nRF 5340 DK External Flash(MX25R6435FZNI - Macronix) Programming using J-link plus v10.1.
I am working on to program external flash(MX25R6435FZNI - Macronix) of nRF 5340 DK board using SEGGER J-Link Plus v10.1 version.
I am following Direct mode(The flash is programmed directly via J-Link using the QSPI protocol) of programming method here,
QSPI 20 Pin connection make as per below URL in between J-Link and QSPI of nRF5340 DK board.
URL: About J-Flash SPI (segger.com)
Used J-Flash SPI v7.60b tool to program external flash here and configuration (Options->Project Settings) in J-Flash SPI as per J-Link support and try to connect(Target->Connect->select J-Link) with Target but facing problem "Failed to auto-detect SPI flash" attached the error result and configuration screenshot here.
Can you please guide me how can I resolve that error?
What am trying above is the possible way to program external flash right?
Does my SEGGER J-Link Plus v10.1 version is capable to program external flash via QSPI in nRF5340 DK?
Thanks in advance...!
Kaushik Parsana
