This example automatically create the thread network. Once the button is pressed every 3 second udp is sent.
Issue is I am not receiving the packet on 2nd device. I am not seeing print from port_data_callback().
What am I missing? Thanks.
Using nrf52840 dongle, nrf connect 1.9.1
/* * Copyright (c) 2020 Nordic Semiconductor ASA * * SPDX-License-Identifier: LicenseRef-Nordic-5-Clause */ #include <zephyr.h> #include <dk_buttons_and_leds.h> #include <logging/log.h> #include <net/openthread.h> #include <openthread/thread.h> #include <openthread/udp.h> #include <sys/printk.h> #include <usb/usb_device.h> #include <drivers/uart.h> LOG_MODULE_REGISTER(coap_server, CONFIG_COAP_SERVER_LOG_LEVEL); BUILD_ASSERT(DT_NODE_HAS_COMPAT(DT_CHOSEN(zephyr_shell_uart), zephyr_cdc_acm_uart), "Console device is not ACM CDC UART device"); #define OT_CONNECTION_LED DK_LED1 static struct k_work udp_send_work; static struct k_timer msg_timer; const char buf[10] = "Hello\0"; otUdpSocket m_socket; static void port_data_callback(void * p_context, otMessage * p_message, const otMessageInfo * p_message_info) { LOG_INF("port_data_callback"); // LOG_INF("ptr to msg = %08x",p_message); } static void init_udp() { otError error = otIp6SetEnabled(openthread_get_default_instance(), true); if( error ){ LOG_ERR("otIp6SetEnabled = %u", error); } error = otUdpOpen(openthread_get_default_instance(), &m_socket, port_data_callback, NULL); if (error != OT_ERROR_NONE ) { LOG_INF("otUdpOpen err = %u", error); return error; } else { LOG_INF("otUdpOpen SUCCESS!"); } } otError send_udp(otUdpSocket *socket) { otError error = OT_ERROR_NONE; otMessageInfo messageInfo; bool is_open = otUdpIsOpen(openthread_get_default_instance(), socket); if (is_open == false) { LOG_INF("socket is not open!"); } memset(&messageInfo, 0, sizeof(messageInfo)); error = otIp6AddressFromString("ff03::1", &messageInfo.mPeerAddr); if (error != OT_ERROR_NONE ) { LOG_INF("otIp6AddressFromString err = %u", error); return error; } messageInfo.mPeerPort = (uint16_t)1994; otMessageSettings settings; settings.mPriority=OT_MESSAGE_PRIORITY_NORMAL; settings.mLinkSecurityEnabled=true; otMessage *test_Message = otUdpNewMessage(openthread_get_default_instance(), &settings); error = otMessageAppend(test_Message, buf, (uint16_t)strlen(buf)); if (error != OT_ERROR_NONE ) { LOG_INF("otMessageAppend err = %u", error); return error; } error = otUdpSend(openthread_get_default_instance(), socket, test_Message, &messageInfo); if(error != OT_ERROR_NONE) { LOG_ERR("otUdpSend err = %u",error); return error; } if(test_Message != NULL) { // otMessageFree(test_Message); LOG_INF("otMessageFree, to be added"); } return error; } static void activate_udp_send(struct k_work *item) { ARG_UNUSED(item); send_udp(&m_socket); k_timer_start(&msg_timer, K_SECONDS(3), K_NO_WAIT); LOG_INF("UDP send activated"); } static void on_msg_timer_expiry(struct k_time *timer_id) { ARG_UNUSED(timer_id); k_work_submit(&udp_send_work); } static void on_button_changed(uint32_t button_state, uint32_t has_changed) { uint32_t buttons = button_state & has_changed; if (buttons & DK_BTN1_MSK) { k_work_submit(&udp_send_work); } } static void on_thread_state_changed(uint32_t flags, void *context) { struct openthread_context *ot_context = context; if (flags & OT_CHANGED_THREAD_ROLE) { switch (otThreadGetDeviceRole(ot_context->instance)) { case OT_DEVICE_ROLE_CHILD: case OT_DEVICE_ROLE_ROUTER: case OT_DEVICE_ROLE_LEADER: dk_set_led_on(OT_CONNECTION_LED); break; case OT_DEVICE_ROLE_DISABLED: case OT_DEVICE_ROLE_DETACHED: default: dk_set_led_off(OT_CONNECTION_LED); break; } } } void main(void) { int ret; k_timer_init(&msg_timer, on_msg_timer_expiry, NULL); k_work_init(&udp_send_work, activate_udp_send); ret = dk_leds_init(); if (ret) { LOG_ERR("Could not initialize leds, err code: %d", ret); goto end; } ret = dk_buttons_init(on_button_changed); if (ret) { LOG_ERR("Cannot init buttons (error: %d)", ret); goto end; } #if DT_NODE_HAS_COMPAT(DT_CHOSEN(zephyr_shell_uart), zephyr_cdc_acm_uart) const struct device *dev; uint32_t dtr = 0U; ret = usb_enable(NULL); if (ret != 0) { LOG_ERR("Failed to enable USB"); return; } dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_shell_uart)); if (dev == NULL) { LOG_ERR("Failed to find specific UART device"); return; } LOG_INF("Waiting for host to be ready to communicate"); /* Data Terminal Ready - check if host is ready to communicate */ while (!dtr) { ret = uart_line_ctrl_get(dev, UART_LINE_CTRL_DTR, &dtr); if (ret) { LOG_ERR("Failed to get Data Terminal Ready line state: %d", ret); continue; } k_msleep(100); } /* Data Carrier Detect Modem - mark connection as established */ (void)uart_line_ctrl_set(dev, UART_LINE_CTRL_DCD, 1); /* Data Set Ready - the NCP SoC is ready to communicate */ (void)uart_line_ctrl_set(dev, UART_LINE_CTRL_DSR, 1); #endif openthread_set_state_changed_cb(on_thread_state_changed); openthread_start(openthread_get_default_context()); init_udp(); end: return; }
