How to setup/use for nrf sniffer
Hello  Nordic Support.
I would like to build and use a Sniffer using a PC (Windows 10), nRF52DK, and nRFConnect for desktop.
Please teach me about the following.
nRFSniffer for Bluetooth LE V4.1.0 (4393_261 / 2021-11-08)
3.1 Programming the nRF Sniffer Firmware
Q1)
Where can I get the sniffer_nrf52dk_nrf52832 _ *. Hex for nRF52DK (PCA10040)?
1. 1. install nRF Connect Programmer.
Q2)
I have installed RF Connect Programmer for Desktop (V3.11.0)
The "Programmer app" menu is not found on the nRFConnect for desktop
Best Regards!
Let me know.
  • Hi
    Indeed, this is where you download the nRF Sniffer. You should also check out the nRF sniffer user guide on our Infocenter to get started.
    Q2. Can you show me a screenshot of how your nRF Connect for Desktop looks? The programmer should be available as shown below.
    Simon
  • Hello
    2287.Sniffer_setup_trouble.pdf
    Without using nRFConnect for desktop Programmer
    I connected the DK board via USB and it looked like mass storage, so it seems that I could write it by copying HEX to the DK board with Drug & Drop.
    Then follow the nRF Sniffer for Bluetooth LE user Guide
    After proceeding, I was able to confirm the Advertising Packet with Wireshark.
    Thanks.
    Best Regards.
  • Hi
    Glad to hear you got it to work by just dragging and dropping the .hex file onto the DK. That should be sufficient. I just tested the programmer app on my end and did not have this issue on my end. Can you "Open log file" and upload that here so we can get a better look at the log from your Programmer app? You can also try to do an nrfjprog --recover or --eraseall command with the nRF command line tools before trying again, and see if this issue still occurs.
    Simon
  • Hello Nordic Support
    I will post the log when it fails using nRFConnect for desktop / Programmer.
    Finally, Packet evaluation can be started, so I will check the operation of Programmer at a later date.
    2022-05-13T01:51:02.230Z DEBUG Application data folder: C:\Users\チノー 山形事業所 市場開発担当\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
    2022-05-13T01:51:02.380Z DEBUG App pc-nrfconnect-programmer v3.0.0 official
    2022-05-13T01:51:02.380Z DEBUG App path: C:\Users\チノー 山形事業所 市場開発担当\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
    2022-05-13T01:51:02.380Z DEBUG nRFConnect 3.11.0, required by the app is (^3.10.0)
    2022-05-13T01:51:02.380Z DEBUG nRFConnect path: C:\Users\チノー 山形事業所 市場開発担当\AppData\Local\Programs\nrfconnect\resources\app.asar
    2022-05-13T01:51:02.381Z DEBUG HomeDir: C:\Users\チノー 山形事業所 市場開発担当
    2022-05-13T01:51:02.381Z DEBUG TmpDir: C:\Users\チノー~1\AppData\Local\Temp
    2022-05-13T01:51:02.399Z INFO Using nrf-device-lib-js version: 0.4.5
    2022-05-13T01:51:02.399Z INFO Using nrf-device-lib version: 0.11.0
    2022-05-13T01:51:02.400Z INFO Using nrfjprog DLL version: 10.15.1
    2022-05-13T01:51:02.400Z INFO Using JLink version: JLink_V7.58b
    2022-05-13T01:51:03.917Z DEBUG iface: イーサネット
    2022-05-13T01:51:03.917Z DEBUG IP4: 172.18.128.36
    2022-05-13T01:51:03.917Z DEBUG IP6: fe80::c00:99f8:7003:d786
    2022-05-13T01:51:03.917Z DEBUG MAC: 58:8a:5a:47:6a:06
    2022-05-13T01:51:03.918Z DEBUG Client Id: 26ba027f2ff5832453d28ec2a68c715821ba565d
    2022-05-13T01:51:03.920Z DEBUG Google Analytics for category pc-nrfconnect-programmer has initialized
    2022-05-13T01:52:12.239Z INFO Parsing HEX file:  D:\sniffer\4_1_0\nrf_sniffer_for_bluetooth_le_4.1.0\hex\sniffer_nrf52dk_nrf52832_4.1.0.hex
    2022-05-13T01:52:12.275Z INFO File was last modified at  2021/10/26 12:44:34
    2022-05-13T01:52:12.328Z INFO Update files regions according to Application core
    2022-05-13T01:52:12.328Z INFO Parse memory regions for file
    2022-05-13T01:54:49.595Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
    2022-05-13T01:54:49.596Z INFO JLink OB firmware version J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    2022-05-13T01:54:49.596Z DEBUG Sending usage data...
