SPI config issue NCS V1.9.1
been having issues trying to get LittleFS to work on external SPI NOR Flash. I get linker errors leading me to believe something is missing in a config. I’ve looked at many samples on how to do this but none of the samples show how to do LittleFS on external SPI flash. So in putting the pieces together, I think something is missing.
It looks like a ordinal number with SPI2 in the dts is creating an issue.  below is the error and i have included the overlay.
[759/771] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[760/771] Linking CXX static library zephyr\kernel\libkernel.a
[761/771] Linking CXX executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\Users\ncs\v1.9.1\toolchain\opt\bin\arm-none-eabi-g++.exe   @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf  && cmd.exe /C "cd /D C:\Users\Development\thread-dev\pbsm-fw\build-833\zephyr && C:\Users\ncs\v1.9.1\toolchain\opt\bin\cmake.exe -E echo ""
c:/users/ncs/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/spi/libdrivers__spi.a(spi_nrfx_spim.c.obj):(.rodata.__compound_literal.0+0x0): undefined reference to `__device_dts_ord_9'
c:/users/ncs/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj):(.data.__compound_literal.0+0x0): undefined reference to `__device_dts_ord_9'
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'c:\Users\ncs\v1.9.1\toolchain\opt\bin\cmake.EXE' --build 'c:\Users\Development\thread-dev\pbsm-fw\build-833'
The terminal process terminated with exit code: 1.
dts-v1/;
#include <nordic/nrf52833_qiaa.dtsi>
	model = "PBSM NRF52833";
	compatible = "nordic,nrf52833-dk-nrf52833";
	chosen {
		zephyr,console = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,uart-mcumgr = &uart0;
		zephyr,bt-mon-uart = &uart0;
		zephyr,bt-c2h-uart = &uart0;
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
	pwmleds {
		compatible = "pwm-leds";
		pwm_led_blue: pwm_led_blue {
			pwms = <&pwm0 15>; // P0.15
		pwm_led_green: pwm_led_green {
			pwms = <&pwm0 36>; // P1.04
		pwm_led_red: pwm_led_red {
			pwms = <&pwm0 24>; // P0.24
	buttons {
		compatible = "gpio-keys";
		user_button: user_button {
			gpios = <&gpio0 11 (GPIO_ACTIVE_LOW)>;
			label = "User Button";
		accl_int1: accl_int1 {
			gpios = <&gpio0 13 (GPIO_ACTIVE_HIGH)>;
			label = "Accelerometer interrupt 1";
		accl_int2: accl_int2 {
			gpios = <&gpio0 16 (GPIO_ACTIVE_HIGH)>;
			label = "Accelerometer interrupt 2";
	outputs {
		compatible = "gpio-leds";
		acc_en: acc_en {
			gpios = <&gpio0 25 (GPIO_ACTIVE_HIGH)>;
			label = "Accelerometer power enable";
		temp_en: temp_en {
			gpios = <&gpio1 2 (GPIO_ACTIVE_HIGH)>;
			label = "Temp sensor power enable";
		mem_en: mem_en {
			gpios = <&gpio1 1 (GPIO_ACTIVE_HIGH)>;
			label = "Memory power enable";
		accel_trig: accel_trig {
			gpios = <&gpio0 2 (GPIO_ACTIVE_HIGH)>;
			label = "Accelerometer trigger";
	/* These aliases are provided for compatibility with samples */
	aliases {
		green-pwm-led = &pwm_led_green;
		blue-pwm-led = &pwm_led_blue;
		red-pwm-led = &pwm_led_red;
		user-button = &user_button;
		acc-en = &acc_en;
		temp-en = &temp_en;
		mem-en = &mem_en;
		accel-trig = &accel_trig;
		accl-int1 = &accl_int1;
		accl-int2 = &accl_int2;
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
&gpio1 {
	status = "okay";
&uart0 {
	status = "okay";
	current-speed = <115200>;
	tx-pin = <6>;  // P0.06
	rx-pin = <8>;  // P0.08
&i2c0 {
	compatible = "nordic,nrf-twi";
	status = "okay";
	clock-frequency = <100000>;
	sda-pin = <26>;  // P0.26
	scl-pin = <27>;  // P0.27
&spi1 {
	compatible = "nordic,nrf-spi";
	status = "okay";
	sck-pin = <41>;  // P1.09
	mosi-pin = <40>; // P1.08
	miso-pin = <4>;  // P0.04
&spi2 {
	status = "okay";
	sck-pin = <19>;  // SCLK/P0.19
	mosi-pin = <17>; // SI/SIO0/P0.17
	miso-pin = <22>; // SO/SIO1/P0.22
	cs-gpios = <&gpio0 23 GPIO_ACTIVE_LOW>;
	mx25r1635f@0 {
		compatible = "jedec,spi-nor";
		reg = <0>;
		spi-max-frequency = <80000000>;
		label = "MX25R16";
		jedec-id = [c2 28 15];
		size = <DT_SIZE_M(16)>;
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
		partitions {
			#address-cells = <1>;
			#size-cells = <1>;
			slot1_partition: partition@0 {
				label = "image-1";
				reg = <0x00000000 0x64000>;
			data_partition: partition@64000 {
				label = "data";
				reg = <0x64000 0x8000>;
			log_partition: partition@6C000 {
				label = "log";
				reg = <0x6C000 0xF94000>;
		fstab {
			compatible = "zephyr,fstab";
			data: data {
				compatible = "zephyr,fstab,littlefs";
				mount-point = "/data";
				partition = <&data_partition>;
				automount;
				read-size = <16>;
				prog-size = <16>;
				cache-size = <64>;
				lookahead-size = <32>;
				block-cycles = <512>;
			log: log {
				mount-point = "/log";
				partition = <&log_partition>;
				automount;
				read-size = <16>;
				prog-size = <16>;
				cache-size = <64>;
&pwm0 {
	status = "okay";
	ch0-pin = <15>; // P0.15
	ch1-pin = <36>; // P1.04
	ch2-pin = <24>; // P0.24
&timer2 {
	status = "okay";
&flash0 {
	partitions {
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 0xc000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000C000 0x64000>;
		scratch_partition: partition@70000 {
			label = "image-scratch";
			reg = <0x00070000 0xa000>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x0007a000 0x00006000>;
