[Update Zigbee SDK] Problem when update from zigbee and thread 4.1.0 to zigbee and thread 4.2.0
Hi guys,
I have a question about migration guide from the old 4.1.0 thread and zigbee sdk to 4.2.0.
The story is that I have this project running 4.1.0 on my custom board with some bugs that seems to be fixed in 4.2.0 due to the release note. When I tried to update the SDK by pasting the new SDK in and then change SDK config as well as the makefile. For some more relevant context, the code I used as reference is the zigbee example light bulb to modify the project but after I successfully compile and flash the device, in zigbee_default_signal_handler I receive signal ID 22 which is the device can sleep signal but in the init system I have put it as router role. I also update the zigbee_helpers.c with
ZB_ERROR_CHECK(zb_zcl_set_backward_comp_mode(ZB_ZCL_AUTO_MODE));
ZB_ERROR_CHECK(zb_zcl_set_backward_compatible_statuses_mode(ZB_ZCL_STATUSES_ZCL8_MODE));
And as far as I know the this signal is only trigger when calling zb_sleep_now in the old SDK. So my question is that in the new SDK is there any part to be consider when init the system to not accidently trigger this behavior.
Thank you for any helps,
Tu
  • Hi Tu,
    Have you experienced the same issue when you test the original ZigBee light bulb sample on nRF52840DK?
    Charlie
  • Well, I have tried it and no I do not have the same problem.
  • Ok, Is it possible some specific modification in your application triggered this issue? I will also check with our development team for the possible cause. Let's keep each other updated.
    Charlie
  • Thank you for your support I will attach the SDK config files and makefile for you to check if there are any configuration should be made
    0726.app_config.h1307.sdk_config.h
    PROJ_DIR         := .
    COMPONENT_DIR    := $(PROJ_DIR)/components
    SRC_DIR          := $(PROJ_DIR)/main
    SDK_ROOT         := $(PROJ_DIR)/nrf_sdk_zigbee
    SDK_VERSION      := $(shell sed -n '1p' $(SDK_ROOT)/documentation/release_notes.txt | egrep -o "([0-9]+\.[0-9]+\.[0-9]+)")
    PROJECT_NAME     := $(shell basename "$(realpath $(PROJ_DIR))")
    OUTPUT_DIRECTORY := _build
    DATE             := $(shell git log -1 --format=%cd --date=format:"%Y%m%d")
    TAG_COMMIT       := $(shell git rev-list --abbrev-commit --tags --max-count=1)
    TAG              := $(shell git describe --abbrev=0 --tags ${TAG_COMMIT} 2>/dev/null || true)
    COMMIT           := $(shell git rev-parse --short HEAD)
    VERSION          := $(TAG:v%=%)
    ifeq ($(VERSION),)
    	VERSION := $(COMMIT)
    ifneq ($(COMMIT), $(TAG_COMMIT))
    	VERSION := $(VERSION)-next-$(COMMIT)
    endif
    endif
    ifneq ($(shell git status --porcelain --ignore-submodules),)
    	VERSION := $(VERSION)-dirty
    endif
    NRF_IC           := nrf52833
    IC_NUM           := $(shell echo ${NRF_IC} | egrep -o "([0-9]+)")
    TARGETS          := nrf52833_xxaa
    TARGET_RELEASE   := $(TARGETS)_release
    TARGET_DEBUG     := $(TARGETS)_debug
    # Print some helpful info about what the user is compiling for
    space :=
    space +=
    $(info BUILD OPTIONS:)
    $(info $(space) Project name     $(PROJECT_NAME))
    $(info $(space) SDK version      $(SDK_VERSION))
    $(info $(space) App version      $(VERSION))
    $(info $(space) Chip             $(NRF_IC))
    $(info $(space) Date             $(DATE))
    $(info $(space) Make Type        $(MAKECMDGOALS))
    $(info $(space))
    $(OUTPUT_DIRECTORY)/$(TARGET_RELEASE).out: \
    	LINKER_SCRIPT  := smarthome_gcc_nrf52833.ld
    $(OUTPUT_DIRECTORY)/$(TARGET_DEBUG).out: \
    	LINKER_SCRIPT  := smarthome_gcc_nrf52833_noboot.ld
    # Source files common to all targets
    SRC_FILES += \
    	$(SDK_ROOT)/modules/nrfx/mdk/gcc_startup_$(NRF_IC).S \
