send and receive data over ble without character 0xDA (Enter)
Hi, I have a NRF52840 DK. I want to use ble_app_uart_c and my peripheral is NRF52840 Dongle and also I want to receive and transmit special frame over ble. I have a problem with BLE_NUS_C_EVT_NUS_TX_EVT becuase  this Requires special characters 0xDA (Enter) to receive data and run bluetooth handler. In my application, sometimes it is necessary to receive or send  this character. I have a special rule to understand the end of the received frame and I do not need to use this character.
Are there any solutions for this?
 Is there a solution to send and receive character by character?
Mohammad Amin
  • Hi Mohammad
    This behavior is set by the ble_app_uart and ble_app_uart_c examples, and you should be able to change the application code in order to change the criteria's used to send or receive data.
    For example, in the ble_app_uart_c example it is the ble_nus_chars_received_uart_print(..) function that is used to process the data received from the peer Bluetooth device and forward it to the UART interface, while the uart_event_handle(..) function is processing the UART data and sending it over the Bluetooth connection.
    Best regards
    Torbjørn
  • Thanks Torbjørn.
    Sorry but I can't understand correctly. for example if a frame(binary) send from LabView to Devkit, the DK won't receive this frame because The end of the frame does not have the character 0xDA and won't run ble_nus_chars_received_uart_print(..) function. This is my problem and I want to solve that.
    Can you help me?
    Best regards
    MohammadAmin
  • Hi Mohammad
    If I understand you correctly you are sending data from LabView to a DK running the ble_app_uart example, which is connected to another DK over Bluetooth running the ble_app_uart_c example, and you see here that you don't get the full message that you sent from the PC side?
    In this case it is the uart_event_handle function on the ble_app_uart side that is the problem, as it only transmits a packet if either the buffer fills up, or if the LF or CR character is received (0x0A or 0x0D):
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    What you could do is to add a timer in the ble_app_uart example that will check the status of the data_array buffer, and send it after some time even if the LF or CR characters aren't received.
    Essentially, if the index variable is larger than 0 it means that some data has been buffered in the data_array buffer but not yet sent, and if it stays over 0 for a certain amount of time without anything happening you could just send the data_array buffer immediately and clear the index variable (similar to how it's already done in the uart_event_handle(..) function when CR or LF is received).
    Best regards
    Torbjørn
