Extended (Periodic) Advertising - data handling
currently I'm testing several options to transfer data in broadcast manner, i.e. in fact extended advertising due to the amount of data to transmit. A few days ago, I found the max. data size I can transfer using periodic advertising. After that I focussed on extended advertising without the periodic option. All my testing examples are based on the periodic_adv or periodic_sync examples coming with ncs.
Today, I found my working object behaving differently from last week. That's why I did a step back, I tested my periodic example from last week. And I found it behaving different too.
I use a sniffer to control the transmitted data. Last week, I found 3 x ADV_EXT_IND, one AUX_ADV_IND, which contained one AD element with the complete local name and one AUX_SYNC_IND, containing the data (data size 249 Byte was ok for the advertiser, on reception side it was only possible to receive 245 byte, which still is ok). Today, I see 3 x ADV_EXT_IND, one AUX_ADV_IND, now containing the data (data size 228 was ok for the advertiser, I didn't test the maximum up to now, but 245 didn't work), and one AUX_CHAIN_IND containing an AD element with the complete local name.
WHY different types now as well as different assignment frame-data and different max. data size??? How often this will change in the future???