    	$(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_rtt.c \
    	$(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_serial.c \
    	$(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_uart.c \
    	$(SDK_ROOT)/components/libraries/log/src/nrf_log_default_backends.c \
    	$(SDK_ROOT)/components/libraries/log/src/nrf_log_frontend.c \
    	$(SDK_ROOT)/components/libraries/log/src/nrf_log_str_formatter.c \
    	$(SDK_ROOT)/external/zboss/src/commissioning/bdb/bdb_finding_binding.c \
    	$(SDK_ROOT)/external/zboss/osif/zb_nrf52_common.c \
    	$(SDK_ROOT)/external/zboss/osif/zb_nrf52_nrf_logger.c \
    	$(SDK_ROOT)/external/zboss/osif/zb_nrf52_logger.c \
    	$(SDK_ROOT)/external/zboss/osif/zb_nrf52_nvram.c \
    	$(SDK_ROOT)/external/zboss/osif/zb_nrf52_timer.c \
    	$(SDK_ROOT)/external/zboss/osif/zb_nrf52_transceiver.c \
    	$(SDK_ROOT)/components/libraries/button/app_button.c \
    	$(SDK_ROOT)/components/libraries/util/app_error.c \
    	$(SDK_ROOT)/components/libraries/util/app_error_handler_gcc.c \
    	$(SDK_ROOT)/components/libraries/scheduler/app_scheduler.c \
    	$(SDK_ROOT)/components/libraries/util/app_error_weak.c \
    	$(SDK_ROOT)/components/libraries/timer/app_timer2.c \
    	$(SDK_ROOT)/components/libraries/util/app_util_platform.c \
    	$(SDK_ROOT)/components/libraries/assert/assert.c \
    	$(SDK_ROOT)/components/libraries/util/nrf_assert.c \
    	$(SDK_ROOT)/components/libraries/timer/drv_rtc.c \
    	$(SDK_ROOT)/components/libraries/atomic_fifo/nrf_atfifo.c \
    	$(SDK_ROOT)/components/libraries/atomic/nrf_atomic.c \
    	$(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \
    	$(SDK_ROOT)/external/fprintf/nrf_fprintf.c \
    	$(SDK_ROOT)/external/fprintf/nrf_fprintf_format.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/ha_sas.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_alarms_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_attr_value.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_basic_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_binary_input.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_c_daily_schedule.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_c_drlc.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_c_messaging.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_c_metering.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_c_price.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_c_wwah.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_color_control_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_common.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_continuous_value_change_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_control4_networking.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_dehumid_control.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_diagnostics_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_door_lock.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_el_measurement.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_en50523_appliance_events_and_alerts.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_fan_control.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_general_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_groups.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_ias_ace_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_ias_wd_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_ias_zone_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_identify_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_illuminance_measurement.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_level_control_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_main.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_meter_identification.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_nvram.