How to disable pairing after a certain timeout.
I am working on nRF52833 board (PCA10100).  I am pairing my peripheral device ( Nordic Board ) to the Mobile Application. I have to disable pairing after a certain timeout. I am not sure how to disable pairing, is there any specific API to do that.  I came across this specific from the document.
Optionally, call pm_sec_params_set to set the security parameters. If you do not call this function, pairing and bonding is not supported.
is this the only way method to disable pairing after certain timeout, since I doubt whether we have have to call the peer_manager_init() once again after the timeout without pm_sec_params_set().
static void peer_manager_init(void)
	ret_code_t           err_code;
	err_code = pm_init();
	sec_param.bond           = SEC_PARAM_BOND;
	sec_param.mitm           = SEC_PARAM_MITM;
	sec_param.lesc           = SEC_PARAM_LESC;
	sec_param.keypress       = SEC_PARAM_KEYPRESS;
	sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
	sec_param.oob            = SEC_PARAM_OOB;
	sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
	sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
	sec_param.kdist_own.enc  = 1;
	sec_param.kdist_own.id   = 1;
	sec_param.kdist_peer.enc = 1;
	sec_param.kdist_peer.id  = 1;
Specifications:
SDK - nRF5_SDK_17.1.0
