nrf9160 i2c2 can't be used.
Hi:
I use ncs 1.9.1, borad nRF9160-DK
sda-pin = <30>;
scl-pin = <31>;
Config:
I added i2c2 in blinky, here is the source code.
2251.blinky.zip
I see i2c2 enabled in zephyr.dts
But its output is like this:
    I tried your example, and it seems to run as expected. I see this waveform in the beginning:
    And since I do not have this sensor myself, it does not go further (ie. no ACK).
    this output looks very strange.
    Did you connect GND?
    Håkon
  • Hi Håkon:
      I'm connected to GND.
    I took your build/zephyr/merged.hex file (ie. the one you compiled) and it also worked on the DK. I can see the same trace as posted below.
    Could you take a multimeter and check the voltage on the P0.30/P0.31 pins and see if it's at VDD level? Note that this will follow your VDD_IO settings (ie. the switch in the lower left corner, where you can set either 1.8V or 3V).
    Is your logic analyzer with a logic level of 3V? If so, try to adjust this to 1.8V in the PC application.
    Håkon
