MBH7BLZ02 not working
I have PCA10028 dev board and Fujitsu MBH7BLZ02 BT module.
I have successfully modified some sample code and when I flash it to nRF module on the PCA board, the code works. I can scan and connect to nRF and use it normally.
Now I'm trying to flash that code to MBH7BLZ02. I've connected MBH to PCA board over debug out connector. I can see the module as nRF51822 in nRFgo Studio, I can flash SoftDevice and application successfully, but MBH module is not seen on scanning. I use S110 for SoftDevice. I've tried S130 too but with same results.
I've also tried to set: SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_SYNTH_250_PPM, false); in static void ble_stack_init(void) ...with no luck.
My MBH module is connected directly via wires to PCA board since I need to do some testing first, but it seems I just can't get it to work(or advertise).
Am I missing something?
Thank you!
Best regards, Mladen
