nrf_serial_read never receive data
Hello !
I was trying to communicate with my Acsip chip, when I saw that the problem was coming from the nrf_serial_read() function. And here is my setup :
- I use the example of Nordic Semi : the serial_pca10040
- My SDK is 16.0.0
- I'm codding with Segger embedded studio 5.42 release
*Fact :
- My colleague is using the same setup, code and SDK and everything is working fine for him.
- the nrf_serial_read() always timeout (so the timeout is working)
My problem is that the function always timeout and the buffer is always empty. I have tried several timeout but that does not work. Also, with my setup I see that I write some command and that I receive some other command from my chip, but the nrf_serial_read() don't catch up this data.
Here is the code of the serial_pca10040 and my initializing of nrf_serial_init :
#define OP_QUEUES_SIZE          3
//#define APP_TIMER_PRESCALER     NRF_SERIAL_APP_TIMER_PRESCALER
static void sleep_handler(void)
    __WFE();
    __SEV();
    __WFE();
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config,
                      14, 15,
                      0xFF, 0xFF,
                      NRF_UART_HWFC_ENABLED, NRF_UART_PARITY_EXCLUDED,
                      NRF_UART_BAUDRATE_115200,
                      UART_DEFAULT_CONFIG_IRQ_PRIORITY);
#define SERIAL_FIFO_TX_SIZE 32
#define SERIAL_FIFO_RX_SIZE 32
NRF_SERIAL_QUEUES_DEF(serial_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 1
NRF_SERIAL_BUFFERS_DEF(serial_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_CONFIG_DEF(serial_config, NRF_SERIAL_MODE_IRQ,
                      &serial_queues, &serial_buffs, NULL, sleep_handler);
NRF_SERIAL_UART_DEF(serial_uart, 0);
    ret_code_t ret;
   ret = nrf_drv_clock_init();
    APP_ERROR_CHECK(ret);
    //ret = nrf_drv_power_init(NULL);
    //APP_ERROR_CHECK(ret);
    ret = app_timer_init();
    // Initialize LEDs and buttons.
    bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
    ret = nrf_serial_init(&serial_uart, &m_uart0_drv_config, &serial_config);
    static char tx_message[] = "Hello nrf_serial!\n\r";
    ret = nrf_serial_write(&serial_uart,
                           tx_message,
                           strlen(tx_message),
                           NULL,
                           NRF_SERIAL_MAX_TIMEOUT);
    while (true)
        char c;
        ret = nrf_serial_read(&serial_uart, &c, sizeof(c), NULL, 1000);
        if (ret != NRF_SUCCESS)
            continue;
        (void)nrf_serial_write(&serial_uart, &c, sizeof(c), NULL, 0);
        (void)nrf_serial_flush(&serial_uart, 0);
Here is the nrf_serial_read function :
ret_code_t nrf_serial_read(nrf_serial_t const * p_serial,
                           void * p_data,
                           size_t size,
                           size_t * p_read,
                           uint32_t timeout_ms)
    ret_code_t ret;
    ASSERT(p_serial);
    if (!p_serial->p_ctx->p_config)
        return NRF_ERROR_MODULE_NOT_INITIALIZED;
    if (!(p_serial->p_ctx->flags & NRF_SERIAL_RX_ENABLED_FLAG))
    if (size == 0)
        return NRF_SUCCESS;
    if (!nrf_mtx_trylock(&p_serial->p_ctx->read_lock))
        return NRF_ERROR_BUSY;
    nrf_serial_timeout_ctx_t tout_ctx = {
            .expired = false,
    if (timeout_ms != NRF_SERIAL_MAX_TIMEOUT)
        ret = timeout_setup(p_serial,
                            p_serial->p_rx_timer,
                            timeout_ms,
                            &tout_ctx);
            nrf_mtx_unlock(&p_serial->p_ctx->read_lock);
            return ret;
    size_t left = size;
    uint8_t * p_buff = p_data;
    do
        size_t rcnt = serial_rx(p_serial, p_buff, left);
        left -= rcnt;
        p_buff += rcnt;
        if (!left)
        if (tout_ctx.expired)
            if (p_serial->p_ctx->p_config->mode != NRF_SERIAL_MODE_POLLING)
                nrf_drv_uart_rx_abort(&p_serial->instance);
        sleep_handler(p_serial);
    } while (1);
    if (p_read)
        *p_read = size - left;
    if (!tout_ctx.expired && (timeout_ms != NRF_SERIAL_MAX_TIMEOUT))
        (void)app_timer_stop(*p_serial->p_rx_timer);
    if (left && tout_ctx.expired)
        return NRF_ERROR_TIMEOUT;
    return NRF_SUCCESS;
So I was wondering if you would have some idea about the source of the problem ?
** It's my first post on DevZone, so if there is anything missing, just tell me and I'll be glad to add it !
    Some code snippets on how you initializing nrf_serial and also for your nrf_serial_read will be helpful.
    These libraries are known to be working as I cannot see any known issues for read in your version of SDK.
    If you are using XTAL clocks, I would double check their accuracies to see if they are not causing any issues here.
    Also please check if there are any error that you need your application to recover from.
  • I just updated my post ! And there don't seem to be any errors !
  • Sorry for a late response, I was OoO.
    I do not see any issues with your code. It looks like you have taken the code snippet as a template from one of our examples in the SDK (SDK\examples\peripheral\serial\main.c). It looks like you commented out nrf_drv_power_init. Is there a reason that you commented it out?
    Do you have any logs enabled (check your sdk_config.h file). Can you show if there are any error that are showed on the logs?
  • Hi Susheel !
    Thank you for your time, it was really appreciated. Unfortunately, I never found any sort of error and I tried a lot of things. So, the last solution was to wipe my computer and start on a fresh installation of windows, and that's what I've done. Everything is now working ! I am an intern and the setup have been changed multiple times by other intern before me ad maybe they changed some settings in the computer. It's just an idea that I have, but we will never really now what happened ! Again, thank you for the help and have a good day !
