Hello.
I written code for nRF51822 w/ MPU6050 in S110(8.0.0) and Keil.
I tried to setup gyro as bellow.
twi_master_init(); => mpu6050_init(MOTION_SENSOR_ADDRESS); => mpu6050_register_write(0x6b, 0x00); // Kick out sleep mode. => mpu6050_register_write(0x6c, 0x00); // Activate Acc & Gyro. => mpu6050_register_read(ACCEL_XOUT_H, buf, 14); // <= Hardfault Error w/ Reboot Device.
I checked debuger, break at HardFault_Handler in arm_startup_nrf51.s
Why occure HardFault and how can I solve this problem?
I attached full source code.
Thank you.
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved. *
- The information contained herein is property of Nordic Semiconductor ASA.
- Terms and conditions of usage are described in detail in NORDIC
- SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
- Licensees are granted free, non-transferable use of the information. NO
- WARRANTY of ANY KIND is provided. This heading must NOT be removed from
- the file.
/** @file *
- @defgroup ble_sdk_uart_over_ble_main main.c
- @ingroup ble_sdk_app_nus_eval
- @brief UART over BLE application main file.
- This file contains the source code for a sample application that uses the Nordic UART service.
- This application uses the @ref srvlib_conn_params module. */
#include <stdint.h> #include <string.h> #include "nordic_common.h" #include "nrf.h" #include "nrf51_bitfields.h" #include "ble_hci.h" #include "ble_advdata.h" #include "ble_conn_params.h" #include "softdevice_handler.h" #include "app_timer.h" #include "app_gpiote.h" #include "app_button.h" #include "ble_nus.h" #include "app_uart.h" #include "app_util_platform.h" #include "bsp.h"
// For Gyro Scope. #include "mpu6050.h" #include "twi_master.h"
#define IS_SRVC_CHANGED_CHARACT_PRESENT 0 /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
#define WAKEUP_BUTTON_ID 0 /**< Button used to wake up the application. */
#define DEVICE_NAME "IE Love" /**< Name of device. Will be included in the advertising data. */
#define APP_ADV_INTERVAL 64 /< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */ #define APP_ADV_TIMEOUT_IN_SECONDS 180 /< The advertising timeout (in units of seconds). */
#define APP_TIMER_PRESCALER 0 /< Value of the RTC1 PRESCALER register. */ #define APP_TIMER_MAX_TIMERS (2 + BSP_APP_TIMERS_NUMBER) /< Maximum number of simultaneously created timers. */ #define APP_TIMER_OP_QUEUE_SIZE 4 /**< Size of timer operation queues. */
#define APP_GPIOTE_MAX_USERS 1 /**< Maximum number of simultaneously GPIOTE users. */
// Motion Sensor Detection Interval #define MOTION_SENSOR_INTERVAL APP_TIMER_TICKS(300, APP_TIMER_PRESCALER) /**< RR interval interval (ticks). */ #define MOTION_SENSOR_ADDRESS (0x68U)
//----------------------------------------------------------------------------- // Register map for Mation Sensor //----------------------------------------------------------------------------- #define MPU_CONFIG 0x1A #define GYRO_CONFIG 0x1B #define ACCEL_CONFIG 0x1C #define ZRMOT_THR 0x21 #define ZRMOT_DUR 0x22 #define ACCEL_XOUT_H 0x3B #define ACCEL_XOUT_L 0x3C #define ACCEL_YOUT_H 0x3D #define ACCEL_YOUT_L 0x3E #define ACCEL_ZOUT_H 0x3F #define ACCEL_ZOUT_L 0x40 #define TEMP_OUT_H 0x41 #define TEMP_OUT_L 0x42 #define ANGLE_XOUT_H 0x43 #define ANGLE_XOUT_L 0x44 #define ANGLE_YOUT_H 0x45 #define ANGLE_YOUT_L 0x46 #define ANGLE_ZOUT_H 0x47 #define ANGLE_ZOUT_L 0x48 #define INT_PIN_CFG 0x37 #define INT_ENABLE 0x38 #define INT_STATUS 0x3A #define MOT_DETECT_STATUS 0x61 #define MOT_DETECT_CTRL 0x69 #define PWR_MGMT_1 0x6B #define PWR_MGMT_2 0x6C #define MPU_WHO_AM_I 0x75
