nRF5SDK1702d674dde radio_test example question
hi,i use radio_test example for radio test.If I don't make any changes, the routine can run well, but a PA chip is added to my product to amplify the RF signal. The PA / LNA chip has two control pins pin16 and pin21. When transmitting, it is necessary to pull pin16 (TX) high and pin21 low. If I do not configure these two pins, the measured waveform is normal, but if I configure these two pins as output, and pull pin16 high and pin21 low during main initialization (because I only need to test). The measured RF waveform becomes very messy. I initially suspect that this pin pin16 is used in the routine, resulting in the abnormal operation of PA. But I can't find anywhere in the code to control this pin. Can you help me confirm whether this pin is used in this routine? The chip I use is Nordic 52832
thanks ,
  • added .i use start tx modulated carrier cmd for test,start channel  = 0 ,end channel = 0,data_rate  = ble_2Mbit
    Q1: Which nRF5 SDK version are you using?
    Q2: What do you mean by "messy" ? Can you share an image of before and after?
    P0.21 is by default setup to be nRESET, and you should not use this pin unless you have setup your project to use P0.21 as a generic GPIO and not nRESET.
    Håkon