    2022-05-13T01:54:49.596Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:54:49.596Z DEBUG Action: Open jlink OB version
    2022-05-13T01:54:49.597Z DEBUG Label: J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    2022-05-13T01:54:49.601Z DEBUG Usage data has been sent
    2022-05-13T01:54:49.601Z INFO Device family NRF52
    2022-05-13T01:54:49.602Z DEBUG Sending usage data...
    2022-05-13T01:54:49.602Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:54:49.602Z DEBUG Action: Open jlink device family
    2022-05-13T01:54:49.602Z DEBUG Label: NRF52
    2022-05-13T01:54:49.604Z DEBUG Usage data has been sent
    2022-05-13T01:54:49.604Z INFO Device version NRF52832_xxAA_REV1
    2022-05-13T01:54:49.604Z DEBUG Sending usage data...
    2022-05-13T01:54:49.604Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:54:49.604Z DEBUG Action: Open jlink device version
    2022-05-13T01:54:49.604Z DEBUG Label: NRF52832_xxAA_REV1
    2022-05-13T01:54:49.605Z DEBUG Usage data has been sent
    2022-05-13T01:54:49.606Z INFO Board version PCA10040
    2022-05-13T01:54:49.606Z DEBUG Sending usage data...
    2022-05-13T01:54:49.606Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:54:49.606Z DEBUG Action: Open jlink device board version
    2022-05-13T01:54:49.606Z DEBUG Label: PCA10040
    2022-05-13T01:54:49.607Z DEBUG Usage data has been sent
    2022-05-13T01:54:49.608Z INFO Loading readback protection status for Application core
    2022-05-13T01:54:49.608Z DEBUG Sending usage data...
    2022-05-13T01:54:49.608Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:54:49.609Z DEBUG Action: Open device
    2022-05-13T01:54:49.609Z DEBUG Label: jlink
    2022-05-13T01:54:49.610Z DEBUG Usage data has been sent
    2022-05-13T01:54:50.472Z INFO Readback protection status: NRFDL_PROTECTION_STATUS_NONE
    2022-05-13T01:54:51.234Z INFO Parse memory regions for Application core
    2022-05-13T01:54:51.241Z INFO Update files regions according to Application core
    2022-05-13T01:54:51.243Z INFO Parse memory regions for file
    2022-05-13T01:54:51.250Z INFO Device is loaded and ready for further operation
    2022-05-13T01:55:01.322Z INFO Recovering NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T01:55:05.241Z INFO Recovering NRFDL_DEVICE_CORE_APPLICATION core completed
    2022-05-13T01:55:05.246Z INFO Device recovery completed
    2022-05-13T01:55:05.246Z INFO Writing procedure starts for NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T01:55:05.295Z INFO Writing HEX to NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T01:55:05.918Z INFO Uploading image through JLink: 0%
    2022-05-13T01:55:06.114Z ERROR Device programming failed with error: [object Object]
    2022-05-13T01:55:06.114Z DEBUG Sending usage data...
    2022-05-13T01:55:06.115Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:55:06.115Z DEBUG Action: Report error
    2022-05-13T01:55:06.115Z DEBUG Label: win32; ia32; v3.0.0; Device programming failed with error: [object Object]
    2022-05-13T01:55:06.118Z DEBUG Usage data has been sent
    2022-05-13T01:55:06.118Z INFO Writing HEX to NRFDL_DEVICE_CORE_APPLICATION core completed
    2022-05-13T01:55:06.119Z INFO Writing procedure ends for NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T01:55:06.136Z INFO Resetting device
    2022-05-13T01:55:06.939Z INFO Resetting device completed
    2022-05-13T01:55:06.945Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
    2022-05-13T01:55:06.945Z INFO JLink OB firmware version J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    2022-05-13T01:55:06.946Z DEBUG Sending usage data...