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */ #define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */ #define SLAVE_LATENCY 0 /< Slave latency. */ #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */ #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */ #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */ #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50, APP_TIMER_PRESCALER) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define SEC_PARAM_BOND 1 /< Perform bonding. */ #define SEC_PARAM_MITM 0 /< Man In The Middle protection not required. */ #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /< No I/O capabilities. */ #define SEC_PARAM_OOB 0 /< Out Of Band data not available. */ #define SEC_PARAM_MIN_KEY_SIZE 7 /< Minimum encryption key size. */ #define SEC_PARAM_MAX_KEY_SIZE 16 /< Maximum encryption key size. */
#define START_STRING "Start...\n" /**< The string that will be sent over the UART when the application starts. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /< UART TX buffer size. */ #define UART_RX_BUF_SIZE 256 /< UART RX buffer size. */
const static uint8_t s_register_config[][2] = { { PWR_MGMT_1, 0x00 } };
static app_timer_id_t m_motion_sensor_timer_id; /< Motion Sensor timer. */ static ble_gap_sec_params_t m_sec_params; /< Security requirements for this application. */ static ble_nus_t m_nus; /< Structure to identify the Nordic UART Service. */ static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /< Handle of the current connection. */
- Holds sensor 3 axes values
- May hold the sensor data itself or may be used to specify sensor axes attribute (deadband, offset...) */ typedef struct { int16_t X; //!< Data pertaining to the X axis int16_t Y; //!< Data pertaining to the Y axis int16_t Z; //!< Data pertaining to the Z axis } t_struct_Motion_SensorAxis;
typedef struct { t_struct_Motion_SensorAxis GyroSamples; t_struct_Motion_SensorAxis AccSamples; int16_t Temp; }t_struct_Motion_Sensor;
uint32_t drv_gyro_read(t_struct_Motion_Sensor* p_samples) { bool success = true; uint8_t buf[20];
success &= mpu6050_register_read(ACCEL_XOUT_H, buf, 14);
/*success &= mpu6050_register_read(ANGLE_XOUT_H, buf, 1);
success &= mpu6050_register_read(ANGLE_XOUT_L, buf+1, 1);
success &= mpu6050_register_read(ANGLE_YOUT_H, buf+2, 1);
success &= mpu6050_register_read(ANGLE_YOUT_L, buf+3, 1);
success &= mpu6050_register_read(ANGLE_ZOUT_H, buf+4, 1);
success &= mpu6050_register_read(ANGLE_ZOUT_L, buf+5, 1);
success &= mpu6050_register_read(TEMP_OUT_H, buf+6, 1);
success &= mpu6050_register_read(TEMP_OUT_L, buf+7, 1);
success &= mpu6050_register_read(ACCEL_XOUT_H, buf+8, 1);
success &= mpu6050_register_read(ACCEL_XOUT_L, buf+9, 1);
success &= mpu6050_register_read(ACCEL_YOUT_H, buf+10, 1);
success &= mpu6050_register_read(ACCEL_YOUT_L, buf+11, 1);
success &= mpu6050_register_read(ACCEL_ZOUT_H, buf+12, 1);
success &= mpu6050_register_read(ACCEL_ZOUT_L, buf+13, 1);*/
if (!success)
return NRF_ERROR_INTERNAL;
p_samples->AccSamples.X = ((buf[0] << 8) | buf[1]); p_samples->AccSamples.Y = ((buf[2] << 8) | buf[3]); p_samples->AccSamples.Z = ((buf[4] << 8) | buf[5]); p_samples->Temp = ((buf[6] << 8) | buf[7]); p_samples->GyroSamples.X = ((buf[8] << 8) | buf[9]); p_samples->GyroSamples.Y = ((buf[10] << 8) | buf[11]); p_samples->GyroSamples.Z = ((buf[12] << 8) | buf[13]);
return NRF_SUCCESS;
/**@brief Function for assert macro callback. *
- @details This function will be called in case of an assert in the SoftDevice.
