non-connectable undirected advertising
Hello
I enable BT advertising with the option  BT_GAP_ADV_TYPE_ADV_NONCONN_IND
#define BT_LE_ADV_NCONN_IND BT_LE_ADV_PARAM(BT_GAP_ADV_TYPE_ADV_NONCONN_IND, \
                         BT_GAP_ADV_FAST_INT_MIN_2, \
                         BT_GAP_ADV_FAST_INT_MAX_2, \
                         NULL)
const struct bt_data scan_resp[] = {
        BT_DATA(BT_DATA_NAME_COMPLETE, beacon_name, strlen(beacon_name)),
err = bt_le_adv_start(BT_LE_ADV_NCONN_IND,adv, ARRAY_SIZE(adv),scan_resp, ARRAY_SIZE(adv));
This works but the device appears as "connectable undirected" in the BT scanner tool
What options should I use for the device to appear as "non-connectable undirected" ?
Thank you
  • Hi, I heard back from the development team. on this issue. You should only use the parameter values supported for a parameter and not the BT GAP Advertising Type. The advertising options should be better suited here. If no options are set (set to 0 or BT_LE_ADV_OPT_NONE) the advertising is non-connectable. You should set BT_LE_ADV_OPT_CONNECTABLE to make an advertisement connectable.
    All advertising options can be found here. BT_GAP_ADV_TYPE_ADV_NONCONN_IND is not the value to be used for options parameters in the API, and you shouldn't use any value for the bt_le_adv_start API's option field of the "bt_le_adv_param" parameter.
    Simon
