUSER, I COULD EASILY DEBUG THE SAME EXAMPLE AND OPENOCD WAS NOT PRINTING ANY PROBLEM, ANYWAY I AM USING SWD OVER RASPBERRY)
Is the chip detecting any internal error at startup being the reason it gets locked?
Open On-Chip Debugger 0.11.0+dev-00651-g9de084e00 (2022-04-24-10:22)
Licensed under GNU GPL v2
For bug reports, read
openocd.org/.../bugs.html
BCM2835 GPIO nums: swclk = 24, swdio = 25
swd
adapter speed: 100 kHz
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : BCM2835 GPIO JTAG/SWD bitbang driver
Info : clock speed 1001 kHz
Info : SWD DPIDR 0x2ba01477
Error: [nrf52.cpu] Could not find MEM-AP to control the core
****** WARNING ******
nRF52 device has AP lock engaged (see UICR APPROTECT register).
Debug access is denied.
Use 'nrf52_recover' to erase and unlock the device.
Warn : target nrf52.cpu examination failed
Info : starting gdb server for nrf52.cpu on 3333
Info : Listening on port 3333 for gdb connections
During firmware restoration, I was also facing this, which I haven't a clue what it might be:
Warn : [nrf52.cpu] target was in unknown state when halt was requested
Error: Wrong parity detected
Thank you