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_occupancy_sensing_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_on_off_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_on_off_switch_config.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_ota_upgrade_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_ota_upgrade_common.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_ota_upgrade_minimal.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_ota_upgrade_srv_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_poll_control_client.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_poll_control_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_power_config_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_pressure_measurement.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_rel_humidity.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_reporting.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_s_daily_schedule.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_s_drlc.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_s_messaging.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_s_metering.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_s_price.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_s_wwah.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_scenes.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_shade_config_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_temp_measurement.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_thermostat_commands.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_thermostat_ui_config.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_time.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_window_covering.c \
    	$(SDK_ROOT)/external/zboss/src/zcl/zcl_wwah_common.c \
    	$(SDK_ROOT)/external/zboss/src/commissioning/bdb/zdo_commissioning_bdb.c \
    	$(SDK_ROOT)/external/zboss/src/commissioning/bdb/zdo_commissioning_bdb_formation.c \
    	$(SDK_ROOT)/external/zboss/src/commissioning/legacy/zdo_commissioning_classic.c \
        $(SDK_ROOT)/components/libraries/experimental_section_vars/nrf_section_iter.c \
    	$(SDK_ROOT)/external/zboss/src/zb_error/zb_error_to_string.c \
    	$(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage.c \
    	$(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage_nvmc.c \
    	$(SDK_ROOT)/components/libraries/memobj/nrf_memobj.c \
    	$(SDK_ROOT)/components/libraries/pwr_mgmt/nrf_pwr_mgmt.c \
    	$(SDK_ROOT)/components/libraries/queue/nrf_queue.c \
    	$(SDK_ROOT)/components/libraries/ringbuf/nrf_ringbuf.c \
    	$(SDK_ROOT)/components/libraries/serial/nrf_serial.c \
    	$(SDK_ROOT)/components/libraries/sortlist/nrf_sortlist.c \
    	$(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \
    	$(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_twi.c \
    	$(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_clock.c \
    	$(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_power.c \
    	$(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_rng.c \
    	$(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_uart.c \
    	$(SDK_ROOT)/components/drivers_nrf/nrf_soc_nosd/nrf_nvic.c \
    	$(SDK_ROOT)/modules/nrfx/hal/nrf_nvmc.c \
    	$(SDK_ROOT)/modules/nrfx/hal/nrf_ecb.c \
    	$(SDK_ROOT)/components/drivers_nrf/nrf_soc_nosd/nrf_soc.c \
    	$(SDK_ROOT)/modules/nrfx/soc/nrfx_atomic.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_clock.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_gpiote.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_power.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/prs/nrfx_prs.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_rng.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_twi.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_twim.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_systick.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_timer.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uart.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uarte.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_wdt.c \
