Unable to build sample application on Windows
I installed nRF Connect SDK (1.9.1) using Toolchain Manager v0.10.3, and nRF Connect for Desktop v3.11.0. Before that I also installed NRF command line tools 10.15.4.
My OS is Windows 10.
I installed VS Code 1.67.0 and all extensions that the Toolchain Manager recommended. The extensions were installed from within the Toolchain manager.
All this is a new install. I never used the Nordic SDK before.
I installed the SDK in c:\nordic\ncs
In VSCode, I performed the quick setup:
After that I created a Freestanding application from a sample. The application location is c:\nordic\myapps and the application name is lpuart-test. The application was created Ok.
But when I tried to create build configuration and build it, the build step fails with this error:
> Executing task: nRF Connect: Generate config nrf52833dongle_nrf52833 for c:\nordic\myapps\lpuart-test <
Building lpuart-test
west build --build-dir c:\nordic\myapps\lpuart-test\build c:\nordic\myapps\lpuart-test --pristine --board nrf52833dongle_nrf52833 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DBOARD_ROOT:STRING="c:/nordic/myapps/lpuart-test"
usage: west [-h] [-z ZEPHYR_BASE] [-v] [-V] <command> ...
west: error: argument <command>: invalid choice: 'build' (choose from 'init', 'update', 'list', 'manifest', 'diff', 'status', 'forall', 'help', 'config', 'topdir', 'selfupdate')
The terminal process terminated with exit code: 2.
This seems to be exactly the same problem as mentioned here (for OS X):
devzone.nordicsemi.com/.../can-t-build-example-application-in-visual-studio-code-osx
That post mentions about invoking "west init". I tried to invoke west, but it complains the Python is not found.
What do I need to do in order to resolve the above? I just want to build one the provided sample applications.
Thank you,
D.
  • Hello D.
    This is a strange behavior.
    Did you try this within the Command Prompt or Git bash from the Toolchain Manager dropdown menu?
    Øyvind
  • A small correction, open Command prompt or git bash from the Toolchain Manager and try running
    ncsmgr init-ncs
  • Hello Øyvind,
    Yes, I tried but it fails:
    501@c-DF0V MINGW64 /c/nordic/myapps/lpuart-test
    $ west init
    FATAL ERROR: already initialized in C:\nordic\ncs\v1.9.1, aborting.
    Note:
    In your environment, ZEPHYR_BASE is set to:
    C:/nordic/ncs/v1.9.1/zephyr
    This forces west to search for a workspace there.
    Try unsetting ZEPHYR_BASE and re-running this command.
    I also tried unsetting ZEPHYR_BASE as it recommended. I unset it in the terminal window. Then west init worked and completed Ok. I opened VS Code again, but the problem is still there. I also tried updating the Quick Configuration - set the SDK to be the one that west init downloaded in my sample application folder. Still the same error.
    What else can I try?
    Yesterday, I also tried removing everything (SDK and all supporting software that I installed), including cleaning all user directories that were created. Then re-installing again. No luck - the error is still there.
    Thank you,
    D.
  • I tried it - from the Toolchain Manager, I opened Bash window and then I executed ncsmgr init-ncs:
    NCS repositories are not yet cloned here. To do so run the following command:
    ncsmgr init-ncs
    501@c-DF0V MINGW64 /c/nordic/ncs/v1.9.1
    $ ncsmgr init-ncs
    Checking out NCS v1.9.1 ...FATAL ERROR: already initialized in C:\nordic\ncs\v1.9.1, aborting.
    Note:
    HEAD is now at 126fad0e2 manifest: update manifest file with 1.9.1 tags
    /C/nordic/ncs/v1.9.1
    done
    Updating repos ...
    done
    It is says that the NCS repositories are not cloned yet, but after I tried to run init-ncs it says that is is already initialized?!
  • Thanks for testing. Could you please try to run the following command in the VS Code Command Palette: nrf Connect: Generate Support Information and provide the information here as a .txt file or using Insert --> Code.
