hello,
Im using nrf52840 Im trying to emulate a chip select signal for spi slave with gpiote and ppi. I used an active high signal as an event and a signal(cs) that is toggled on any event signal edge. i then connected the task and event using ppi. while testing, I notice that the cs pin takes a little more time than expected to toggle which corrupts data received by spis. reading the ppi section in the datasheet i noticed this sentence "while other asynchronous events will be delayed by up to one 16 MHz clock period." does this mean that there is a 1 clock delay between event and task ? and would this be the reason for the problem Im facing?
i dont know if i made my question clear enough. if there are any questions i would be happy to elaborate a bit more
