5340, Zephyr failure to connect to Polar Heart rate strap; ble wireshark trace
Hi ,
I have compiled in Heart rat relay into my app; can scan and connect to simulator and garmin HR straps; but fail to connect to polar.
My debug log shows...
So security is encryption, no auth and I get an "unspecified" error.
I have done a BLE wireshark trace; but cannot see anything in the trace to indicate the issue.
Would be grateful if someon could look and give me a clue to whats going wrong.
Here is wireshark trace....
polarHrmActiveScanConnectFail.pcapng
Owain
  • Hi Hung,
    central uart or central heart rate example?
    Our device is both a central and a peripheral. One can connect from a mobile to manage our device; but it can connect to peripherals.
    Looking at the central heartrate example it works quite differntly to the uart example; it also does not change the security level. Note the Garmin strap works fine changing level to 2.
    Owain
  • Hi Owain,
    Sorry my mistake. My idea is to use central_uart because it has similar behavior as your application to require L2 when connected. But I forgot that it won't connect to the polar HR because it's different UUID.
    What you can do is to change the scan_init() to filter the HRS UUID instead of the NUS UUID. The goal is to make it connect and pair to the Polar HR. You can remove any code related to NUS client.
    I just want to have a very simple application that connect and pair and do nothing else. The prj.conf should be kept the same as in the sample.  If it works we can try to compare it with your application to see what cause the issue.
  • Hi Hung,
    I have taken the uart example as you suggest; I have had to make some small changes to ensure HCI RPMSG is used rather than HCI H4.
    This the outpu from the test on the console;  looks that same as my own project; fails on the security change.
    *** Booting Zephyr OS build v3.2.99-ncs1 ***
    [00:00:00.259,552] \033[0m<inf> fs_nvs: 2 Sectors of 4096 bytes\033[0m
    [00:00:00.259,552] \033[0m<inf> fs_nvs: alloc wra: 0, ec0\033[0m
    [00:00:00.259,552] \033[0m<inf> fs_nvs: data wra: 0, 154\033[0m
    [00:00:00.284,606] \033[0m<inf> bt_hci_core: No ID address. App must call settings_load()\033[0m
    [00:00:00.284,637] \033[0m<inf> central_hr: Bluetooth initialized\033[0m
    [00:00:00.286,254] \033[1;31m<err> settings: set-value failure. key: bt/name error(-2)\033[0m
    [00:00:00.287,139] \033[0m<inf> central_hr: Scan module initialized\033[0m
    Starting Bluetooth Central HR example
    [00:00:00.289,978] \033[0m<inf> central_hr: Scanning successfully started\033[0m
    [00:00:01.612,976] \033[0m<inf> central_hr: Filters matched. Address: E0:EF:E7:CA:6A:68 (random) connectable: 1\033[0m
    [00:00:02.115,417] \033[0m<inf> central_hr: Connected: E0:EF:E7:CA:6A:68 (random)\033[0m
    [00:00:02.167,572] \033[0m<inf> central_hr: MTU exchange done\033[0m
    [00:00:17.817,810] \033[1;33m<wrn> central_hr: Pairing failed conn: E0:EF:E7:CA:6A:68 (random), rea[00:01:05.502,258] \033[1;33m<wrn> central_hr: Pairing failed conn: E0:EF:E7:CA:6A:68 (random), reason 9\033[0m
    [00:01:05.502,410] \033[1;33m<wrn> central_hr: Security failed: E0:EF:E7:CA:6A:68 (random) level 1 err 9\033[0m
    [00:01:05.502,441] \033[1;31m<err> bt_gatt_dm: Discover failed, error: -128.\033[0m
    [00:01:05.502,441] \033[1;31m<err> central_hr: could not start the discovery procedure, error code: -128\033[0m
    [00:01:05.503,570] \033[0m<inf> central_hr: Disconnected: E0:EF:E7:CA:6A:68 (random) (reason 8)\033[0m
    This was built using ncs 2.2.0.
    6305.central_uart.zip
  • Hi Owain,
    Thanks for the update.
    I would assume there is some configuration with your board that chose HCI H4 ?
    By default if you compile with nRF5340 hci_rpmsg will be selected for the netcore.
    Could you try compile for nRF5340dk_nrf5340_cpuapp ?
    Also if you have a nRF52 board please try to do a cross check. We need to see if the issue only happens on the nRF53 or also on the nRF52. Then we can narrow down it to the dual core setting that cause the issue.
    I also assume that you only try to pair with one device ? By default CONFIG_BT_MAX_PAIRED = 1 so you can't pair with 2 devices or more.
    I looked at the trace again and have to correct myself that it was not "The nRF5 didn't send the pairing confirm and then the slave disconnected. " but the pairing confirms were sent and pairing randoms received but the confirm value from the POLAR was not match and it explain why the central terminate the pairing process.
    I will check internally to have the confirmation, but it's strange that the POLAR works with other central but not the DUT. I assume it works fine with a phone  ?
    Please also try testing the nRF5340 to pair with a nRF5 running peripheral_hr to see if the pairing would work or not. From what you described, it worked with the Garmin ?
    I did a quick test with your firmware and it paired fine with a nRF52 running peripheral_hr.
  • Hi again Owain,
    After checking with the team, I think we found something suspicious here.  In both of your sniffer trace the slave didn't respond to the LL_PHY_REQ from the central.
    This could be the reason the central couldn't send the LL_ENC_REQ. The central can't send the encryption request before the previous request has been responded.
    Could you please try modify the central so that it doesn't request 2Mbps PHY change to see if it would let the pairing complete ?
    You may want to call  bt_conn_get_remote_info() to get the information to know about the peer's BLE stack. If it's very old it may doesn't support PHY request change.