    2022-05-13T01:55:06.946Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:55:06.948Z DEBUG Action: Open jlink OB version
    2022-05-13T01:55:06.948Z DEBUG Label: J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    2022-05-13T01:55:06.950Z DEBUG Usage data has been sent
    2022-05-13T01:55:06.950Z INFO Device family NRF52
    2022-05-13T01:55:06.951Z DEBUG Sending usage data...
    2022-05-13T01:55:06.951Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:55:06.951Z DEBUG Action: Open jlink device family
    2022-05-13T01:55:06.951Z DEBUG Label: NRF52
    2022-05-13T01:55:06.953Z DEBUG Usage data has been sent
    2022-05-13T01:55:06.953Z INFO Device version NRF52832_xxAA_REV1
    2022-05-13T01:55:06.953Z DEBUG Sending usage data...
    2022-05-13T01:55:06.953Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:55:06.954Z DEBUG Action: Open jlink device version
    2022-05-13T01:55:06.954Z DEBUG Label: NRF52832_xxAA_REV1
    2022-05-13T01:55:06.955Z DEBUG Usage data has been sent
    2022-05-13T01:55:06.956Z INFO Board version PCA10040
    2022-05-13T01:55:06.956Z DEBUG Sending usage data...
    2022-05-13T01:55:06.956Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:55:06.956Z DEBUG Action: Open jlink device board version
    2022-05-13T01:55:06.956Z DEBUG Label: PCA10040
    2022-05-13T01:55:06.958Z DEBUG Usage data has been sent
    2022-05-13T01:55:06.958Z INFO Loading readback protection status for Application core
    2022-05-13T01:55:07.687Z INFO Readback protection status: NRFDL_PROTECTION_STATUS_NONE
    2022-05-13T01:55:08.447Z INFO Parse memory regions for Application core
    2022-05-13T01:55:08.450Z INFO Update files regions according to Application core
    2022-05-13T01:55:08.450Z INFO Parse memory regions for file
    2022-05-13T01:55:08.460Z INFO Device is loaded and ready for further operation
    2022-05-13T01:56:50.057Z INFO Recovering NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T01:56:54.044Z INFO Recovering NRFDL_DEVICE_CORE_APPLICATION core completed
    2022-05-13T01:56:54.049Z INFO Device recovery completed
    2022-05-13T01:56:54.049Z INFO Writing procedure starts for NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T01:56:54.092Z INFO Writing HEX to NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T01:56:54.698Z INFO Uploading image through JLink: 0%
    2022-05-13T01:56:54.902Z ERROR Device programming failed with error: [object Object]
    2022-05-13T01:56:54.902Z DEBUG Sending usage data...
    2022-05-13T01:56:54.902Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:56:54.902Z DEBUG Action: Report error
    2022-05-13T01:56:54.902Z DEBUG Label: win32; ia32; v3.0.0; Device programming failed with error: [object Object]
    2022-05-13T01:56:54.904Z DEBUG Usage data has been sent
    2022-05-13T01:56:54.904Z INFO Writing HEX to NRFDL_DEVICE_CORE_APPLICATION core completed
    2022-05-13T01:56:54.904Z INFO Writing procedure ends for NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T01:56:54.911Z INFO Resetting device
    2022-05-13T01:56:55.706Z INFO Resetting device completed
    2022-05-13T01:56:55.713Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
    2022-05-13T01:56:55.713Z INFO JLink OB firmware version J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    2022-05-13T01:56:55.713Z DEBUG Sending usage data...
    2022-05-13T01:56:55.713Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:56:55.714Z DEBUG Action: Open jlink OB version
    2022-05-13T01:56:55.714Z DEBUG Label: J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    2022-05-13T01:56:55.716Z DEBUG Usage data has been sent
    2022-05-13T01:56:55.716Z INFO Device family NRF52
    2022-05-13T01:56:55.717Z DEBUG Sending usage data...
    2022-05-13T01:56:55.717Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:56:55.717Z DEBUG Action: Open jlink device family
    2022-05-13T01:56:55.717Z DEBUG Label: NRF52
    2022-05-13T01:56:55.719Z DEBUG Usage data has been sent
    2022-05-13T01:56:55.719Z INFO Device version NRF52832_xxAA_REV1
    2022-05-13T01:56:55.720Z DEBUG Sending usage data...
