Asset_tracker V2 run time buffer overflow in LTE
I run the Asstet_tracker V2. The part of LTE log is as below:
2022-05-19T07:58:34.234Z DEBUG modem << [00:00:33.314,788] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_CONNECTED[0m
2022-05-19T07:58:34.425Z DEBUG modem << [00:00:33.504,974] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_READY[0m
2022-05-19T07:58:34.441Z DEBUG modem << [00:00:33.514,892] [0m<dbg> cloud_module: cloud_wrap_event_handler: CLOUD_WRAP_EVT_CONNECTED[0m
2022-05-19T07:58:34.444Z DEBUG modem << [00:00:33.523,651] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTED[0m
after this
[00:00:33.530,120] [0m<dbg> ui_module: state_set: State transition STATE_CLOUD_CONNECTING --> STATE_RUNNING[0m
2022-05-19T07:58:34.461Z DEBUG modem << * buffer overflow detected *
I could not understand the reason of the buffer overflow here and it's solution.  If required, I can send complete Log file.
    Yes, please. Also, you can provide as much information as possible, such as MFW version and NCS version.
  • HI, I added some DBG measages to data_get() function in main.c of asset_tracker_v2. I added bms_module to default code and made changes in every file where required. The get_data() function prepares the list of requested data.  I observed that when
    app_module_event->data_list[count++] = APP_DATA_BMS;
    is added to get_data() functon, the buffer_overflow mesasge appears in LTE a shown in attached log file. When,
    is not there in get_data() function, then there is no buffer_overflow and works well.
    The code pf get_data() also is shown here below.
    static void data_get(void)
    	static bool first = true;
    	struct app_module_event *app_module_event = new_app_module_event();
    	size_t count = 0;
            LOG_DBG(" Main: Entered data_get()");
    	/* Set a low sample timeout. If GNSS is requested, the sample timeout will be increased to
    	 * accommodate the GNSS timeout.
    	app_module_event->timeout = 1;
    	/* Specify which data that is to be included in the transmission. */
    	app_module_event->data_list[count++] = APP_DATA_MODEM_DYNAMIC;
            LOG_DBG(" Modem_dyn requested through data_list[]");
    	app_module_event->data_list[count++] = APP_DATA_BATTERY;
            LOG_DBG(" APP_BATT requested through data_list[]");
    	app_module_event->data_list[count++] = APP_DATA_ENVIRONMENTAL;
            LOG_DBG(" APP_ENV requested through data_list[]");
    	if (IS_ENABLED(CONFIG_APP_REQUEST_NEIGHBOR_CELLS_DATA) && !app_cfg.no_data.neighbor_cell) {
    		app_module_event->data_list[count++] = APP_DATA_NEIGHBOR_CELLS;
            LOG_DBG(" APP_NBR_CELLS requested through data_list[]");
    	/* The reason for having at least 75 seconds sample timeout when
    	 * requesting GNSS data is that the GNSS module on the nRF9160 modem will always
    	 * search for at least 60 seconds for the first position fix after a reboot. This limit
    	 * is enforced in order to give the modem time to perform scheduled downloads of
    	 * A-GPS data from the GNSS satellites.
    	 * However, if A-GPS data has been downloaded via the cloud connection and processed
    	 * before the initial GNSS search, the actual GNSS timeout set by the application is used.
    	 * Processing A-GPS before requesting GNSS data is enabled by default,
    	 * and the time that the application will wait for A-GPS data before including GNSS
    	 * in sample requests can be adjusted via the
    	 * CONFIG_APP_REQUEST_GNSS_WAIT_FOR_AGPS_THRESHOLD_SEC Kconfig option. If this option is
    	 * set to -1, the application module will not request GNSS unless A-GPS data has been
    	 * processed.
    	 * If A-GPS data has been processed the sample timeout can be ignored as the
    	 * GNSS will most likely time out before the sample timeout expires.