    	$(SDK_ROOT)/components/libraries/hardfault/nrf52/handler/hardfault_handler_gcc.c \
    	$(SDK_ROOT)/components/libraries/hardfault/hardfault_implementation.c \
    	$(SRC_DIR)/main.c \
    	$(SRC_DIR)/config.c \
    	$(SRC_DIR)/periph_monitor.c \
    	$(SRC_DIR)/zigbee_touch_switch.c \
    	$(SRC_DIR)/zigbee_ss_led_driver_cluster.c \
    	$(SRC_DIR)/zigbee_led_driver.c \
    	$(SRC_DIR)/zigbee_custom_cluster_touch.c\
    	$(SRC_DIR)/zb_gateway_error_handler.c\
    	$(SRC_DIR)/zigbee_curtain_cluster.c\
    	$(SRC_DIR)/periph_curtain.c \
    	$(SRC_DIR)/zb_zcl_analog_output.c \
    	$(SDK_ROOT)/components/libraries/fds/fds.c \
    	$(SDK_ROOT)/components/libraries/crc16/crc16.c \
    	$(COMPONENT_DIR)/nrf_peripherals/nrf_fds_storage.c \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_touch/periph_touch.c \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_touch/touch_lib/sx9500/sx9500.c \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_touch/touch_lib/sx8636/sx8636.c \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_pwm/periph_pwm.c \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_adc/periph_adc.c \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_button/periph_button.c \
    	$(COMPONENT_DIR)/zigbee_mesh/zigbee_mesh.c \
    	$(COMPONENT_DIR)/zigbee_mesh/zigbee_helper.c \
    	$(COMPONENT_DIR)/zigbee_mesh/zigbee_attr_report.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_pwm.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_ppi.c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_saadc.c \
    	$(SDK_ROOT)/external/segger_rtt/SEGGER_RTT.c \
    	$(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_Syscalls_GCC.c \
    	$(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_printf.c \
    	$(SDK_ROOT)/modules/nrfx/mdk/system_$(NRF_IC).c \
    	$(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_qdec.c \
    # Include folders common to all targets
    INC_FOLDERS += \
    	$(SDK_ROOT)/external/zboss/osif \
    	$(SDK_ROOT)/integration/nrfx \
    	$(SDK_ROOT)/components/libraries/low_power_pwm \
    	$(SRC_DIR) \
    	$(SRC_DIR)/include \
    	$(SDK_ROOT)/components/libraries/fds \
    	$(SDK_ROOT)/components/libraries/crc16 \
    	$(SDK_ROOT)/external/nRF-IEEE-802.15.4-radio-driver/src \
    	$(SDK_ROOT)/components/libraries/scheduler \
    	$(SDK_ROOT)/components/libraries/experimental_section_vars \
    	$(SDK_ROOT)/components/libraries/atomic_fifo \
    	$(SDK_ROOT)/modules/nrfx/mdk \
    	$(SDK_ROOT)/components/libraries/queue \
    	$(SDK_ROOT)/components/libraries/strerror \
    	$(SDK_ROOT)/components/libraries/serial \
    	$(SDK_ROOT)/components/zigbee/common \
    	$(SDK_ROOT)/external/nRF-IEEE-802.15.4-radio-driver/src/fem \
    	$(SDK_ROOT)/components/drivers_nrf/nrf_soc_nosd \
    	$(SDK_ROOT)/integration/nrfx/legacy \
    	$(SDK_ROOT)/components/libraries/button \
    	$(SDK_ROOT)/components/libraries/log \
    	$(SDK_ROOT)/modules/nrfx/hal \
    	$(SDK_ROOT)/components/libraries/log/src \
    	$(SDK_ROOT)/components/libraries/sortlist \
    	$(SDK_ROOT)/modules/nrfx/drivers/include \
    	$(SDK_ROOT)/external/zboss/include \
    	$(SDK_ROOT)/external/zboss/include/zcl \
    	$(SDK_ROOT)/components/libraries/ringbuf \
    	$(PROJ_DIR)/config \
    	$(SDK_ROOT)/external/fprintf \
    	$(SDK_ROOT)/components/libraries/balloc \
    	$(SDK_ROOT)/components/libraries/util \
    	$(SDK_ROOT)/modules/nrfx \
    	$(SDK_ROOT)/components \
