Hard fault from nrf_log_frontend_dequeue()
I'm getting a hard fault that I really need some help to debug. My call stack is shown below and includes nrf_log_frontend_dequeue() as well as a custom service function which calls sd_ble_gatts_hvx().
I checked the CFSR upon the fault following this guide and the only error flag set is for the following:
"IACCVIOL - Indicates that an attempt to execute an instruction triggered an MPU or Execute Never (XN) fault."
This error occurs in two cases:
(1) immediately upon connection with the peripheral device if--and this is a sort of strange condition--if SAADC acquisition time is set to 1us or 5us (NRF_SAADC_ACQTIME_1US)
(2) rarely/sporadically if SAADC acquisition time is set to anything >5us
One connection is that my custom function ble_sws_meas_send is called by the SAADC callback. But the frequency of SAADC reads is set independently of acquisition time, so I don't know why this would have an effect.
Thanks in advance!
  • , thanks for the comment, but as I'm using SDK 17.0.2 (>15.2.0) I think I have an unrelated bug.
    , I am using a static SAADC double buffer, shown below. Should it not be static? (I did try removing the static keyword and got the same error.)
    static nrf_saadc_value_t     m_fr_buffer_pool[2][CHEM_BUFFER_NUM];
    The buffer is initialized as follows:
    err_code = nrf_drv_saadc_buffer_convert(m_fr_buffer_pool[0], CHEM_BUFFER_NUM);
    err_code = nrf_drv_saadc_buffer_convert(m_fr_buffer_pool[1], CHEM_BUFFER_NUM);
    As far as the specific code running during the fault, when it breaks, the call stack points to code for 3 unknown functions, and the most recent is at 0xA60. (This is different than described in my original post, but there have been some smaller unrelated changes to the codebase since, and it is still erring immediately upon Bluetooth connection as before.)
    4770 bx lr
    4B01 ldr r3, [pc, #4]          <- 0xA60
    681B ldr r3, [r3]
    68DB ldr r3, [r3, #12]
    4718 bx r3
    Thanks.
    Noelle
    Yes, using static buffers would be preferred. My concern was that you placed the buffers on the stack, and that an overflow of the available stack size did overwrite some other RAM content.
    0xA60 is the hardfault handler in the MBR, so this is expected when a hardfault occurs.
    Would it be possible to share the project, for us to debug it on our end?