    	 * When GNSS is requested, set the sample timeout to (GNSS timeout + 15 seconds)
    	 * to let the GNSS module finish ongoing searches before data is sent to cloud.
    	if (first) {
    		if (IS_ENABLED(CONFIG_APP_REQUEST_GNSS_ON_INITIAL_SAMPLING) && request_gnss() &&
    		    !app_cfg.no_data.gnss) {
    			app_module_event->data_list[count++] = APP_DATA_GNSS;
    			app_module_event->timeout = MAX(app_cfg.gnss_timeout + 15, 75);
                            LOG_DBG(" GNSS requested through data_list[]");
    		app_module_event->data_list[count++] = APP_DATA_MODEM_STATIC;
    		first = false;
    	} else {
    		if (request_gnss() && !app_cfg.no_data.gnss) {
            LOG_DBG(" BMS requested through data_list[]");
    	/* Set list count to number of data types passed in app_module_event. */
    	app_module_event->count = count;
    	app_module_event->type = APP_EVT_DATA_GET;
            LOG_DBG("Ready to launch APP_EVT_DATA_GET Event");
    	APP_EVENT_SUBMIT(app_module_event);
            LOG_DBG("Launched APP_EVT_DATA_GET Event");
    Where overflow occurs, I could not understand ?
    2022-05-26T09:51:56.443Z DEBUG modem << *** Booting Zephyr OS build v2.7.99-ncs1-2195-g186cf4539e5a  ***
    2022-05-26T09:51:56.451Z DEBUG modem << [00:00:00.207,336] [0m<inf> at_host: UART check failed: 1. Dropping buffer and retrying.[0m
    2022-05-26T09:51:56.532Z DEBUG modem << [00:00:00.225,830] [0m<dbg> watchdog: watchdog_timeout_install: Watchdog timeout installed. Timeout: 60[0m
    2022-05-26T09:51:56.534Z DEBUG modem << [00:00:00.235,290] [0m<dbg> watchdog: watchdog_start: Watchdog started[0m
    2022-05-26T09:51:56.538Z DEBUG modem << [00:00:00.242,004] [0m<dbg> watchdog: watchdog_feed_enable: Watchdog feed enabled. Timeout: 30000[0m
    2022-05-26T09:51:56.542Z DEBUG modem << [00:00:00.251,373] [0m<inf> app_event_manager: APP_EVT_START[0m
    2022-05-26T09:51:56.545Z DEBUG modem << [00:00:00.257,171] [0m<dbg> gnss_module: state_set: State: STATE_INIT[0m
    2022-05-26T09:51:56.550Z DEBUG modem << [00:00:00.263,763] [0m<dbg> ui_module: state_set: State transition STATE_INIT --> STATE_RUNNING[0m
    2022-05-26T09:51:56.554Z DEBUG modem << [00:00:00.272,552] [0m<dbg> ui_module: sub_state_set: Sub state: SUB_STATE_ACTIVE[0m
    2022-05-26T09:51:56.557Z DEBUG modem << [00:00:00.280,181] [0m<dbg> ui_module: sub_sub_state_set: Sub state: SUB_SUB_STATE_GNSS_INACTIVE[0m
    2022-05-26T09:51:56.560Z DEBUG modem << [00:00:00.289,154] [0m<dbg> util_module: state_set: State: STATE_INIT[0m
    2022-05-26T09:51:56.581Z DEBUG modem << [00:00:00.296,234] [0m<inf> bms_module: BMS Thread Start successful: 0[0m
    2022-05-26T09:51:56.584Z DEBUG modem << [00:00:00.302,856] [0m<inf> bms_module: State: STATE_INIT[0m
    2022-05-26T09:51:56.591Z DEBUG modem << [00:00:00.308,471] [0m<inf> bms_module: State transition STATE_INIT --> BMS DETECTED[0m
    2022-05-26T09:51:56.594Z DEBUG modem << [00:00:00.316,345] [0m<dbg> cloud_module: state_set: State: STATE_LTE_INIT[0m