- @warning This handler is an example only and does not fit a final product. You need to analyse
how your product is supposed to react in case of Assert. - @warning On assert from the SoftDevice, the system can only recover on reset.
- @param[in] line_num Line number of the failing ASSERT call.
- @param[in] p_file_name File name of the failing ASSERT call. */ void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name) { app_error_handler(DEAD_BEEF, line_num, p_file_name); }
/**@brief Function for the GAP initialization. *
- @details This function will set up all the necessary GAP (Generic Access Profile) parameters of
the device. It also sets the permissions and appearance.
*/ static void gap_params_init(void) { uint32_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for the Advertising functionality initialization. *
- @details Encodes the required advertising data and passes it to the stack.
Also builds a structure to be passed to the stack when starting the advertising.
*/ static void advertising_init(void) { uint32_t err_code; ble_advdata_t advdata; ble_advdata_t scanrsp; uint8_t flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
ble_uuid_t adv_uuids[] = {{BLE_UUID_NUS_SERVICE, m_nus.uuid_type}};
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_FULL_NAME;
advdata.include_appearance = false;
advdata.flags = flags;
memset(&scanrsp, 0, sizeof(scanrsp));
scanrsp.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
scanrsp.uuids_complete.p_uuids = adv_uuids;
err_code = ble_advdata_set(&advdata, &scanrsp);
/**@brief Function for handling the data from the Nordic UART Service. *
@details This function will process the data received from the Nordic UART BLE Service and send
it to the UART module. -
@param[in] p_nus Nordic UART Service structure.
@param[in] p_data Data to be send to UART module.
@param[in] length Length of the data. */ /**@snippet [Handling the data received over BLE] */ static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length) { uint32_t err_code; static uint8_t data_array[BLE_NUS_MAX_DATA_LEN]; t_struct_Motion_Sensor samples;
err_code = drv_gyro_read(&samples);
sprintf((char*)data_array, "%d %d %d %d %d %d", samples.GyroSamples.X, samples.GyroSamples.Y, samples.GyroSamples.Z, samples.AccSamples.X, samples.AccSamples.Y, samples.AccSamples.Z);
err_code = ble_nus_string_send(&m_nus, data_array, strlen((char*)data_array));
/strcpy((char)data_array, "IE Love");
err_code = ble_nus_string_send(&m_nus, data_array, strlen((char*)data_array));*/ if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); }
for (uint32_t i = 0; i < length; i++) { while (app_uart_put(p_data[i]) != NRF_SUCCESS); } while (app_uart_put('\n') != NRF_SUCCESS); } /**@snippet [Handling the data received over BLE] */
/**@brief Function for initializing services that will be used by the application. */ static void services_init(void) { uint32_t err_code; ble_nus_init_t nus_init;
/**@brief Function for initializing security parameters.
static void sec_params_init(void)
m_sec_params.bond = SEC_PARAM_BOND;
m_sec_params.mitm = SEC_PARAM_MITM;
m_sec_params.io_caps = SEC_PARAM_IO_CAPABILITIES;
m_sec_params.oob = SEC_PARAM_OOB;
m_sec_params.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
m_sec_params.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
/**@brief Function for handling an event from the Connection Parameters Module. *
@details This function will be called for all events in the Connection Parameters Module
which are passed to the application. -
@note All this function does is to disconnect. This could have been done by simply setting
the disconnect_on_fail config parameter, but instead we use the event handler -
mechanism to demonstrate its use. -
@param[in] p_evt Event received from the Connection Parameters Module. */ static void on_conn_params_evt(ble_conn_params_evt_t * p_evt) { uint32_t err_code;
if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) { err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE); APP_ERROR_CHECK(err_code); } }
/**@brief Function for handling errors from the Connection Parameters module. *
- @param[in] nrf_error Error code containing information about what went wrong. */ static void conn_params_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); }
/**@brief Function for initializing the Connection Parameters module. */ static void conn_params_init(void) { uint32_t err_code; ble_conn_params_init_t cp_init;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for starting advertising. */ static void advertising_start(void) { uint32_t err_code; ble_gap_adv_params_t adv_params;
// Start advertising.
