NCS 1.9.99: How to set sda and scl pins for I2C
With an earlier version of NCS  I could set the sda and scl pins using an overlay file:
boards/nrf52840dk_nrf52840.overlay:
&i2c0 {
    status = "okay";
    sda-pin = < 45 >;
    scl-pin = < 47 >;
    sht3xd@45 {
		compatible = "sensirion,sht3xd";
		reg = <0x45>;
		label = "SHT3XD";
		alert-gpios = <&gpio1 10 GPIO_ACTIVE_HIGH>;
With NCS 1.9.99 I get this error:
In file included from /home/k/ncs1999/zephyr/include/zephyr/toolchain.h:50,
                 from /home/k/ncs1999/zephyr/include/zephyr/init.h:10,
                 from /home/k/ncs1999/zephyr/include/zephyr/device.h:29,
                 from /home/k/ncs1999/zephyr/include/zephyr/drivers/i2c.h:23,
                 from /home/k/ncs1999/zephyr/drivers/i2c/i2c_nrfx_twim.c:8:
/home/k/ncs1999/zephyr/include/zephyr/toolchain/gcc.h:77:36: error: static assertion failed: "/soc/i2c@40003000 has legacy *-pin properties defined although PINCTRL is enabled"
   77 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
/home/k/ncs1999/zephyr/soc/arm/nordic_nrf/common/./soc_nrf_common.h:229:2: note: in expansion of macro 'BUILD_ASSERT'
  229 |  BUILD_ASSERT(!IS_ENABLED(CONFIG_PINCTRL) ||   \
/home/k/ncs1999/zephyr/drivers/i2c/i2c_nrfx_twim.c:396:2: note: in expansion of macro 'NRF_DT_CHECK_PIN_ASSIGNMENTS'
  396 |  NRF_DT_CHECK_PIN_ASSIGNMENTS(I2C(idx), 1, scl_pin, sda_pin);        \
/home/k/ncs1999/zephyr/drivers/i2c/i2c_nrfx_twim.c:448:1: note: in expansion of macro 'I2C_NRFX_TWIM_DEVICE'
  448 | I2C_NRFX_TWIM_DEVICE(0);
How do I change the sda and scl pin assignments using NCS 1.9.99?
Jan Erik
    please try:
    check the entire overlay file for blue line conflicts
    remove build, and add new
    Best regards
    The way pins are set has been changed for future releases, and this change is present on the devtag 1.9.99.
    Is there a reason that you are using 1.9.99, and not 1.9.1?
    On 1.9.1 you would not see these errors.
    I'm developing an environmental control system using openthread and zephyr COAP. The system works but intermittently the openthread connection detaches, then becomes leader, but won't rejoin the existing network. This will be challenging to debug as I haven't found a way to trigger the problem. As a first step in trouble shooting I wanted to use more recent versions of the libraries to see if the problem persists. I chose 1.9.99 since it will have the most recent versions of zephyr, openthread, and COAP.
    As you point out, the way pins are set was changed to pinctrl. I was able to get the sht3xd example to compile with this overlay below but it doesn't connect with the device.  I'll see if my original problem is solved with v1.9.1
    &pinctrl {
       i2c0_default_alt: i2c0_default_alt {
          group1 {
             psels = <NRF_PSEL(TWIM_SDA, 0, 45)>,
                     <NRF_PSEL(TWIM_SCL, 0, 47)>;
       i2c0_sleep_alt: i2c0_sleep_alt {
          group1 {
             low-power-enable;
    &i2c0 {
    	sht3xd@45 {
            status = "okay";
            pinctrl-0 = <&i2c0_default_alt>;
            pinctrl-1 = <&i2c0_sleep_alt>;
    		reg = <0x45>;
    		label = "SHT3XD";
  • Try putting the pinctrl-* fields outside of the sht3xd block. If that doesn't work, there should be a file at build/zephyr/include/generated called devicetree_unfixed.dts. Attach that here with Insert->Image/video/file and I'll take a look.
    Ok, so that's why you are looking into 1.9.99, makes sense. Make a ticket specifically for the openthread issues if you are unable to solve them, and we will do our best to assist you.
  • Thanks,  Øivind.  I followed your suggestion of putting the pinctrl-* fields outside of the sht3xd block.  I also needed to specify the pin numbers using the new convention instead of the old. In the old system port 1, pin 13  was pin 45 and port 1, pin 15 was pin 47 (pin was specified as pin number plus 0 for port 0 or plus 32 for port 1). Under pinctrl, the port and pin are separated so port 1, pin 13 should be specified as <NRF_PSEL(TWIM_SDA, 1, 13)>  not  <NRF_PSEL(TWIM_SDA, 0, 45)>.  You know all this, I'm just elaborating for someone else who might stumble upon this thread.
    The v1.9.99 SHT3XD sample now builds and runs correctly for me on the nrf52840dk with my target pins.
    I added nrf52840dk_nrf52840.overlay to the boards directory:
    &pinctrl {
          group1 {
             psels = <NRF_PSEL(TWIM_SDA, 1, 13)>,
                     <NRF_PSEL(TWIM_SCL, 1, 15)>;
          group1 {
             low-power-enable;
    &i2c0 {
    	sht3xd: sht3xd@45 {
            status = "okay";
    		reg = <0x45>;
    		label = "SHT3XD";
    I also made two changes to the main.c file:
    14d13
    < #define SHT3XD DT_NODELABEL(sht3xd)
    29c28
    < 	const struct device *dev = DEVICE_DT_GET(SHT3XD);
    > 	const struct device *dev = device_get_binding("SHT3XD");