    	$(SDK_ROOT)/external/segger_rtt \
    	$(SDK_ROOT)/components/libraries/memobj \
    	$(SDK_ROOT)/external/zboss/src/zb_error \
    	$(SDK_ROOT)/external/nRF-IEEE-802.15.4-radio-driver/src/fem/three_pin_gpio \
    	$(SDK_ROOT)/components/libraries/atomic \
    	$(SDK_ROOT)/external/zboss/include/ha \
    	$(SDK_ROOT)/external/zboss/src/include \
    	$(SDK_ROOT)/external/zboss/include/osif \
    	$(SDK_ROOT)/components/libraries/delay \
    	$(SDK_ROOT)/components/toolchain/cmsis/include \
    	$(SDK_ROOT)/external/zboss/include/addons \
    	$(SDK_ROOT)/components/libraries/mutex \
    	$(SDK_ROOT)/components/libraries/pwr_mgmt \
    	$(SDK_ROOT)/components/libraries/fstorage \
    	$(SDK_ROOT)/components/libraries/timer \
    	$(COMPONENT_DIR)/nrf_peripherals/include \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_touch/include \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_touch/touch_lib/sx8636 \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_touch/touch_lib/sx9500 \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_pwm/include \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_button/include \
    	$(COMPONENT_DIR)/nrf_peripherals/periph_adc/include \
    	$(COMPONENT_DIR)/zigbee_mesh/include \
    	$(SDK_ROOT)/components/libraries/hardfault/nrf52 \
    	$(SDK_ROOT)/components/libraries/hardfault \
    # Libraries common to all targets
    LIB_FILES += \
    	$(SDK_ROOT)/external/zboss/lib/gcc/libzboss.a \
    	$(SDK_ROOT)/external/zboss/lib/gcc/$(NRF_IC)/nrf_radio_driver.a \
    	$(SDK_ROOT)/external/zboss/lib/gcc/libgppb.a \
    # Optimization flags
    OPT = -O0 -ggdb3
    # Uncomment the line below to enable link time optimization
    #OPT += -flto
    # To make SEGGER RTT retarget to printf correctly, you need to get around
    # the silly ANSI C compatibility stuff that breaks our GCC builds
    PARAMS_DEFINE = -D_PARAMS\(paramlist\)=paramlist
    # C flags common to all targets
    CFLAGS += $(OPT)
    CFLAGS += $(PARAMS_DEFINE)
    CFLAGS += -DPROJECT_NAME=\"$(PROJECT_NAME)\"
    CFLAGS += -DPROJECT_VERSION=\"$(VERSION)\"
    CFLAGS += -DUSE_APP_CONFIG
    CFLAGS += -DAPP_TIMER_V2
    CFLAGS += -DAPP_TIMER_V2_RTC1_ENABLED
    CFLAGS += -DCONFIG_NFCT_PINS_AS_GPIOS
    CFLAGS += -DCONFIG_ZIGBEE_ERROR_TO_STRING_ENABLED
    CFLAGS += -DFLOAT_ABI_HARD
    CFLAGS += -DLIBZBOSS_CONFIG_FILE=\"libzboss_config.h\"
    CFLAGS += -DNRF$(IC_NUM)_XXAA
    CFLAGS += -DZBOSS_BUILD
    CFLAGS += -DZB_NRF_INTERNAL
    #CFLAGS += -DZB_ROUTER_NO_ED
    CFLAGS += -DZB_NVRAM_FLASH_AUTO_ADDRESS
    CFLAGS += -DZB_ZCL_SCENES_OPTIONAL_COMMANDS_DISABLED
    CFLAGS += -DZB_ZCL_USE_ZCL7_AS_DEFAULT_REVISION
    #CFLAGS += -DZB_TRACE_LEVEL=0
    #CFLAGS += -DZB_TRACE_MASK=0
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS += -Wall -Werror
    CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # keep every function in a separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin -fshort-enums -Wno-packed-bitfield-compat
    CFLAGS += -Wno-error=unused-variable
    CFLAGS += -Wno-error=unused-function
    # C++ flags common to all targets
    CXXFLAGS += $(OPT)
    # Assembler flags common to all targets
    ASMFLAGS += -ggdb3
    ASMFLAGS += -mcpu=cortex-m4
    ASMFLAGS += -mthumb -mabi=aapcs
    ASMFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    ASMFLAGS += -DAPP_TIMER_V2
    #ASMFLAGS += -DZB_ROUTER_NO_ED
    ASMFLAGS += -DAPP_TIMER_V2_RTC1_ENABLED
    ASMFLAGS += -DFLOAT_ABI_HARD
    ASMFLAGS += -DLIBZBOSS_CONFIG_FILE=\"libzboss_config.h\"
    ASMFLAGS += -DNRF$(IC_NUM)_XXAA
    # Linker flags
    LDFLAGS += $(OPT)
    LDFLAGS += -mthumb -mabi=aapcs -L$(SDK_ROOT)/modules/nrfx/mdk -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # let linker dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs
    $(TARGET_RELEASE): CFLAGS += -D__HEAP_SIZE=8192
    $(TARGET_RELEASE): CFLAGS += -D__STACK_SIZE=8192
    $(TARGET_RELEASE): ASMFLAGS += -D__HEAP_SIZE=8192
    $(TARGET_RELEASE): ASMFLAGS += -D__STACK_SIZE=8192
    $(TARGET_DEBUG): CFLAGS += -DDEBUG
    $(TARGET_DEBUG): CFLAGS += -DDEBUG_NRF
    $(TARGET_DEBUG): CFLAGS += -D__HEAP_SIZE=8192
    $(TARGET_DEBUG): CFLAGS += -D__STACK_SIZE=8192
    $(TARGET_DEBUG): ASMFLAGS += -DDEBUG
    $(TARGET_DEBUG): ASMFLAGS += -DDEBUG_NRF
    $(TARGET_DEBUG): ASMFLAGS += -D__HEAP_SIZE=8192
    $(TARGET_DEBUG): ASMFLAGS += -D__STACK_SIZE=8192
    # Add standard libraries at the very end of the linker input, after all objects
    # that may need symbols provided by these libraries.
    LIB_FILES += -lc -lnosys -lm -lstdc++
    .PHONY: all release debug help
    # all targets
    all: release
    # release target
    release: $(TARGET_RELEASE)
    # debug target
    debug: $(TARGET_DEBUG)
    # Print all targets that can be built
    help:
    	@echo "following targets are available:"
    	@echo "    all (default) - build all targets: release and debug"
    	@echo "    release       - build $(TARGET_RELEASE)"
    	@echo "    debug         - build $(TARGET_DEBUG)"
    	@echo "    clean         - clean all targets"
    	@echo "    sdk_config    - starting external tool for editing sdk_config.h"
    	@echo "    flash         - flashing release binary"
    	@echo "    flash_debug   - flashing debug binary"
    	@echo ""
    TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
    include $(TEMPLATE_PATH)/Makefile.common
    $(foreach target_release, $(TARGET_RELEASE), $(call define_target, $(target_release)))
    $(foreach target_debug, $(TARGET_DEBUG), $(call define_target, $(target_debug)))
    .PHONY: flash flash_debug erase
    # Flash the program
    flash_softdevice:
    	nrfjprog -f nrf52 --program $(SDK_ROOT)/components/softdevice/s113/hex/s113_nrf52_7.0.1_softdevice.hex --sectorerase
    flash: release
    	nrfjprog -f nrf52 --program $(OUTPUT_DIRECTORY)/$(TARGET_RELEASE).hex --sectorerase
    	nrfjprog -f nrf52 --reset
    	@make monitor
    # Flash the program
    flash_debug: debug
    	@echo Flashing: $(OUTPUT_DIRECTORY)/$(TARGET_DEBUG).hex
    	nrfjprog -f nrf52 --program $(OUTPUT_DIRECTORY)/$(TARGET_DEBUG).hex --sectorerase
    erase:
    	nrfjprog -f nrf52 --eraseall
    reset:
    log:
    	JLinkRTTViewer
    monitor:
    	@echo "monitor" $(shell JLinkRTTViewerExe --device NRF52833_XXAA --interface swd --speed 4000 --connection usb --autoconnect)
    SDK_CONFIG_FILE := config/sdk_config.h
    CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar
    sdk_config:
    	java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
  • Hi Charlie
    So, I have some update on the problem. So the problem is that I have this
    void zboss_signal_handler(zb_bufid_t bufid)
        zb_zdo_app_signal_hdr_t *p_sg_p = NULL;
        zb_zdo_app_signal_type_t sig = zb_get_app_signal(bufid, &p_sg_p);
        zb_ret_t status = ZB_GET_APP_SIGNAL_STATUS(bufid);
        /*NRF_LOG_INFO("zboss_signal_handler signal %d", sig);*/
        switch (sig) {
                ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
    If I uncomment the Log in this funtion it will pop up repeatedly signal 22. But the weird thing is that in the zigbee_default_signal_handler(bufid), when signal 22 hit, it will go to default like in this code.
                /* Unimplemented signal. For more information see: zb_zdo_app_signal_type_e and zb_ret_e. */
                NRF_LOG_INFO("Unimplemented signal (signal: %d, status: %d)", sig, status);
    But I can never see the log pop up which means that The code in default signal handler has do some thing to filter out the signal. But still I can not figure out how to achieve the same outcome in the self implemented zboss_signal_handler
    I also test with the devkit pca10100 and have the same outcome. I also attach the code for you to check it out
    3884.light_bulb.zip
    Thank you
    Tu