    2022-05-26T09:51:56.614Z DEBUG modem << [00:00:00.323,333] [0m<dbg> cloud_module: sub_state_set: Sub state: SUB_STATE_CLOUD_DISCONNECTED[0m
    2022-05-26T09:51:56.625Z DEBUG modem << [00:00:00.332,305] [0m<dbg> data_module: state_set: State: STATE_CLOUD_DISCONNECTED[0m
    2022-05-26T09:51:56.628Z DEBUG modem << [00:00:00.340,454] [0m<dbg> date_time: date_time_core_register_handler: Registering handler 0x47ba3[0m
    2022-05-26T09:51:56.631Z DEBUG modem << [00:00:00.349,609] [0m<dbg> data_module: config_print_all: Device mode: Active[0m
    2022-05-26T09:51:56.652Z DEBUG modem << [00:00:00.356,933] [0m<dbg> data_module: config_print_all: Active wait timeout: 120[0m
    2022-05-26T09:51:56.659Z DEBUG modem << [00:00:00.364,715] [0m<dbg> data_module: config_print_all: Movement resolution: 120[0m
    2022-05-26T09:51:56.661Z DEBUG modem << [00:00:00.372,497] [0m<dbg> data_module: config_print_all: Movement timeout: 3600[0m
    2022-05-26T09:51:56.670Z DEBUG modem << [00:00:00.380,126] [0m<dbg> data_module: config_print_all: GPS timeout: 60[0m
    2022-05-26T09:51:56.673Z DEBUG modem << [00:00:00.387,145] [0m<dbg> data_module: config_print_all: Accelerometer threshold: 10.00[0m
    2022-05-26T09:51:56.688Z DEBUG modem << [00:00:00.395,446] [0m<dbg> data_module: config_print_all: Requesting of neighbor cell data is enabled[0m
    2022-05-26T09:51:56.691Z DEBUG modem << [00:00:00.404,876] [0m<dbg> data_module: config_print_all: Requesting of GNSS data is enabled[0m
    2022-05-26T09:51:56.695Z DEBUG modem << [00:00:00.413,574] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2022-05-26T09:51:56.698Z DEBUG modem << [00:00:00.419,982] [0m<dbg> ui_module: sub_state_set: Sub state: SUB_STATE_ACTIVE[0m
    2022-05-26T09:51:56.700Z DEBUG modem << [00:00:00.428,009] [0m<dbg> main: active_mode_timers_start_all: Device mode: Active[0m
    2022-05-26T09:51:56.716Z DEBUG modem << [00:00:00.435,760] [0m<dbg> main: active_mode_timers_start_all: Start data sample timer: 120 seconds interval[0m
    2022-05-26T09:51:56.724Z DEBUG modem << [00:00:00.445,861] [0m<inf> app_event_manager: APP_EVT_ACTIVITY_DETECTION_DISABLE[0m
    2022-05-26T09:51:56.727Z DEBUG modem << [00:00:00.453,979] [0m<dbg> main: state_set: App State transition STATE_INIT --> STATE_RUNNING[0m
    2022-05-26T09:51:56.729Z DEBUG modem << [00:00:00.462,677] [0m<dbg> main: sub_state_set: App Sub state: SUB_STATE_ACTIVE_MODE[0m
    2022-05-26T09:51:56.743Z DEBUG modem << [00:00:00.470,672] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
    2022-05-26T09:51:56.747Z DEBUG modem << [00:00:00.477,233] [0m<dbg> main: data_get:  Modem_dyn requested through data_list[][0m
    2022-05-26T09:51:56.753Z DEBUG modem << [00:00:00.485,107] [0m<dbg> main: data_get:  APP_BATT requested through data_list[][0m
    2022-05-26T09:51:56.764Z DEBUG modem << [00:00:00.492,889] [0m<dbg> main: data_get:  APP_ENV requested through data_list[][0m
    2022-05-26T09:51:56.769Z DEBUG modem << [00:00:00.500,610] [0m<dbg> main: data_get:  APP_NBR_CELLS requested through data_list[][0m
