Can't Debug with image including MCUBoot Bootloader
I am trying to work with the MCUBoot bootloader in my project. I was able to configure and build my project and it appears to run properly when I flash it to the chip directly. However when I try to debug it I get the following error:
Run to 'main' timed out. Trying to pause program
The full debug console output was as follows:
Launching gdb-server: "C:\\Program Files (x86)\\SEGGER\\JLink\\JLinkGDBServerCL.exe" -singlerun -nogui -if swd -port 50000 -swoport 50001 -telnetport 50002 -device nRF52832_xxAA -select usb=682211915 -rtos "C:\\Program Files (x86)\\SEGGER\\JLink\\GDBServer\\RTOSPlugin_Zephyr.dll"
Please check TERMINAL tab (gdb-server) for output from C:\Program Files (x86)\SEGGER\JLink\JLinkGDBServerCL.exe
Finished reading symbols from objdump: Time: 63 ms
Finished reading symbols from nm: Time: 60 ms
Reading symbols from c:\Soberlink\soberlink_sfw\trunk_NordicBLE\SL_Connect_ST\build_connect\zephyr\merged.hex...
(No debugging symbols found in c:\Soberlink\soberlink_sfw\trunk_NordicBLE\SL_Connect_ST\build_connect\zephyr\merged.hex)
WARNING: Cortex-Debug will deprecate use of GDB version 8 after July 2022. Please upgrade to version 9+
0x0002e6a2 in ?? ()
Program stopped, probably due to a reset and/or halt issued by debugger
add symbol table from file "c:/Soberlink/soberlink_sfw/trunk_NordicBLE/SL_Connect_ST/build_connect/zephyr/zephyr.elf"
(y or n) [answered Y; input not from terminal]
Reading symbols from c:/Soberlink/soberlink_sfw/trunk_NordicBLE/SL_Connect_ST/build_connect/zephyr/zephyr.elf...
add symbol table from file "c:/Soberlink/soberlink_sfw/trunk_NordicBLE/SL_Connect_ST/build_connect/mcuboot/zephyr/zephyr.elf"
Reading symbols from c:/Soberlink/soberlink_sfw/trunk_NordicBLE/SL_Connect_ST/build_connect/mcuboot/zephyr/zephyr.elf...
2 Resetting target
[New Thread 536878408]
[New Thread 536877856]
[Switching to Thread 536878408]
Reading symbols from c:\nordicsemi\v1.9.1\toolchain\opt\bin\arm-none-eabi-objdump.exe --syms -C -h -w c:\Soberlink\soberlink_sfw\trunk_NordicBLE\SL_Connect_ST\build_connect\zephyr\merged.hex
Reading symbols from c:/nordicsemi\v1.9.1\toolchain\opt\bin\arm-none-eabi-nm.exe --defined-only -S -l -C -p c:\Soberlink\soberlink_sfw\trunk_NordicBLE\SL_Connect_ST\build_connect\zephyr\merged.hex
Launching GDB: "c:\\nordicsemi\\v1.9.1\\toolchain\\opt\\bin\\arm-none-eabi-gdb.exe" -q --interpreter=mi2 "c:\\Soberlink\\soberlink_sfw\\trunk_NordicBLE\\SL_Connect_ST\\build_connect\\zephyr\\merged.hex"
Set "showDevDebugOutput": true in your "launch.json" to see verbose GDB transactions here. Helpful to debug issues or report problems
I even tried to use a standard example (BLE peripheral) and got the same results. Any suggestions what could causing the bootloader to hang only while debugging?
Thanks and regards,
Pam
  • Hi Pam,
    I have not been able to reproduce this. Just to check that the tools are in place, can you try building the unmodified smp_svr sample with overlay-bt.conf and ensure you check the "Enable debug options" checkbox? Does debugging work then? (On my end, using the latest VS Code (1.67.1), nRF Connect for VS Code plugin (v2022.4.219) and nRF Connect SDK 1.9.1 this works out of the box.)
    If this works, then we can look at your project (though I see you wrote that you tested with another sample - which, and with which modifications and build configuration)? If this also fails, we should look at your development environment configuration.
    Einar
  • Hi Einar,
    I wasn't able to get the "overlay-bt.conf" version of the project to build because it is too large for the NRF52832. However I did get the "overlay-bt-tiny.conf" and the "overlay-serial.conf" versions to build and run on the dev board.
    After referencing this sample project I tweaked my own project and was able to get it to download and successfully run as well with the debugger. Although it doesn't work consistently, sometimes there are issues where it gets "stuck" and never makes it out of the bootloader after the download. I'm still trying to identify the exact problem, but maybe it's related to the state of the chip along with the external hardware on the board?
    I will try to see if I can get somewhere on the DFU design in my project. Is there any documentation on the SMP protocol if I end up using that versus something custom? The update image is being transferred via the UART from a different processor in our device so the application on the Nordic chip just has to write the new image to flash and initiate the switch/update via the bootloader.
    Pam
  • Hi Pam,
    That is good to hear.
    That could be. It id difficult to say without knowing more. It could make sense to debug to bootloader to see what state it is in when it is seemingly stuck.
    The Simple Management Protocol (SMP) protocol comes from the mcumgr project. The documentation is unfortunately sparse, though. Or as they put it in the mcumgr documentation: "Information and documentation for mcumgr is stored within the source". There is a small chapter on the protocol, though.
    Einar
  • Hi Einar,
    I am still having a problem with debugging when the "mcuboot" is included in my build. I don't experience these issues when the bootloader is not included. Here is some of the output from the debug console window when the debugger stalls (after the code is downloaded).
    2
    Resetting target
    [New Thread 536878448]
    [New Thread 536877896]
    [Switching to Thread 536878448]
    GDB never responded to an interrupt request. Trying to end session anyways
    Could there be a RAM issue perhaps causing it to have difficulty switching threads? I'm struggling with how to debug this, I don't see an easy way to work with any type of debugging in the bootloader.
    Any help would be great. I can get it to work when I select "Recover Board" via the connected JTAG device just before the download. But I have to do this every time to get it to work.
    Thanks for your help and best regards,
    Pam
  • Hi Einar,
    It seems like a Visual Studio or Zephyr bug of some sort. See the case below, this is the exact issue I have run across. I'll work around it for now as suggested by using a build without the debug option selected or incorporate multiple threads.
    https://devzone.nordicsemi.com/f/nordic-q-a/79881/unable-to-use-debugger-in-vs-code-using-nrf-connect/330690#330690
    Thanks and regards,
    Pam