memset(&adv_params, 0, sizeof(adv_params));
adv_params.type = BLE_GAP_ADV_TYPE_ADV_IND;
adv_params.p_peer_addr = NULL;
adv_params.fp = BLE_GAP_ADV_FP_ANY;
adv_params.interval = APP_ADV_INTERVAL;
adv_params.timeout = APP_ADV_TIMEOUT_IN_SECONDS;
err_code = sd_ble_gap_adv_start(&adv_params);
/**@brief Function for starting application timers. */ static void application_timers_start(void) { uint32_t err_code;
// Start application timers.
err_code = app_timer_start(m_motion_sensor_timer_id, MOTION_SENSOR_INTERVAL, NULL);
/**@brief Function for stop application timers. */ static void application_timers_stop(void) { uint32_t err_code;
err_code = app_timer_stop(m_motion_sensor_timer_id);
/**@brief Function for the Application's S110 SoftDevice event handler. *
@param[in] p_ble_evt S110 SoftDevice event. */ static void on_ble_evt(ble_evt_t * p_ble_evt) { uint32_t err_code; static ble_gap_sec_keyset_t s_sec_keyset; ble_gap_enc_info_t * p_enc_info;
switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: err_code = bsp_indication_set(BSP_INDICATE_CONNECTED); APP_ERROR_CHECK(err_code); m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle; //application_timers_start(); break;
case BLE_GAP_EVT_DISCONNECTED: err_code = bsp_indication_set(BSP_INDICATE_IDLE); APP_ERROR_CHECK(err_code); m_conn_handle = BLE_CONN_HANDLE_INVALID; //application_timers_stop(); advertising_start(); break; case BLE_GAP_EVT_SEC_PARAMS_REQUEST: s_sec_keyset.keys_periph.p_enc_key = NULL; err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_SUCCESS, &m_sec_params, &s_sec_keyset); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_SYS_ATTR_MISSING: err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_AUTH_STATUS: // TODO: Adoptation to s110v8.0.0, is this needed anymore ? break; case BLE_GAP_EVT_SEC_INFO_REQUEST: if (s_sec_keyset.keys_periph.p_enc_key != NULL) { p_enc_info = &s_sec_keyset.keys_periph.p_enc_key->enc_info; err_code = sd_ble_gap_sec_info_reply(m_conn_handle, p_enc_info, NULL, NULL); APP_ERROR_CHECK(err_code); } else { // No keys found for this device. err_code = sd_ble_gap_sec_info_reply(m_conn_handle, NULL, NULL, NULL); APP_ERROR_CHECK(err_code); } break; case BLE_GAP_EVT_TIMEOUT: if (p_ble_evt->evt.gap_evt.params.timeout.src == BLE_GAP_TIMEOUT_SRC_ADVERTISING) { err_code = bsp_indication_set(BSP_INDICATE_IDLE); APP_ERROR_CHECK(err_code); // Configure buttons with sense level low as wakeup source. err_code = bsp_buttons_enable(1 << WAKEUP_BUTTON_ID); APP_ERROR_CHECK(err_code); // Go to system-off mode (this function will not return; wakeup will cause a reset). err_code = sd_power_system_off(); APP_ERROR_CHECK(err_code); } break; default: // No implementation needed. break;} }
/**@brief Function for dispatching a S110 SoftDevice event to all modules with a S110 SoftDevice
event handler. - @details This function is called from the S110 SoftDevice event interrupt handler after a S110
SoftDevice event has been received. - @param[in] p_ble_evt S110 SoftDevice event. */ static void ble_evt_dispatch(ble_evt_t * p_ble_evt) { ble_conn_params_on_ble_evt(p_ble_evt); ble_nus_on_ble_evt(&m_nus, p_ble_evt); on_ble_evt(p_ble_evt); }
/**@brief Function for the S110 SoftDevice initialization. *
@details This function initializes the S110 SoftDevice and the BLE event interrupt. */ static void ble_stack_init(void) { uint32_t err_code;
// Initialize SoftDevice. SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
// Enable BLE stack. ble_enable_params_t ble_enable_params; memset(&ble_enable_params, 0, sizeof(ble_enable_params)); ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT; err_code = sd_ble_enable(&ble_enable_params); APP_ERROR_CHECK(err_code);
// Subscribe for BLE events. err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch); APP_ERROR_CHECK(err_code); }
/**@brief Function for placing the application in low power state while waiting for events. */ static void power_manage(void) { uint32_t err_code = sd_app_evt_wait(); APP_ERROR_CHECK(err_code); }
/**@brief Function for handling the Heart rate measurement timer timeout. *
- @details This function will be called each time the heart rate measurement timer expires.