    2022-05-26T09:51:56.775Z DEBUG modem << [00:00:00.508,850] [0m<dbg> main: data_get:  BMS requested through data_list[][0m
    2022-05-26T09:51:56.792Z DEBUG modem << [00:00:00.516,174] [0m<dbg> main: data_get: Ready to launch APP_EVT_DATA_GET Event[0m
    2022-05-26T09:51:56.795Z DEBUG modem << * buffer overflow detected *
    2022-05-26T09:51:56.800Z DEBUG modem << [00:00:00.526,580] [1;31m<err> os: r0/a1:  0x00000003  r1/a2:  0x00000000  r2/a3:  0x00000001[0m
    2022-05-26T09:51:56.817Z DEBUG modem << [00:00:00.535,247] [1;31m<err> os: r3/a4:  0x2002590e r12/ip:  0x2001c9c4 r14/lr:  0x00032117[0m
    2022-05-26T09:51:56.821Z DEBUG modem << [00:00:00.543,884] [1;31m<err> os:  xpsr:  0x61000000[0m
    2022-05-26T09:51:56.828Z DEBUG modem << [00:00:00.549,133] [1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000[0m
    2022-05-26T09:51:56.830Z DEBUG modem << [00:00:00.559,509] [1;31m<err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000[0m
    2022-05-26T09:51:56.845Z DEBUG modem << [00:00:00.569,885] [1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000[0m
    2022-05-26T09:51:56.848Z DEBUG modem << [00:00:00.580,291] [1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000[0m
    2022-05-26T09:51:56.851Z DEBUG modem << [00:00:00.590,637] [1;31m<err> os: fpscr:  0x00000000[0m
    2022-05-26T09:51:56.861Z DEBUG modem << [00:00:00.595,855] [1;31m<err> os: Faulting instruction address (r15/pc): 0x00030b9e[0m
    2022-05-26T09:51:56.864Z DEBUG modem << [00:00:00.603,729] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0[0m
    2022-05-26T09:51:56.869Z DEBUG modem << [00:00:00.611,328] [1;31m<err> os: Current thread: 0x20011658 (unknown)[0m
    2022-05-26T09:51:56.881Z DEBUG modem << [00:00:00.618,133] [0m<dbg> util_module: state_set: State transition STATE_INIT --> STATE_REBOOT_PENDING[0m
    2022-05-26T09:51:56.888Z DEBUG modem << [00:00:00.627,685] [0m<dbg> main: data_get: Launched APP_EVT_DATA_GET Event[0m
    2022-05-26T09:51:56.893Z DEBUG modem << [00:00:00.634,826] [0m<dbg> modem_module: state_set: State transition STATE_INIT --> STATE_DISCONNECTED[0m
    2022-05-26T09:51:56.895Z DEBUG modem << [00:00:00.644,439] [0m<dbg> sensor_module: state_set: State: STATE_INIT[0m
    2022-05-26T09:51:56.907Z DEBUG modem << [00:00:00.651,214] [0m<dbg> sensor_module: state_set: State transition STATE_INIT --> STATE_RUNNING[0m
    2022-05-26T09:51:56.910Z DEBUG modem << [00:00:00.668,060] [0m<dbg> modem_module: configure_low_power: PSM requested[0m
    2022-05-26T09:51:57.404Z DEBUG modem << [00:00:01.160,583] [0m<inf> bms_module: State transition BMS DETECTED --> STATE_RUNNING[0m
    2022-05-26T09:51:57.410Z DEBUG modem << [00:00:01.168,670] [0m<inf> bms_module: BMS Thread: BMS_FOUND[0m
    2022-05-26T09:51:57.412Z DEBUG modem <<
    2022-05-26T09:52:06.351Z DEBUG modem << *** Booting Zephyr OS build v2.7.99-ncs1-2195-g186cf4539e5a  ***
    2022-05-26T09:52:06.353Z DEBUG modem <<
