51822 bootloader setting
    recently I'm building dfu function on my board, using nrf51822 qfaa and softdevice s110.
Here is the situation, I get two 51822 modules:
-one is Raytac MDBT40, using nRF51822 QFAAH00, called A
-the other I'm not sure, using nRF51822 QFAAH10, called B
From Nordic document, the x in the build code is 0..9 for production release.
At first, I run dfu_dual_bank_ble sample code on 51DK. Here is the original bootloader address:
I got B module earlier than A. I change to custom board and change address:
It works well on B.
Then, I repeat the steps on A module. The same bootloader can be loaded to A, but it can't work, even advertising.
I've checked if I only load s110 and application, it works.
Is there something I misunderstood or miss checking?
Thank you very much.
  • Hi Edvin,
    So if you have an LFXTAL (32kHz physical xtal) with 20PPM accuracy, that is fine. If not, look in the enum from nrf_sdm.h, line 100, and find one entry that suits your HW. If you don't have an LFXTAL, try using NRF_CLOCK_LFCLKSRC_RC_250_PPM_250MS_CALIBRATION.
    I've changed it into "NRF_CLOCK_LFCLKSRC_RC_250_PPM_4000MS_CALIBRATION" already.
    If that doesn't work, then have you tried debugging? Try setting a breakpoint in the main() function of the bootloader. What happens? Is it reached?`Try to compare the working and non working device, and see if you see any difference in behavior.
    Yes, I just use debug mode for a while. It stops and shows this error when the code comes to nrf_delay.h.
    The other module, which can work well, stops at other place.
    I think there are answers about these errors in devzone, but I haven't figure it out yet.
  • How have you connected the programmer to your boards, and what programmer are you using?
  • Hi Edvin,
      I use either Keil or nrfgo studio through Jlink.
      If I try to use programmer in nrf connect for desktop, it cannot read my board. It might be some problem which I haven't figure out yet.
  • Have you tried using nrfjprog (nrf command line tools)
    But you never see these JLink - Cortex-M Error when you debug your application (without bootloader)?
    When you try to debug the bootloader, does the JLink error come immediately, or does it reach the main() function first?
  • Hi Edvin,
      Raytac engineer helps me to find out a little different.
    In my project which is transformed from SDK sample code, I use these argument setting:
    And these are Raytac engineer using (I was told that he uses SDK, too):
    So, I try the following 3 argument settings:
    1. --family NRF51 --program "#H"     ➜ I use at first
    2. --reset --program "#H"         ➜ Raytac uses
    3. --reset --family NRF51 --program "#H     ➜ I mix 1 & 2
    Both setting 2 and 3 lead modules to work.
    After I turn back to try setting 1, modules work, too.
    It seems there is something wrong if I keep using setting 1; and in 2 or 3 Keil fixes the problems.
    Thank you for your help.
