Multiple GPIO interrupts from SYSTEM_SOFT_OFF
OK, so it seems if you accidently hit "VERIFY ANSWER" your discussion gets locked and you can no longer comment, nor reverse that process.  So, I've had to start a new discussion in order to keep on with the old one:
https://devzone.nordicsemi.com/f/nordic-q-a/88286/multiple-gpio-interrupts-from-system_soft_off
What I wanted to say, rather than verify the answer, was:
Hi Simon,
Firstly, I seem to have accidently set your reply to "verified answer" and I can't seem to work out how to reverse that.
Anyway, I'm actually using the nRF Connect SDK (V1.9.1) and Zephyr, and may be 'cross-pollinating" by using those API's.  But I did ask on here if they were the only ones to use and didn't ever get an answer, so have just made them work for the moment.
What I'm seeing I don't think will benefit from button debounce, but I may be wrong.  What seems to be happening is that the first button press will trigger the device out of SYSTEM_OFF mode, and then my code starts running.  But any subsequent button press seems to interrupt the code that is being run and boot the device out of SYSTEM_OFF mode, even though I don't think it is actually in that mode.  This then seems to scramble all the registers I am using to determine how/why it came out of SYSTEM_OFF, and then I can't get it to do what it is supposed to do.
What I want to be able to do is the moment any GPIO triggers an exit from SYSTEM_OFF, that I disable this function so that any subsequent button presses will have no impact.  Essentially a bit like disabling interrupts whilst you service an exisiting interrupt.
But I can't find anywhere online where the functionality to achieve this is described.
I'd be happy to go with a low power mode rather than SYSTEM_OFF if it makes achieving what I want easier.  I can probably deal with quiescent currents of < 5uA.  Its just I couldn't actually find any helpful Zephyr/nRF Connect SDK low power examples, and everyone I have asked seems to look at me blankly.
I had a quick look at the example you listed in the original post.  Can't immediately understand much of it, but I'll go and have a more detailed look.  Also, not sure how relevant it is given I'm not using the nRF5 SDK
Cheers,
Mike