    2022-05-26T09:52:06.355Z DEBUG modem << I: Starting bootloader
    2022-05-26T09:52:06.360Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-05-26T09:52:06.366Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-05-26T09:52:06.368Z DEBUG modem <<
    2022-05-26T09:52:06.370Z DEBUG modem << I: Boot source: none
    2022-05-26T09:52:06.372Z DEBUG modem << I: Swap type: none
    2022-05-26T09:52:06.459Z DEBUG modem << I: Bootloader chainload address offset: 0x10000
    2022-05-26T09:52:06.464Z DEBUG modem << I: Jumping to the first image slot
    2022-05-26T09:52:06.939Z DEBUG modem << *** Booting Zephyr OS build v2.7.99-ncs1-2195-g186cf4539e5a  ***
    2022-05-26T09:52:06.952Z DEBUG modem << [00:00:00.207,519] [0m<dbg> watchdog: watchdog_timeout_install: Watchdog timeout installed. Timeout: 60[0m
    2022-05-26T09:52:06.956Z DEBUG modem << [00:00:00.217,010] [0m<dbg> watchdog: watchdog_start: Watchdog started[0m
    2022-05-26T09:52:06.964Z DEBUG modem << [00:00:00.223,724] [0m<dbg> watchdog: watchdog_feed_enable: Watchdog feed enabled. Timeout: 30000[0m
    2022-05-26T09:52:06.970Z DEBUG modem << [00:00:00.233,093] [0m<inf> app_event_manager: APP_EVT_START[0m
    2022-05-26T09:52:06.976Z DEBUG modem << [00:00:00.238,891] [0m<dbg> gnss_module: state_set: State: STATE_INIT[0m
    2022-05-26T09:52:06.985Z DEBUG modem << [00:00:00.245,513] [0m<dbg> ui_module: state_set: State transition STATE_INIT --> STATE_RUNNING[0m
    2022-05-26T09:52:06.987Z DEBUG modem <<
    2022-05-26T09:52:06.992Z DEBUG modem << [00:00:00.254,272] [0m<dbg> ui_module: sub_state_set: Sub state: SUB_STATE_ACTIVE[0m
    2022-05-26T09:52:06.994Z DEBUG modem <<
    2022-05-26T09:52:07.002Z DEBUG modem << [00:00:00.261,901] [0m<dbg> ui_module: sub_sub_state_set: Sub state: SUB_SUB_STATE_GNSS_INACTIVE[0m
    2022-05-26T09:52:07.008Z DEBUG modem << [00:00:00.270,904] [0m<dbg> util_module: state_set: State: STATE_INIT[0m
    2022-05-26T09:52:07.016Z DEBUG modem << [00:00:00.278,015] [0m<inf> bms_module: BMS Thread Start successful: 0[0m
    2022-05-26T09:52:07.021Z DEBUG modem << [00:00:00.284,606] [0m<inf> bms_module: State: STATE_INIT[0m
    2022-05-26T09:52:07.029Z DEBUG modem << [00:00:00.290,252] [0m<inf> bms_module: State transition STATE_INIT --> BMS DETECTED[0m
    2022-05-26T09:52:07.036Z DEBUG modem << [00:00:00.298,126] [0m<dbg> cloud_module: state_set: State: STATE_LTE_INIT[0m
    2022-05-26T09:52:07.044Z DEBUG modem << [00:00:00.305,084] [0m<dbg> cloud_module: sub_state_set: Sub state: SUB_STATE_CLOUD_DISCONNECTED[0m
    2022-05-26T09:52:07.047Z DEBUG modem <<
    2022-05-26T09:52:07.052Z DEBUG modem << [00:00:00.314,086] [0m<dbg> data_module: state_set: State: STATE_CLOUD_DISCONNECTED[0m
    2022-05-26T09:52:07.062Z DEBUG modem << [00:00:00.322,113] [0m<dbg> date_time: date_time_core_register_handler: Registering handler 0x47ba3[0m
    2022-05-26T09:52:07.069Z DEBUG modem << [00:00:00.331,298] [0m<dbg> data_module: config_print_all: Device mode: Active[0m
