nRF52840 random disconnection
Good morning,
We have a new equipment based on the nRF52840 and s140.
                Just now, a new problem has appeared and it is very strange, as it seems to be a ‘random’ error:
                We have already assembled tens of equipment, and most of them are perfectly working with any smartphone (using both your ‘nRF Connect’ application or our own application).
                But, we have a few smartphones that show a strange behavior: they are able to perfectly connect to some of our nRF52840-based equipment, and in a few ones, they are able to connect but they get disconnected after a few seconds. Same equipment is connecting to other smartphones without problems (without disconnecting).
                This is (step by step) what it is happening a few times:
  • Equipment (nRF52840) is advertising.
  • Smartphone stablish connection with equipment using pin number
  • First time, the connection is perfectly working.
  • If smartphone is disconnected and connected back again with same equipment (Already bonded), then connection is stablished but smartphone disconnects after 30”, approximately. Same behavior is happening with both nRF connect application and our own application. Looking at log in nRF application we see: ‘Connection terminated by peer (status 19)’or ‘GATT_CONN_TIMEOUT’
Why is it happening?
Which is the reason?
How can we solve this?
 Could you help us? (For your information, we have set MIN_CONN_INTERVAL to 7.5m and MAX_CONN_INTERVAL to 100ms)
Thank you
  • HI again,
    I have reproduced again the disconnection with the Xiaomi Mi8. I have the code in the same way it was last specified: with SLAVE_LATENCY set to 15. But I have set (for sniffer purposes) SEC_PARAM_LESC=0.
    I have proceeded in the same way: equipment desinchronized from my central (Xiaomi Mi8), and then (with Wireshark ready) I have bonded peripheral to my Xiaomi, and I have manually disconnected it several times unless last time: in this last time, it has been disconnected alone after about 30".
    Please, find attached this trace. Please, let me know any finding.
    Furthermore, in what regards BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST event, which is the right implementation. Could it affect in this behavior?3_06_22_Android_Connection_Bonding_Connection_Mi8.pcapng
  • Hi Daniel,
    This might be the missing sniffer trace that we have been looking for.
    There are a few potential issue that I can find here:
    1. I can see a security request was sent right after the connection has been established. Did you call pm_conn_secure() inside BLE_GAP_EVT_CONNECTED event ?
    If you did please remove it. Also please check if you have PM_HANDLER_SEC_DELAY_MS set to something in sdk_config.h ? Please try set it to 1000 , by default it's 400ms. It's for interoperability as mentioned in the description.
    2. I can see service changed indication that's sent by the slave:
    Did you change the attribute table ? And did you have something in your code to send the service changed indication ?
    3. The central send a confirmation 30 seconds into the connection:
    I'm not so sure what the confirmation for, for which indication, but it's most likely for the service changed indication. But it came too late and the softdevice disconnected due to BLE_GATTS_EVT_TIMEOUT . The slave terminate the connection right after that.
    Please try to check the points I listed here and also try to capture another sniffer trace if it has the same pattern we may be able to pin point the problem.
  • Hi Hung,
    I really appreciate your support: it is very important for us...
    In what regards your questions:
    1.- pm_conn_secure() is not called.
          PM_HANDLER_SEC_DELAY_MS is set to o --> I'll set it to 1000
    2.- I never use 'sd_ble_gatts_service_changed'. Using nRF tool, I have seen that the Generic Attribute with UUID 0x1801 is set as INDICATE. How can I change this? All my other services are sending notifications. Please, find a screenshot showing the Generic Attribute and my first service (all of them have same setup).
    Moreover, I'm using the DFU service defined as shown in the second screenshot. As far as I know, the NRF_SDH_BLE_SERVICE_CHANGED has to be set to 1 for the DFU to work, right?
    And what about BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST? Which is the suitable implementation?
    Dani
  • Hi Hung,
    Now, by having set PM_HANDLER_SEC_DELAY_MS to 1000, even the TAB A is working!!!!!!
    Please, let me know information I was asking in my previous answer.
    And what about SLAVE_LATENCY? Do you recommend to set it back to 0?
    Dani.
  • Good morning Hung,
    What's your opinion about last findings?
    Dani