    2022-05-13T01:56:55.720Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:56:55.720Z DEBUG Action: Open jlink device version
    2022-05-13T01:56:55.720Z DEBUG Label: NRF52832_xxAA_REV1
    2022-05-13T01:56:55.724Z DEBUG Usage data has been sent
    2022-05-13T01:56:55.724Z INFO Board version PCA10040
    2022-05-13T01:56:55.725Z DEBUG Sending usage data...
    2022-05-13T01:56:55.725Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T01:56:55.725Z DEBUG Action: Open jlink device board version
    2022-05-13T01:56:55.725Z DEBUG Label: PCA10040
    2022-05-13T01:56:55.727Z DEBUG Usage data has been sent
    2022-05-13T01:56:55.727Z INFO Loading readback protection status for Application core
    2022-05-13T01:56:56.601Z INFO Readback protection status: NRFDL_PROTECTION_STATUS_NONE
    2022-05-13T01:56:57.517Z INFO Parse memory regions for Application core
    2022-05-13T01:56:57.521Z INFO Update files regions according to Application core
    2022-05-13T01:56:57.521Z INFO Parse memory regions for file
    2022-05-13T01:56:57.531Z INFO Device is loaded and ready for further operation
    2022-05-13T02:00:02.195Z INFO Update files regions according to Application core
    2022-05-13T02:00:02.195Z INFO Parse memory regions for file
    2022-05-13T02:00:14.514Z DEBUG Sending usage data...
    2022-05-13T02:00:14.514Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:00:14.514Z DEBUG Action: Close device
    2022-05-13T02:00:14.514Z DEBUG Label:
    2022-05-13T02:00:14.516Z DEBUG Usage data has been sent
    2022-05-13T02:00:14.519Z INFO Target device closed
    2022-05-13T02:00:23.890Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
    2022-05-13T02:00:23.890Z INFO JLink OB firmware version J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    2022-05-13T02:00:23.890Z DEBUG Sending usage data...
    2022-05-13T02:00:23.890Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:00:23.890Z DEBUG Action: Open jlink OB version
    2022-05-13T02:00:23.891Z DEBUG Label: J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    2022-05-13T02:00:23.892Z DEBUG Usage data has been sent
    2022-05-13T02:00:23.892Z INFO Device family NRF52
    2022-05-13T02:00:23.892Z DEBUG Sending usage data...
    2022-05-13T02:00:23.892Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:00:23.893Z DEBUG Action: Open jlink device family
    2022-05-13T02:00:23.893Z DEBUG Label: NRF52
    2022-05-13T02:00:23.894Z DEBUG Usage data has been sent
    2022-05-13T02:00:23.894Z INFO Device version NRF52832_xxAA_REV1
    2022-05-13T02:00:23.894Z DEBUG Sending usage data...
    2022-05-13T02:00:23.894Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:00:23.894Z DEBUG Action: Open jlink device version
    2022-05-13T02:00:23.894Z DEBUG Label: NRF52832_xxAA_REV1
    2022-05-13T02:00:23.895Z DEBUG Usage data has been sent
    2022-05-13T02:00:23.895Z INFO Board version PCA10040
    2022-05-13T02:00:23.896Z DEBUG Sending usage data...
    2022-05-13T02:00:23.896Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:00:23.896Z DEBUG Action: Open jlink device board version
    2022-05-13T02:00:23.896Z DEBUG Label: PCA10040
    2022-05-13T02:00:23.900Z DEBUG Usage data has been sent
    2022-05-13T02:00:23.900Z INFO Loading readback protection status for Application core
    2022-05-13T02:00:23.901Z DEBUG Sending usage data...