    2022-05-26T09:52:07.077Z DEBUG modem << [00:00:00.338,623] [0m<dbg> data_module: config_print_all: Active wait timeout: 120[0m
    2022-05-26T09:52:07.080Z DEBUG modem <<
    2022-05-26T09:52:07.085Z DEBUG modem << [00:00:00.346,405] [0m<dbg> data_module: config_print_all: Movement resolution: 120[0m
    2022-05-26T09:52:07.093Z DEBUG modem << [00:00:00.354,187] [0m<dbg> data_module: config_print_all: Movement timeout: 3600[0m
    2022-05-26T09:52:07.099Z DEBUG modem << [00:00:00.361,816] [0m<dbg> data_module: config_print_all: GPS timeout: 60[0m
    2022-05-26T09:52:07.107Z DEBUG modem << [00:00:00.368,835] [0m<dbg> data_module: config_print_all: Accelerometer threshold: 10.00[0m
    2022-05-26T09:52:07.117Z DEBUG modem << [00:00:00.377,166] [0m<dbg> data_module: config_print_all: Requesting of neighbor cell data is enabled[0m
    2022-05-26T09:52:07.119Z DEBUG modem <<
    2022-05-26T09:52:07.126Z DEBUG modem << [00:00:00.386,596] [0m<dbg> data_module: config_print_all: Requesting of GNSS data is enabled[0m
    2022-05-26T09:52:07.133Z DEBUG modem << [00:00:00.395,294] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2022-05-26T09:52:07.140Z DEBUG modem << [00:00:00.401,702] [0m<dbg> ui_module: sub_state_set: Sub state: SUB_STATE_ACTIVE[0m
    2022-05-26T09:52:07.148Z DEBUG modem << [00:00:00.409,729] [0m<dbg> main: active_mode_timers_start_all: Device mode: Active[0m
    2022-05-26T09:52:07.158Z DEBUG modem << [00:00:00.417,480] [0m<dbg> main: active_mode_timers_start_all: Start data sample timer: 120 seconds interval[0m
    2022-05-26T09:52:07.172Z DEBUG modem << [00:00:00.427,581] [0m<inf> app_event_manager: APP_EVT_ACTIVITY_DETECTION_DISABLE[0m
    2022-05-26T09:52:07.262Z DEBUG modem << [00:00:00.435,699] [0m<dbg> main: state_set: App State transition STATE_INIT --> STATE_RUNNING[0m
    2022-05-26T09:52:07.268Z DEBUG modem << [00:00:00.444,396] [0m<dbg> main: sub_state_set: App Sub state: SUB_STATE_ACTIVE_MODE[0m
    2022-05-26T09:52:07.292Z DEBUG modem << [00:00:00.452,423] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
    2022-05-26T09:52:07.296Z DEBUG modem << [00:00:00.458,984] [0m<dbg> main: data_get:  Modem_dyn requested through data_list[][0m
    2022-05-26T09:52:07.299Z DEBUG modem << [00:00:00.466,857] [0m<dbg> main: data_get:  APP_BATT requested through data_list[][0m
    2022-05-26T09:52:07.302Z DEBUG modem << [00:00:00.474,639] [0m<dbg> main: data_get:  APP_ENV requested through data_list[][0m
    2022-05-26T09:52:07.306Z DEBUG modem << [00:00:00.482,360] [0m<dbg> main: data_get:  APP_NBR_CELLS requested through data_list[][0m
    2022-05-26T09:52:07.308Z DEBUG modem << [00:00:00.490,600] [0m<dbg> main: data_get:  BMS requested through data_list[][0m
    2022-05-26T09:52:07.314Z DEBUG modem << [00:00:00.497,955] [0m<dbg> main: data_get: Ready to launch APP_EVT_DATA_GET Event[0m
    2022-05-26T09:52:07.317Z DEBUG modem << * buffer overflow detected *
    2022-05-26T09:52:07.322Z DEBUG modem << [00:00:00.508,361] [1;31m<err> os: r0/a1:  0x00000003  r1/a2:  0x00000000  r2/a3:  0x00000001[0m
