k_sem_take failed UART interrupts Bluetooth
Hello together,
Im currently doing my bachelor thesis and my task is to develop a user interface that can control a NRF52840 and write some parameters over UART.
Im able receive data that I sent from a python script, but if I want to start advertising it gets interrupted and the error message says: ASSERTION FAIL [error == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:305 k_sem_take failed with error -11
I already looked at everything I found relating to that error message. It seems like the UART, which is interrupt driven and fifo, interrupts the bluetooth hci core. I dont have any idea how to fix that, since Im not really experienced with zephyr or embedde programming.
In general: I need some code that reads the UART and does not interrupt the bluetooth functionality of the board. I didn't find a different UART solution that worked, it doesn't has to be interrupt driven or fifo! I hope some of you may help me :)
Thank you in advance for your answers!
The code is as following:
#include <zephyr.h>
#include <zephyr/types.h>
#include <sys/byteorder.h>
#include <stddef.h>
#include <errno.h>
#include <sys/printk.h>
#include <drivers/uart.h>
#include <stdio.h>
#include <string.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/hci.h>
#include <bluetooth/gatt.h>
#include <bluetooth/gatt_dm.h>
#include <bluetooth/conn.h>
#include <bluetooth/uuid.h>
static uint8_t uart_buf[1024];
static uint8_t  mfg_data[] = {0x23,0x66,0x61,0x75,0x38,0xC5,0xAB,0xA9,0xF1,0x47,0x26,0xF7,0x44,0x73,0x2A,0xE2};
static const struct bt_data ad[] = {
  BT_DATA(BT_DATA_UUID128_ALL, mfg_data, 16)
static void start_adv(void)
  int err;
  err = bt_le_adv_start(BT_LE_ADV_NCONN, ad, ARRAY_SIZE(ad) ,NULL, 0);
  if (err) {
      printk("Advertising failed to start (err %d)\n", err);
      return;
  printk("Advertising successfully started \n");
static void uart_cb(const struct device *x, void *user_data)
    //printk("*");
  uart_irq_update(x);
  int data_length = 0;
  if (uart_irq_rx_ready(x)) {
    data_length = uart_fifo_read(x, uart_buf, sizeof(uart_buf));
    uart_buf[data_length] = 0;
  char cmp_str[] = "a";
  printk("%s\n", uart_buf);
  if(!strcmp(uart_buf,cmp_str)){
    start_adv();
void main(void)
  const struct device *uart = device_get_binding("UART_0");
  //uart_irq_callback_set(uart, uart_cb);
  int uart1_data = 0;
  uart_irq_callback_user_data_set(uart, uart_cb, &uart1_data);
  uart_irq_rx_enable(uart);
  printk("UART loopback start!\n");
  int err;
  printk("Starting Scanner/Advertiser Demo\n");
  /* Initialize the Bluetooth Subsystem */
  err = bt_enable(NULL);
  if (err) {
    printk("Bluetooth init failed (err %d)\n", err);
    return;
  if (IS_ENABLED(CONFIG_SETTINGS)) {
      settings_load();
  printk("\nBluetooth initialized \n");
The .conf file is the following:
CONFIG_BT=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
