Using Azure C embedded SDK in one of the samples
I am evaluating the usage of Azure C embedded SDK (https://azure.github.io/azure-sdk-for-c/) in one of the nRF 9160DK development samples (https_client)
The Azure C SDK is added via fetchContent of Cmake. And I use the nRF connect to build the https_client sample.
While the compilation works well. I see issues during the linking as follows
c:/users/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: error: _deps/azuresdkforc-build/sdk/src/azure/iot/libaz_iot_provisioning.a(az_iot_provisioning_client_sas.c.obj): conflicting CPU architectures 17/2
c:/users/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file _deps/azuresdkforc-build/sdk/src/azure/iot/libaz_iot_provisioning.a(az_iot_provisioning_client_sas.c.obj)
Am I missing something? I am working on windows and using the nRF connect setup on my VS-code.