    2022-05-13T02:00:23.901Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:00:23.901Z DEBUG Action: Open device
    2022-05-13T02:00:23.901Z DEBUG Label: jlink
    2022-05-13T02:00:23.902Z DEBUG Usage data has been sent
    2022-05-13T02:00:24.779Z INFO Readback protection status: NRFDL_PROTECTION_STATUS_NONE
    2022-05-13T02:00:25.606Z INFO Parse memory regions for Application core
    2022-05-13T02:00:25.610Z INFO Update files regions according to Application core
    2022-05-13T02:00:25.610Z INFO Parse memory regions for file
    2022-05-13T02:00:25.623Z INFO Device is loaded and ready for further operation
    2022-05-13T02:01:58.708Z INFO Parsing HEX file:  D:\sniffer\4_1_0\nrf_sniffer_for_bluetooth_le_4.1.0\hex\sniffer_nrf52dk_nrf52832_4.1.0.hex
    2022-05-13T02:01:58.708Z INFO File was last modified at  2021/10/26 12:44:34
    2022-05-13T02:01:58.756Z INFO Update files regions according to Application core
    2022-05-13T02:01:58.756Z INFO Parse memory regions for file
    2022-05-13T02:02:34.265Z INFO Recovering NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T02:02:38.166Z INFO Recovering NRFDL_DEVICE_CORE_APPLICATION core completed
    2022-05-13T02:02:38.172Z INFO Device recovery completed
    2022-05-13T02:02:38.173Z INFO Writing procedure starts for NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T02:02:38.207Z INFO Writing HEX to NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T02:02:38.774Z INFO Uploading image through JLink: 0%
    2022-05-13T02:02:38.993Z ERROR Device programming failed with error: [object Object]
    2022-05-13T02:02:38.994Z DEBUG Sending usage data...
    2022-05-13T02:02:38.994Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:02:38.994Z DEBUG Action: Report error
    2022-05-13T02:02:38.994Z DEBUG Label: win32; ia32; v3.0.0; Device programming failed with error: [object Object]
    2022-05-13T02:02:38.997Z DEBUG Usage data has been sent
    2022-05-13T02:02:38.998Z INFO Writing HEX to NRFDL_DEVICE_CORE_APPLICATION core completed
    2022-05-13T02:02:38.999Z INFO Writing procedure ends for NRFDL_DEVICE_CORE_APPLICATION core
    2022-05-13T02:02:39.006Z INFO Resetting device
    2022-05-13T02:02:39.803Z INFO Resetting device completed
    2022-05-13T02:02:39.811Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
    2022-05-13T02:02:39.811Z INFO JLink OB firmware version J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    2022-05-13T02:02:39.812Z DEBUG Sending usage data...
    2022-05-13T02:02:39.812Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:02:39.812Z DEBUG Action: Open jlink OB version
    2022-05-13T02:02:39.812Z DEBUG Label: J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    2022-05-13T02:02:39.815Z DEBUG Usage data has been sent
    2022-05-13T02:02:39.815Z INFO Device family NRF52
    2022-05-13T02:02:39.816Z DEBUG Sending usage data...
    2022-05-13T02:02:39.816Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:02:39.816Z DEBUG Action: Open jlink device family
    2022-05-13T02:02:39.817Z DEBUG Label: NRF52
    2022-05-13T02:02:39.819Z DEBUG Usage data has been sent
    2022-05-13T02:02:39.819Z INFO Device version NRF52832_xxAA_REV1
    2022-05-13T02:02:39.820Z DEBUG Sending usage data...
    2022-05-13T02:02:39.820Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:02:39.820Z DEBUG Action: Open jlink device version
    2022-05-13T02:02:39.820Z DEBUG Label: NRF52832_xxAA_REV1
    2022-05-13T02:02:39.823Z DEBUG Usage data has been sent
    2022-05-13T02:02:39.823Z INFO Board version PCA10040
    2022-05-13T02:02:39.824Z DEBUG Sending usage data...
    2022-05-13T02:02:39.824Z DEBUG Category: pc-nrfconnect-programmer
    2022-05-13T02:02:39.824Z DEBUG Action: Open jlink device board version
    2022-05-13T02:02:39.824Z DEBUG Label: PCA10040
    2022-05-13T02:02:39.826Z DEBUG Usage data has been sent
    2022-05-13T02:02:39.827Z INFO Loading readback protection status for Application core
    2022-05-13T02:02:40.728Z INFO Readback protection status: NRFDL_PROTECTION_STATUS_NONE
    2022-05-13T02:02:41.581Z INFO Parse memory regions for Application core
    2022-05-13T02:02:41.584Z INFO Update files regions according to Application core
    2022-05-13T02:02:41.584Z INFO Parse memory regions for file
    2022-05-13T02:02:41.592Z INFO Device is loaded and ready for further operation
    Best Regards.
    Thanks.
