Can't compile nRF5340 Audio DK example
I am trying to build the example for the Audio DK on an x86 Mac and am having trouble configuring the toolchain.
I have followed the instructions from here: developer.nordicsemi.com/.../gs_installing.html
When I run the build command for buildprog.py I get an error saying Zephyr can not find the toolchain.
I believe I have all of the environment variables set properly.
The error shows a path under the heading CROSS_COMPILE that does not exist (it is not installed by the GNU Arm Embedded Toolchain from here: https://developer.arm.com/downloads/-/gnu-rm)
CROSS_COMPILE:
/Users/dmann/gnuarmemb/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-
Any help would be appreciated.
Example Build Output
dmann@Davids-MBP-2 buildprog % python3 buildprog.py -c both -b release -d both
No programmer/debugger connected to PC
No snrs connected
| snr | snr conn | device | only reboot | core app programmed | core net programmed |
| 1050187322 | False | headset | Not selected | Not selected | Not selected |
| 1050166837 | False | gateway | Not selected | Not selected | Not selected |
| 1000 | False | headset | Not selected | Not selected | Not selected |
Invoking build step
Net core uses precompiled hex
Run: west build ../.. -b nrf5340_audio_dk_nrf5340_cpuapp -d ../../build/dev_headset/build_release
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: /Users/dmann/w/ncs/nrf/applications/nrf5340_audio
-- Cache files will be written to: /Users/dmann/Library/Caches/zephyr
-- Zephyr version: 3.0.99 (/Users/dmann/w/ncs/zephyr)
-- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
-- Board: nrf5340_audio_dk_nrf5340_cpuapp
-- Found dtc: /usr/local/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/Users/dmann/gnuarmemb/gcc-arm-none-eabi-9-2019-q4-major)
CMake Error at /Users/dmann/w/ncs/zephyr/cmake/compiler/gcc/generic.cmake:9 (message):
Zephyr was unable to find the toolchain. Is the environment misconfigured?
User-configuration:
ZEPHYR_TOOLCHAIN_VARIANT: gnuarmemb
Internal variables:
CROSS_COMPILE:
TOOLCHAIN_HOME: /Users/dmann/gnuarmemb/gcc-arm-none-eabi-9-2019-q4-major
/Users/dmann/w/ncs/zephyr/cmake/modules/generic_toolchain.cmake:51 (include)
/Users/dmann/w/ncs/zephyr/cmake/modules/zephyr_default.cmake:121 (include)
/Users/dmann/w/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:51 (include)
/Users/dmann/w/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:81 (include_boilerplate)
CMakeLists.txt:13 (find_package)
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -DWEST_PYTHON=/usr/local/opt/[email protected]/bin/python3.9 -B/Users/dmann/w/ncs/nrf/applications/nrf5340_audio/build/dev_headset/build_release -S/Users/dmann/w/ncs/nrf/applications/nrf5340_audio -GNinja
File "/Users/dmann/w/ncs/nrf/applications/nrf5340_audio/tools/buildprog/buildprog.py", line 319, in <module>
__main()
File "/Users/dmann/w/ncs/nrf/applications/nrf5340_audio/tools/buildprog/buildprog.py", line 302, in __main
__build_module(build_cfg)
File "/Users/dmann/w/ncs/nrf/applications/nrf5340_audio/tools/buildprog/buildprog.py", line 130, in __build_module
raise Exception("cmake error: " + str(ret_val))
Exception: cmake error: 256
Environment variables are set as:
ZEPHYR_BASE=/Users/dmann/w/ncs/zephyr
ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
GNUARMEMB_TOOLCHAIN_PATH=~/gnuarmemb/gcc-arm-none-eabi-9-2019-q4-major