It will exclude RR Interval data from every third measurement. - @param[in] p_context Pointer used for passing some arbitrary information (context) from the
app_start_timer() call to the timeout handler.
*/ static void motion_sensor_handler(void * p_context) { // Get Value of Motion Sensor. static uint8_t data_array[BLE_NUS_MAX_DATA_LEN]; uint32_t err_code; t_struct_Motion_Sensor samples;
UNUSED_PARAMETER(p_context);
//strcpy((char*)data_array, "IE Love");
/**@brief Function for the Timer initialization. *
@details Initializes the timer module. This creates and starts application timers. */ static void timers_init(void) { uint32_t err_code;
// Initialize timer module. APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, false);
// Create timers. err_code = app_timer_create(&m_motion_sensor_timer_id, APP_TIMER_MODE_REPEATED, motion_sensor_handler); APP_ERROR_CHECK(err_code); }
/**@brief Function for handling app_uart events. *
- @details This function will receive a single character from the app_uart module and append it to
a string. The string will be be sent over BLE when the last character received was a -
'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of -
@ref NUS_MAX_DATA_LENGTH.
*/ /**@snippet [Handling the data received over UART] */ void uart_event_handle(app_uart_evt_t * p_event) { static uint8_t data_array[BLE_NUS_MAX_DATA_LEN]; static uint8_t index = 0; uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
err_code = ble_nus_string_send(&m_nus, data_array, index);
index = 0;
case APP_UART_FIFO_ERROR:
} /**@snippet [Handling the data received over UART] */
/@brief Function for initializing the UART module. */ /@snippet [UART Initialization] */ static void uart_init(void) { uint32_t err_code; const app_uart_comm_params_t comm_params = { RX_PIN_NUMBER, TX_PIN_NUMBER, RTS_PIN_NUMBER, CTS_PIN_NUMBER, APP_UART_FLOW_CONTROL_ENABLED, false, UART_BAUDRATE_BAUDRATE_Baud38400 };
APP_UART_FIFO_INIT( &comm_params,
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOW,
err_code);
} /**@snippet [UART Initialization] */
/**@brief Application main function. */ int main(void) { uint8_t start_string[] = START_STRING; uint32_t err_code;
// Initialize.
APP_GPIOTE_INIT(APP_GPIOTE_MAX_USERS);
ble_stack_init();
// Init Timer.
//timers_init();
uart_init();
err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
NULL);
gap_params_init();
services_init();
advertising_init();
conn_params_init();
sec_params_init();
// For Gyroscope.
twi_master_init();
/*nrf_gpio_port_dir_set(NRF_GPIO_PORT_SELECT_PORT1, NRF_GPIO_PORT_DIR_OUTPUT);
if (!twi_master_init())
nrf_gpio_port_write(NRF_GPIO_PORT_SELECT_PORT1, 0x55);
/*uint32_t i =0;
bool transfer_succeeded;
for (i = 0; i < (sizeof(s_register_config) / sizeof(s_register_config[0])); ++i)
uint8_t read;
transfer_succeeded &= mpu6050_register_write(s_register_config[i][0], s_register_config[i][1]);
transfer_succeeded &= mpu6050_register_read(s_register_config[i][0], &read, sizeof(read));
transfer_succeeded &= (s_register_config[i][1] == read);
if(!mpu6050_verify_product_id())
printf("Error Verify Product ID.\n");
printf("%s",start_string);
// Enter main loop.
for (;;)
power_manage();