    2022-05-26T09:52:07.327Z DEBUG modem << [00:00:00.517,028] [1;31m<err> os: r3/a4:  0x2002590e r12/ip:  0x2001c9c4 r14/lr:  0x00032117[0m
    2022-05-26T09:52:07.330Z DEBUG modem << [00:00:00.525,665] [1;31m<err> os:  xpsr:  0x61000000[0m
    2022-05-26T09:52:07.333Z DEBUG modem << [00:00:00.530,883] [1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000[0m
    2022-05-26T09:52:07.336Z DEBUG modem << [00:00:00.541,290] [1;31m<err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000[0m
    2022-05-26T09:52:07.364Z DEBUG modem << [00:00:00.551,666] [1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000[0m
    2022-05-26T09:52:07.367Z DEBUG modem << [00:00:00.562,072] [1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000[0m
    2022-05-26T09:52:07.369Z DEBUG modem << [00:00:00.572,418] [1;31m<err> os: fpscr:  0x00000000[0m
    2022-05-26T09:52:07.372Z DEBUG modem << [00:00:00.577,636] [1;31m<err> os: Faulting instruction address (r15/pc): 0x00030b9e[0m
    2022-05-26T09:52:07.375Z DEBUG modem << [00:00:00.585,510] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0[0m
    2022-05-26T09:52:07.377Z DEBUG modem << [00:00:00.593,139] [1;31m<err> os: Current thread: 0x20011658 (unknown)[0m
    2022-05-26T09:52:07.381Z DEBUG modem << [00:00:00.599,945] [0m<dbg> util_module: state_set: State transition STATE_INIT --> STATE_REBOOT_PENDING[0m
    2022-05-26T09:52:07.401Z DEBUG modem << [00:00:00.609,497] [0m<dbg> main: data_get: Launched APP_EVT_DATA_GET Event[0m
    2022-05-26T09:52:07.404Z DEBUG modem << [00:00:00.616,638] [0m<dbg> modem_module: state_set: State transition STATE_INIT --> STATE_DISCONNECTED[0m
    2022-05-26T09:52:07.406Z DEBUG modem << [00:00:00.626,251] [0m<dbg> sensor_module: state_set: State: STATE_INIT[0m
    2022-05-26T09:52:07.410Z DEBUG modem << [00:00:00.633,026] [0m<dbg> sensor_module: state_set: State transition STATE_INIT --> STATE_RUNNING[0m
    2022-05-26T09:52:07.411Z DEBUG modem << [00:00:00.649,963] [0m<dbg> modem_module: configure_low_power: PSM requested[0m
    2022-05-26T09:52:07.429Z DEBUG modem <<
    2022-05-26T09:52:07.881Z DEBUG modem << [00:00:01.142,425] [0m<inf> bms_module: State transition BMS DETECTED --> STATE_RUNNING[0m
    2022-05-26T09:52:07.889Z DEBUG modem << [00:00:01.150,512] [0m<inf> bms_module: BMS Thread: BMS_FOUND[0m
  • And what is the MFW version and NCS version?
  • I observed that in Main.c file, there is get_data() fn. If custom data request s added to data_list[], then buffer overflow occurs. I commented the request for environmental and added request for custom data in data_list[] then no buffer overflow occurred and custom data was visible and encoded in LTE. So, need to find that is there any limit to max requests to be passed through data_list[] ?
    Håkon is on vacation. Are you still having issues with this?
     Can you show the modifications you have made? Did you add a new new type toapp_module_data_type ?
