where is that file in which I can change the sensors code to create my custom code on thingy91?
I need to modify the code of different sensor data, which is obtained on LTE monitor, so I want that file in which I can create custom sensor data /Modify the sensor data according to me  and then show it on LTE monitor  For example I want to change the after decimal value length for accelerometer value and the name "temp" "humidity" to a custom name like "Temperature of my room"  "Environment humidity"   and all this change will be reflected on LTE monitor and then on Azure cloud
SO, where is that file in which I can change the sensors code to create my custom code?
Using thingy91, ncs version latest created build successfully
NOTE: Please respond Fast and up to the topic, No need to stretch the conversation
