I'm trying to build the smp_svr example design: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/README.html#smp-svr-sample
I'm targeting Thingy52, although the board isn't officially supported for the design. My goal is to build a design that can perform Firmware Over The Air updates. I'm using nRF Connect SDK v1.9.1.
I get this error when building:
[258/268] Linking C executable zephyr/zephyr_pre0.elf FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/wshum/nordic_apps/smp_svr/build/mcuboot/zephyr/zephyr_pre0.map : && ccache /opt/nordic/ncs/v1.9.1/toolchain/bin/arm-none-eabi-gcc zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -fuse-ld=bfd -Wl,-T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/Users/wshum/nordic_apps/smp_svr/build/mcuboot/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/boards/boards/arm/thingy52_nrf52832/libboards__arm__thingy52_nrf52832.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/regulator/libdrivers__regulator.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/mbedtls/libmodules__mbedtls.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/segger/libmodules__segger.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L"/opt/nordic/ncs/v1.9.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v7e-m/nofp" -L/Users/wshum/nordic_apps/smp_svr/build/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a -no-pie -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn && cd /Users/wshum/nordic_apps/smp_svr/build/mcuboot/zephyr && /opt/nordic/ncs/v1.9.1/toolchain/Cellar/cmake/3.21.1/bin/cmake -E echo /opt/nordic/ncs/v1.9.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.bfd: zephyr/drivers/regulator/libdrivers__regulator.a(regulator_fixed.c.obj):(.rodata.regulator_2_cfg+0xc): undefined reference to `__device_dts_ord_8' /opt/nordic/ncs/v1.9.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.bfd: zephyr/drivers/regulator/libdrivers__regulator.a(regulator_fixed.c.obj):(.rodata.regulator_3_cfg+0xc): undefined reference to `__device_dts_ord_8' /opt/nordic/ncs/v1.9.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.bfd: zephyr/drivers/regulator/libdrivers__regulator.a(regulator_fixed.c.obj):(.rodata.regulator_4_cfg+0xc): undefined reference to `__device_dts_ord_8' collect2: error: ld returned 1 exit status ninja: build stopped: subcommand failed.
I found this issue which looks related, but it just seems like the test got disabled: https://github.com/zephyrproject-rtos/zephyr/issues/41418
