Extended Advertising - reception and data size
I recently started with nRF52840-DK, Zephyr and nRF Connect SDK (v. 1.9.1). I want to test extended advertising. Since there is no example of "pure" extended advertising (i.e. no periodic), I modified the periodic_adv example. Modification is quite easy: In prj.conf setting CONFIG_BT_PER_ADV=n, in main.c skipping bt_le_per_adv_set_param() and bt_le_per_adv_start(), usage of bt_le_ext_adv_set_data() instead of bt_le_per_adv_set_data(). Now extended advertising runs well. With a Sodera sniffer, I can see three ADV_EXT_IND frames in channels 37/38/39, followed by an AUX_ADV_IND frame in one of the data channels. The AUX_ADV_IND frame contains two AD elements: One with the data I want to transmit and one with the complete local name as set in prj.conf.
For reception, I use the periodic_sync example, which should support extended advertising without the periodic functionality too.
Now the questions:
My receiver calls the scan_recv function, but always I see only one of the AD elements. The buffer contains only the AD element with the local name, which is the last one in the frame (according to the sniffer raw data). There is no indication of the reception of my data in the second AD element. What have I to do to receive both (or even more) AD elements? What is the intention here - to have several calls of scan_recv for every AD element or to have a list of buffers or something else?
  • Hi
    The nrt_buf_simple_max_len value is set depending on the number of bytes bening reserved as headroom, and shows how many bytes are usable behind the net_buf_simple data pointer. So the reason this is different in different applications is that the header size varies in size depending on the application.
    Simon
  • Hi Simonr,
    thanks for the explanation. But it doesn't help to understand what happens. I'm able to send up to 249 data bytes in extended advertising (one AD element containing the data), I can monitor these bytes in the AUX_ADV_IND frame with the sniffer. Why I can't receive them? Currently, I can receive 227 data bytes only. The whole frame in BB is only 244 bytes long in that case, which is less than I would expect as maximum size from the BT specs. How can I extend the data size in reception to the 249 bytes I can send? Why there is a difference between the TX and RX?
    Best regards
    Axel
  • Hi Simonr,
    now I compared the sniffer data of extended advertising and periodic advertising. I found that the difference
    d_length1 = LE_BB packet length - LE_ADV PDU length = 11
    in both cases, means that at least from size point of view these cases are identical.
    For periodic advertising, the extended header is 0 byte, that's why
    d_length2 = PDU length - AD Data length = 2
    which are the two size values itself.
    For extended advertising, the extended header is 3 bytes long, that's why d_length2 = 5.
    Question: Ok, there is a difference in possible size of 3 byte (extended header length). But the difference in what I'm able to receive is 249 - 227 = 22 byte. Why?
  • Hi Axel
    Okay, so you see the bytes on the BLE sniffer but don't receive them on the central side, is that the case? Can you send me the sniffer trace(s) so we can have a look on our side? Also, what device is the receiver in this connection? Does it perhaps not support the chained/periodic advertising used, so you don't see the packets on the receiving end for that reason.
    Simon
  • Hi Simonr,
    that's what I'm telling from the beginning - I can send more data than I'm able to receive. I'll attach a sniffer data file (Sodera sniffer), from my extended advertising max data tests - here "pure" extended advertising is used, no periodic functionality.
    Capture_test-extended-adv_maxdata.cfa
    The AD element in the AUX_ADV_IND contains 227 data bytes [0xff, 0xff, 0x00, 0xaa, 0x00, 0x01, 0x02 ... 0xde], which is the maximum I can receive - as I mentioned, net_buf_simple_max_len = 229 (227 + size + type).This is the simple extension from the advertising example, including two byte manufacturer ID.
    On Tx side, I can extend the data to 249 bytes in total (counting up to 0xf4), which I can see correctly sent in the sniffer. How I can extend the reception data size to that number?
    I'm using Nordic nRF52840-DK for Tx as well as for Rx, I program both devices using the same environment. I don't expect any problem from that side.
    Additional question: On advertiser side, is there any possibility to have a call-back function to be informed once the AUX_ADV_IND frame is transmitted?
    Best regards
    Axel
